Good, sticky grips? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Good, sticky grips? (/showthread.php?tid=76391) Pages:
Re: Good, sticky grips? - Carter - 27-08-16 Was the spacer like a large washer ? If so it'd be for the throttle side between grip and the throttle body. Re: Good, sticky grips? - Freza - 27-08-16 Yes, and I didn't put it. Now it's gonna be a problem to take off the grip ![]() __________________ Sent from my mobile using Tapatalk Re: Good, sticky grips? - Carter - 27-08-16 I wouldn't worry about it if the grips ain't rubbing. It's a bugger when things like that happen tho eh. Re: Good, sticky grips? - Carter - 04-09-16 Got my grips earlier this week, they're 120mm long, it says SB short on the pack so looks like there's two lengths. I've not got bar end weights but they don't supply the plastic end plugs anymore, seem to remember they used to supply glue with them too but never mind eh. They feel harder than the last ones I had but that could've down to them being new. Just gotta get my new risers and renthals now and on they'll go. Re: Good, sticky grips? - rw711 - 31-12-16 Generally 2 lengths of grips 120 mm or 125mm I got short ones for my Kawasaki - and was left with 'the gap' :rolleyes I'm guessing the fazer ones should be 125mm also? Re: Good, sticky grips? - darrsi - 31-12-16 Heated grips are a must.......i use them for a large part of the year in the UK, great in the rain, even better in the cold, i simply couldn't do without them now. A bit like a woolly hat in the snow......you don't have to wear one, but it's so much nicer if you do. :thumbup |
