Clutch adjusting nut - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Clutch adjusting nut (/showthread.php?tid=74198) Pages:
Re: Clutch adjusting nut - sinto607276 - 01-11-15 (01-11-15, 08:51 PM)darrsi link Wrote: Was thinking about that gadget earlier. Might not fit in the gap as you say, but another problem you'll have is the centre pins will push up against the adjusting screw first and maybe not allow it to go down far enough to catch the nut. Re: Clutch adjusting nut - darrsi - 01-11-15 (01-11-15, 09:02 PM)sinto link Wrote: [quote author=darrsi link=topic=18632.msg214731#msg214731 date=1446407477] Might not fit in the gap as you say, but another problem you'll have is the centre pins will push up against the adjusting screw first and maybe not allow it to go down far enough to catch the nut. [/quote] Yeah, i just said exactly the same thing to a mate of mine. Handy little gadget though, just ordered one for £7.99, it's bound to come in handy. Re: Clutch adjusting nut - sinto607276 - 01-11-15 (01-11-15, 09:12 PM)darrsi link Wrote: [quote author=sinto link=topic=18632.msg214732#msg214732 date=1446408152] Might not fit in the gap as you say, but another problem you'll have is the centre pins will push up against the adjusting screw first and maybe not allow it to go down far enough to catch the nut. [/quote] Yeah, i just said exactly the same thing to a mate of mine. Handy little gadget though, just ordered one for £7.99, it's bound to come in handy. [/quote] Always handy, I've got one in the bottom of my tool box just in case, but really only good if you have clear access to the thing you want to move. I've used mine to remove many a worn nut/bolt. You just need to remember to push it on and hold it there as you turn to slacken or it just comes off
Re: Clutch adjusting nut - celticdog - 02-11-15 Don't forget to let us all know how you get on with this one darrsi
Re: Clutch adjusting nut - mr self destruct - 02-11-15 I find Metrinch sockets perfect for situations like this. http://www.ebay.co.uk/itm/METRINCH-1-4-Socket-Spanners-Set-0-20-0-51-9-Pt-Deep-Long-MET-0230-Cliprail-/251971465959?hash=item3aaaab72e7:m:msilKaJMdrPx895LgYuPYLw They have quite bad reviews and are known for rounding off good nuts, but I only use mine for nuts that are already fucked so I've got nothing to lose. Re: Clutch adjusting nut - darrsi - 02-11-15 I remembered today that I have some unused brand new Impact Driver sockets, which I can only presume will have 6 flats on? (gotta think where I've put them?) Got it all adjusted okay at the mo' so not gonna attempt anything until the new nut turns up. Re: Clutch adjusting nut - His Dudeness - 02-11-15 Impact sockets are often thicker than a normal socket so the outside diameter might not fit in the hole but if it does that's what I'd try first. An impact socket with a rattle gun. There's also a "universal socket" that might be worth trying. It has pins in it that retract to form the shape of the nut. I haven't seen or used one before so can't say if it's any good or not http://www.fleetfarm.com/products/images/medium/0000000030982.jpg Re: Clutch adjusting nut - darrsi - 03-11-15 (02-11-15, 11:53 PM)His Dudeness link Wrote: Impact sockets are often thicker than a normal socket so the outside diameter might not fit in the hole but if it does that's what I'd try first. An impact socket with a rattle gun. Yeah, that was mentioned earlier, which resulted in me buying one anyway, i'm too easy like that. :lol Bit concerned it may latch on to the centre adjusting worm screw and possibly damage it. Re: Clutch adjusting nut - His Dudeness - 03-11-15 I had the same worry getting a big bolt off the end of a crankshaft. I thought the engine might turn over and fire me off over the other side of the workshop :lol but it didn't because it's the rapid on off impacting that does the job rather than a constant torque. An impact gun should zip if off no problem Re: Clutch adjusting nut - darrsi - 10-11-15 Still not touched it 'cos it's all okay at the mo', but for anyone interested this is what it looks like. Not sure which way round it goes yet? Re: Clutch adjusting nut - celticdog - 10-11-15 Glad all's ok for the mo'. Looks like its got quite a coarse thread on it Darrsi. I wonder if it's metric or JIS? Now where did I put my Zeus chart? :lol Re: Clutch adjusting nut - darrsi - 10-11-15 (10-11-15, 09:39 PM)celticdog link Wrote: Glad all's ok for the mo'. Looks like its got quite a coarse thread on it Darrsi. Picture's a bit deceiving, don't forget it's only a 12mm nut. I'll replace it at the weekend in the daylight hours. Re: Clutch adjusting nut - darrsi - 15-11-15 All sorted, found a long 12mm socket i never knew i had which had 6 points rather than 12 points on it and it came off no problem. My impact socket would have fitted as well, as there was plenty of room. Changed the OEM nut with the replacement version, which is hopefully made of sterner stuff. Another Fazer part made of the finest cheese. Re: Clutch adjusting nut - Val - 16-11-15 (15-11-15, 02:52 PM)darrsi link Wrote: All sorted, found a long 12mm socket i never knew i had which had 6 points rather than 12 points on it and it came off no problem. Good work :thumbup Where have you bought the replacement version? I am asking cause need to adjust it soon myself... Re: Clutch adjusting nut - darrsi - 16-11-15 (01-11-15, 08:02 PM)darrsi link Wrote: Just ordered a replacement version of the nut, so hopefully it won't be made of cheese like this one, from ATV Parts UK. As above ![]() If you use a socket with just the 6 points on it rather than 12 I think you'll be totally fine undoing it. A 12mm deep angled ring spanner is the correct way of nipping it back up though, 'cos you need to adjust the centre screw. It really does make a difference when adjusting it properly from the lower end first, the clutch lever and changing gear felt much smoother this morning in comparison to before. I've been stuck in so much traffic over the last month I'm probably wearing the cable out much quicker than it should do, and I've been burning fuel for fun. I wouldn't mind but it's not even that far to my work but recent journeys have been horrendous with the sheer volume of traffic, sometimes with my own road being clogged up. On really bad days I've even resorted to sneakily using the pavement in side roads otherwise I just wouldn't move. :\ |
