99 fzs600 lumpy idle, lumpy low speed - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 99 fzs600 lumpy idle, lumpy low speed (/showthread.php?tid=78695) Pages:
Re: 99 fzs600 lumpy idle, lumpy low speed - motodevcam - 12-09-17 What a difference! New caps have worked a treat!!! Instant and predictable power when pulling away now farther than "nothing and LURCH"!! Re: 99 fzs600 lumpy idle, lumpy low speed - Riggerlee88 - 21-06-19 Hi I know this is an old thread just ordered some new NGK Caps for mine did you need to trim the leads or is it a straight swap? Re: 99 fzs600 lumpy idle, lumpy low speed - BBROWN1664 - 21-06-19 (21-06-19, 04:18 PM)Riggerlee88 link Wrote: Hi I know this is an old thread just ordered some new NGK Caps for mine did you need to trim the leads or is it a straight swap? Its always best to trim 5mm off if you can Re: 99 fzs600 lumpy idle, lumpy low speed - darrsi - 21-06-19 (21-06-19, 04:18 PM)Riggerlee88 link Wrote: Hi I know this is an old thread just ordered some new NGK Caps for mine did you need to trim the leads or is it a straight swap? When you take the old caps off you’ll see why a trim is needed. Over time the wires inside the HT leads get pushed outwards into the plastic outer part of the lead. 5mm is normally enough to make it all look like new again so you get a good connection with the screw in the new caps. Re: 99 fzs600 lumpy idle, lumpy low speed - Steve3351 - 21-06-19 (31-08-17, 09:34 PM)motodevcam link Wrote: Thank you for helpful replies DAMN....! that plug looks evil.....water coming from somewhere...most probably coolant. Wotever about carbs, u need to sort that issue :evil :evil :evil Re: 99 fzs600 lumpy idle, lumpy low speed - unfazed - 22-06-19 (31-08-17, 09:34 PM)motodevcam link Wrote: Thank you for helpful repliesIt is not coolant, the issue is caused by a blocked drain hole for plugs 3 and 4. when you removed the plug the the rust laden water wet the plug as it was being unscrewed. The build up of water is causing the plug cap to to arc the giving the rough running. It happens when the bike is left on the sidestand in the rain and rubbish gets in there and blocks the hole. You will see the hole on the centre of the side of the head. There is one on both sides. Number 3 is more prone especially if left for long periods on the side stand outdoors uncovered in all weathers. The hole extends from the side of the head to plug 4 and the three is drained past 4. Poke it out or try a blast from a power hose once it is clear wash out the area. Might want to remove the plug cap and clean it out if it is still slightly rough change the plug caps. Re: 99 fzs600 lumpy idle, lumpy low speed - Gabrael72 - 22-06-19 Completely agree with the post above, I took on my Fazer a few years ago and decided to service it (not having much history with it) and number 3 plug sheared off in the head, turns out the previous owner never changed it (only the others) because it had rusted in there due to the drain being blocked, ended up having the head off and drilled out then helicoiled (£450 later,) a good piece of advice would be to take them out and put some antiseize on the plug threads (not too much towards the nut end of the thread) just to help prevent this possibility in the future, also make sure the drain hole is clear too! |
