Top Speed 2001 FZS600?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Top Speed 2001 FZS600?? (/showthread.php?tid=75893) |
Re: Top Speed 2001 FZS600?? - joebloggs - 16-06-16 (16-06-16, 09:08 PM)sinto link Wrote: [quote author=Bretty link=topic=20329.msg234452#msg234452 date=1466097510] Fek me, I'll need to find out how you get that! :pokefun [/quote] 141mpg, better than porn Colin lol Re: Top Speed 2001 FZS600?? - BIG MAC - 16-06-16 (16-06-16, 11:38 AM)BBROWN1664 link Wrote: Sounds like you have a restrictor kit fitted Dalton. A mistake that's often made...The Blue one had already arrived at destination Re: Top Speed 2001 FZS600?? - Millietant - 16-06-16 (16-06-16, 09:13 AM)Dalton Godwin link Wrote: Hi All, So what happens at 86mph Dalton - are you at full throttle ? At what speed does winding on more throttle stop making any difference, does it misfire at that speed, what RPM's is it running at, does it stop at 86mph in 4th, 5th, 6th gear or in all of them? - it's difficult to give any real feedback without a better description of the problem. I put a restrictor kit on our sons 600 Fazer when I bought it, as he was only 3 weeks past his 17th birthday when he passed his test - but even so, it would eventually get up to just shy of 110 mph in the right conditions if the throttle was teased on gently after the restrictors effect kicked in, in top gear. The thing was though, because it was a carb restrictor kit, it would run out of steam in all gears at around 7,000 rpm (the sign of a restricted one) and once you reached 2/3 throttle, opening it further had no effect whatsoever. With the restrictors removed it flies - it's indicated +140 mph at the Nurbutgring after the gantry on the final straight and it got there with ease. Oh, and it's a Silver '03 model (no top box on at the 'Ring though). Re: Top Speed 2001 FZS600?? - sinto607276 - 17-06-16 (16-06-16, 09:38 PM)joebloggs link Wrote: 141mpg, better than porn Colin lolI wouldn't know! :rolleyes :lol Re: Top Speed 2001 FZS600?? - darrsi - 17-06-16 (16-06-16, 10:35 AM)BIG MAC link Wrote: Err a 51 plate in fast blue with micron exhaust absolutely will not ever do an indicated 142 mph...that would be madness. Equally a similar bike cannot do 130..two up 135mph, with a passenger, been there done that, and only shut off 'cos a car moved into my lane about a quarter of a mile ahead of me, but it was still going strong otherwise. As for yer mans bike, i would say it HAS to be restricted, otherwise for this particular bike to have such a poor top speed through a fault i'd imagine it would run and sound like a biscuit tin full of nails, or if it was an air leak for instance it would be bogging down like mad. Even when restricted though i'm sure they're meant to go faster than that, so something is certainly very wrong either way. Re: Top Speed 2001 FZS600?? - Fazer99 - 17-06-16 (17-06-16, 05:51 AM)darrsi link Wrote: Even when restricted though i'm sure they're meant to go faster than that, so something is certainly very wrong either way. Depends on the type of restrictor fitted and where it's fitted (according to my engineer friends and co workers), as the one that was fitted to my FZR just killed the top end speed. Re: Top Speed 2001 FZS600?? - darrsi - 17-06-16 Okay, so according to this fella, they do around 90mph when restricted to 33bhp, which would point even more to the OP's bike being restricted as well. http://www.themotorbikeforum.co.uk/viewtopic.php?t=47360 Re: Top Speed 2001 FZS600?? - Skippernick - 17-06-16 Think he needs to reply to this thread a bit more otherwise you lot will make into a ver long one!!! :lol Re: Top Speed 2001 FZS600?? - Dalton Godwin - 22-06-16 Hi all, Firstly, Thanks very much to everyone that responded. I thought I'd set up an email alert to tell me when people were replying to my thread, but clearly I hadn't, so apologies for not replying sooner, as I thought I'd had not responses!! The bike is a red one ![]() I'll double check the gears in a bit, but I'm reasonably sure I'm in 6th gear when it maxes out. I wouldn't say the bike accelerates particularly hard in any gear (compared to other bikes I've had). Ok, so it accelerates harder than the shitty Vauxhall Nova (that thinks he's quicker than me), but so does my 1.4 Scirocco. So to answer this I would say it saunters up to 86mph, and then stops accelerating. I've changed the wheel bearing today, and I'm just in the middle of an oil & filter change. It's an interesting point about the restrictor kits. I've never heard of them before, so I wouldn't really know what to look for. Are there different types, and how did I identify them? Regards Dalton Re: Top Speed 2001 FZS600?? - darrsi - 22-06-16 "...The bike is a red one..." Solved! :rollin :rollin :rollin Re: Top Speed 2001 FZS600?? - Oldgit - 22-06-16 Blue ones can achieve light speed. Re: Top Speed 2001 FZS600?? - Aky208 - 23-06-16 Mine has a restrictor in the carbs that I'm yet to take out. Still manages 110 though! Re: Top Speed 2001 FZS600?? - fazersharp - 23-06-16 (22-06-16, 09:08 PM)Oldgit link Wrote: Blue ones can achieve light speed.Black A black hole can bend time and light Re: Top Speed 2001 FZS600?? - unfazed - 23-06-16 And a red one needs to be restricted to allow the black and blue ones to keep up :lol Re: Top Speed 2001 FZS600?? - joebloggs - 23-06-16 Mine looks fast, unfortunately it only goes as fast as I can push it atm............... Re: Top Speed 2001 FZS600?? - Dalton Godwin - 23-06-16 Hi All, A bit of an update: Scraping Noise: I've replaced the front wheel bearings, but the horrible noise (continuous scraping) is still there, even at 5mph. The calipers have already been cleaned up, so I don't think it's sticking calipers. It's doing me head in Top Speed The bike thanked me for the oil & filter changed this morning, saying it felt like it's had a good clear-out. We all know how that feels :rollin Unfortunately, it wasn't grateful enough to go over 84mph!! I've heard rumours that Fazers don't like after-market Speedo's (speedometer, not the swimming trunks, although I understand they don't like those either). I've therefore put the original clocks back on, but still no joy get past 84mph this morning :'( If a previous owner has put a speed restrictor on, where might they have put it? Also, an issue I've not posted about before, but I understand it's quite common, Going from 2nd to 3rd gear, whilst the gear selector moves up, it doesn't seem to engage 3rd. This means the process is... 1st to 2nd....2nd, clutch in, left foot up, left foot up again, and I'm in 3rd (definately 3rd). Aparently Fazers have something inside the wears and can be replaced? I think I've bought a bit of a lemon here. Yes I know it was a Cat-D, but these problems seem endless :'( Any advice much appreciated. Dalton Re: Top Speed 2001 FZS600?? - joebloggs - 23-06-16 Get the front wheel off the ground and slowly rotate the wheel, may be easier to hear where the sound is coming from. Re: Top Speed 2001 FZS600?? - Dalton Godwin - 23-06-16 Hi mate, thanks for the reply. I've tried that one, but can't hear anything other than the calipers passing through the pads. I'm wondering whether the forks are mis-aligned as I've replaced the forks as part of getting it back on the road after the Cat-D write-off? As with the other stuff, who knows what the previous owner did to it!! Re: Top Speed 2001 FZS600?? - BBROWN1664 - 23-06-16 restrictor kits, if fitted, go in the carb to stop the needles opening too far or in the airway between the airbox and the engine (could be either side of the carb) to prevent too much air and therefore fuel reaching the engine. Re: Top Speed 2001 FZS600?? - darrsi - 23-06-16 (23-06-16, 10:23 AM)Dalton Godwin link Wrote: Hi mate, thanks for the reply. I've tried that one, but can't hear anything other than the calipers passing through the pads. If the forks were misaligned you'd have trouble putting the spindle on, so i doubt it's that. |
