Service Items (Air Filter / Plugs / Oil) - recommendations? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Service Items (Air Filter / Plugs / Oil) - recommendations? (/showthread.php?tid=78960) Pages:
Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - darrsi - 26-11-17 (25-11-17, 11:03 PM)midden link Wrote: [quote author=fazersharp link=topic=23429.msg270342#msg270342 date=1508838908]I noticed the difference when going passed 7k revs on a dirty air filter. [/quote] I bought a HiFlo air filter years ago which lasted about 3 days before i ordered a K&N. Most likely it was a ropey one, but the bike just didn't breathe at all. Once the new one was fitted the difference was huge. I also did a carb balance though with a 'dirty' K&N and i had to do it again a week later after cleaning it. So a stuffed up air filter really can alter a bikes performance, and as you say at the top end it will undoubtedly make a difference. Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - mtread - 26-11-17 Quote: Ibought a HiFlo air filter years ago which lasted about 3 days before i ordered a K&N.Most likely it was a ropey one, but the bike just didn't breathe at all.You did take the wrapper off didn't you Darrsi? :b [/quote] Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - fazersharp - 26-11-17 In my head a wet K&N filter is likely to get bunged up more quickly than a dry paper one as every single particle that comes along will stick to it where as with a paper one it tends to hit it and fall off and collect out of the way of the main air flow . What do you think Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - darrsi - 26-11-17 (26-11-17, 03:07 PM)fazersharp link Wrote: In my head a wet K&N filter is likely to get bunged up more quickly than a dry paper one as every single particle that comes along will stick to it where as with a paper one it tends to hit it and fall off and collect out of the way of the main air flow . There's a lot more air flow with a K&N Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - celticbiker - 26-11-17 If you can, you might want to turn up your fuelling a bit too if you fit a k&n as you might be running a little lean. Re: Service Items (Air Filter / Plugs / Oil) - recommendations? - darrsi - 26-11-17 (26-11-17, 04:27 PM)celticbiker link Wrote: If you can, you might want to turn up your fuelling a bit too if you fit a k&n as you might be running a little lean. Shouldn't really matter as these bikes run rich anyway, although i do reckon a carb balance will certainly smooth things out. |
