Stuck Clutch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Stuck Clutch (/showthread.php?tid=77344) Pages:
Re: Stuck Clutch - tommyardin - 08-02-17 (06-02-17, 02:14 PM)crickleymal link Wrote: [quote author=red98 link=topic=21792.msg251820#msg251820 date=1486317039]OK I'll only listen to half of what you say ?. It's a bit annoying that it stuck because I operated the clutch several times every time I went past the bike. [/quote] Pulling the clutch lever in will not free the plates just pushes the pressure plate away but the plates will still be stuck together with the suction of the oil between the plates, they need to spin at a high speed to be able to be thrown apart, or the impact of vigorously rocking the bike back and forth. Re: Stuck Clutch - tommyardin - 09-02-17 (07-02-17, 09:47 PM)YamFazFan link Wrote: [quote author=unfazed link=topic=21792.msg252026#msg252026 date=1486499981] Next question, is the oil semi synthetic or fully synthetic? [/quote] Oh no, not that one again! :'( :lol :lol [/quote] Yeah the old argument rears it's ugly head again, Mineral, Semi synthetic or Fully synthetic. I personally use ........................................ and I will not be persuaded otherwise. :lol Re: Stuck Clutch - unfazed - 10-02-17 Pink sounds like the thin fully synthetic usually used in race bike or sports bike. Last time I used it was in an RSV1000 Mille R Factory I would suggest you change the oil and filter and use the recommended oil 10W40 semi synthetic motorcycle specific oil. There will be fellows on bitching about the oil they use is XXXXXXX and they never had an clutch problems :rolleyes When you want to solve an issue go back to basics :eek Adjust the clutch properly and ensure the bolts on the clutch cover are all tight (10Nm is all they require) Remove the clutch lever and check the hole as it can wear and elongate reducing the amount of leverage and not operate the clutch fully. If the hole is elongated get a new clutch lever Now adjust the clutch properly Screw in the cable adjuster full at the lever end. Remove the rubber bung on the sprocket cover Loosen the lock nut with a deep spanner ( it will loosen with a crack and frighten the crap out of you) Turn the lock nut anti clockwise a full turn Hold you fingers lightly on the clutch lever Turn the centre screw clockwise with a good fitting flat screwdriver You will feel the lever moving out Keep turning the screw until the lever is about 5 to 6mm from the lever housing. Tighten the locknut. Replace the rubber bung Make the final fine adjustments with the cable adjuster at the lever. The reason for asking about the pull on the lever is that heavy duty springs and very thin oil can cause the clutch to stick. This will get the bitchers on now again :rolleyes To be honest I really don't care I am just recommending what to try to resolve the problem. :thumbup Let us know how you get on. |
