Engine mounts 99 FZS - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Engine mounts 99 FZS (/showthread.php?tid=73751) Pages:
Re: Engine mounts 99 FZS - unfazed - 09-09-15 Ouch! indeed, lucky lad, lots of limbs lost due to compartmental syndrome not being diagnosed in time. :'( Came close myself over the same thing, still can't run, but can do everything else. Takes time, a lot of time
Re: Engine mounts 99 FZS - Bretty - 10-09-15 I think I am being stupid! There are 4 bolts that go through the engine. 2 at the front side by side and 2 at the back. Long ones, one above the other. Are you saying there is only one mount at the back? Maybe it is because mine is 2000. I had the engine out again last night and refitted it. I have some spare engine cases sat outside if any one is interested? Re: Engine mounts 99 FZS - Notch000 - 10-09-15 i never notived te upper back one, hopefully its not smashed too !! is it hard to access ? Re: Engine mounts 99 FZS - unfazed - 10-09-15 Two long ones at the back top and bottom, two short ones at the front left and right. Probably bent the frame mountings at the rear. Re: Engine mounts 99 FZS - Bretty - 11-09-15 You can see the bolt heads if you look.. here and here.. (although not very well on my photo) Re: Engine mounts 99 FZS - Notch000 - 14-09-15 thanks for that Bretty, it will be another few weeks before I get to look at mine properly as i have it in storage and im heading abroad for a couple of weeks, do you have any pics of the back of the engine out of bike ??? I have a quick look last night and coudent make out the top rear engine mount Re: Engine mounts 99 FZS - Bretty - 14-09-15 This is obviously with the engine case split. But shows the mounts. You should buy these off me and fit your internals! You'll only need a couple of gaskets! ;-) Re: Engine mounts 99 FZS - joebloggs - 14-09-15 (14-09-15, 02:37 PM)Bretty link Wrote: This is obviously with the engine case split. But shows the mounts. You should buy these off me and fit your internals! You'll only need a couple of gaskets! ;-) Gasket set and possibly all new big end shells, seals etc, maybe a good idea but not ness a cheap one Re: Engine mounts 99 FZS - Notch000 - 14-09-15 No thanks, live in Ireland and think it would be much easier to weld & repair broken mount, assuming top one is ok Re: Engine mounts 99 FZS - Bretty - 14-09-15 I just rebuilt my engine with new head and cylinder gasket and threebond for £70 all in (plus fluids, 20hrs work and a bit of swearing and tool throwing) It's definitely easier to buy a complete secondhand lump (£250~) if you can find one with a history you trust. I reckon in this instance a 'new' frame will be needed as it's tricky enough getting the lump in and out of a straight one! To be honest, If that was my bike, I'd be breaking it. :-( Re: Engine mounts 99 FZS - joebloggs - 14-09-15 You were fortunate that all the shells were the correct size Re: Engine mounts 99 FZS - Bretty - 14-09-15 I only changed the gearbox components. The crank shaft and corresponding shells never changed. Re: Engine mounts 99 FZS - Notch000 - 14-09-15 (14-09-15, 03:48 PM)Bretty link Wrote: I just rebuilt my engine with new head and cylinder gasket and threebond for £70 all in (plus fluids, 20hrs work and a bit of swearing and tool throwing) il see how it line up & go from there , big bcrow bar and a lump hammer. its my first bike so id probably rather burry it than break it, I saw another frame for sale so that's option 2 !! I have new sub frame mount and bolt set in the post first too <a href="http://photobucket.com/" target="_blank"><img src="http://i252.photobucket.com/albums/hh1/Notch000/DSC_0475.jpg" border="0" alt=" photo DSC_0475.jpg"/></a> |
