Faulty Ignition Switch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Faulty Ignition Switch (/showthread.php?tid=74637) Pages:
Re: Faulty Ignition Switch - old son - 13-01-16 Ill drop him a PM but I've taken mine apart and there is nothing obvious that needs to be removed to free the barrel. Maybe there is a circlip somewhere. I'll look again. Re: Faulty Ignition Switch - b1k3rdude - 14-01-16 (13-01-16, 10:58 PM)old son link Wrote: Ill drop him a PM but I've taken mine apart and there is nothing obvious that needs to be removed to free the barrel. Maybe there is a circlip somewhere. I'll look again.Hmm got some pics..? Im wondering if the barrel is cast as part of the cap..? if so then while a bit extreme you could swap all the small barrel keys from one to the other. You'd have to do them one at a time noting the position/slot - but thats even assuming you can even get to them. Re: Faulty Ignition Switch - old son - 14-01-16 I'll take another look this evening. Re: Faulty Ignition Switch - b1k3rdude - 17-01-16 How goes it..? Re: Faulty Ignition Switch - old son - 18-01-16 I stripped it down last night and I cant see any way of removing the barrel. ![]() ![]() I have repainted the second hand unit I bought and it is now looking presentable. Think I will fit Wednesday evening. Re: Faulty Ignition Switch - b1k3rdude - 18-01-16 (18-01-16, 08:25 AM)old son link Wrote:
Re: Faulty Ignition Switch - old son - 19-01-16 I posted pics in my earlier post. There is nothing else to take pics of. When I undo the top bolt on the top plate to remove the old lock, will the bearing come off with the plate? If it does how do I get the bearing out of the original plate and into the replacement plate? Re: Faulty Ignition Switch - Falcon 269 - 19-01-16 No, mate, the bearings remain in place. It's a very simple swap as you'll see when you remove the top nut.
Re: Faulty Ignition Switch - old son - 19-01-16 Thanks Mike, that makes it a lot easier! |
