Cable routing..... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Cable routing..... (/showthread.php?tid=73238) Pages:
Re: Cable routing..... - sinto607276 - 17-07-15 (17-07-15, 08:41 AM)unfazed link Wrote: To suppress Sintos confused state :lolI resemble that remark :b (17-07-15, 08:41 AM)unfazed link Wrote: It is the diode for the Neutral Light circuit, on the 98-99 models it is under the tank and on the foxeye models it is integrated into the Starter cut out relay and the 2000-2001 models it is as you see in Anutzs pictureAhh, that's cleared it up, cheers ![]() (17-07-15, 08:41 AM)unfazed link Wrote: I can see a question coming here :eekNo more questions your honor :rolleyes Re: Cable routing..... - anutz - 17-07-15 The issue is how this connection and routing happens...
Re: Cable routing..... - unfazed - 17-07-15 Relay is in the wrong way, rotate it 90degrees anticlockwise from where it is in the picture and then follow the previous clear as mud instruction
Re: Cable routing..... - anutz - 17-07-15 thanks Unfazed.....i shall try that.... :lol Re: Cable routing..... - anutz - 17-07-15 not sure its in the wrong way, if i rotate it then nothing reaches and the positive lead is pointing the wrong way.... Re: Cable routing..... - unfazed - 17-07-15 The red lead comes out the back and turns to the right and over the top of the relay between the connections and the fuses to the battery positive. When all tightened up push the lead down the rear of the relay. Check out the routing on page 15 of the manual Re: Cable routing..... - anutz - 17-07-15 :'( This is harder than getting the timing chain and cams lined up! Tommorow i shall have another bash :b Re: Cable routing..... - sinto607276 - 17-07-15 (17-07-15, 10:01 PM)anutz link Wrote: :'( This is harder than getting the timing chain and cams lined up!You'll be fine anutz, as suggested by unfazed, you'll be looking a book with pictures in it :b :rollin Re: Cable routing..... - anutz - 18-07-15 OK think i got it!
Re: Cable routing..... - unfazed - 18-07-15 Not quite correct. Take off the red cable from the battery and pull it back, then put it to the right side of the relay (bike right side) and back to the battery over the top of the relay. The black cable looks fine. The reason it goes over the top of the relay is that it make it easier to remove and move away from the battery if ever it is necessary when working on the bike. I will try and get a picture of mine later. Re: Cable routing..... - anutz - 18-07-15 ah i see what you mean, i will go re-route that little bugger......you see.....it was easier to get the engine timing right :lol Re: Cable routing..... - sinto607276 - 18-07-15 (18-07-15, 09:52 PM)anutz link Wrote: ah i see what you mean, i will go re-route that little bugger......you see.....it was easier to get the engine timing right :lol :rollin :rollin Re: Cable routing..... - unfazed - 18-07-15 Here is the picture of mine and it has been that way for 86000miles :lol Re: Cable routing..... - sinto607276 - 18-07-15 Is that a crop circle to the right of your picture unfazed? :b |
