USB/Charger Port - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: USB/Charger Port (/showthread.php?tid=72681) Pages:
Re: USB/Charger Port - sinto607276 - 29-05-15 (29-05-15, 11:41 AM)dilboy link Wrote:First of all thanks for all the advice and fear of fire :eek Re: USB/Charger Port - dilboy - 29-05-15 (29-05-15, 09:05 PM)sinto link Wrote:[quote author=dilboy link=topic=17112.msg197407#msg197407 date=1432896071][/quote] Re: USB/Charger Port - sinto607276 - 29-05-15 (29-05-15, 09:14 PM)dilboy link Wrote:Firstly, we've got to unwire you from the moon :lol But seriously, You'll need to find thefuse box near battery, Have a circuit tester (or 2 bits of wire with 12v bulb) Connect one end to NEGATIVE on battery Switch on ignition Touch terminals (one at a time) with other wire or terminal of circuit tester You will see light come on or movement on circuit tester Switch off ignition If light goes out, that's where you want to connect your POSITIVE wire from.your USB charger and leave the NEGATIVE on the battery or find an earth nearby. If you don't get a light coming on or movement on the tester, repeat the above steps till you do Simples, job done
Re: USB/Charger Port - sinto607276 - 29-05-15 (29-05-15, 09:30 PM)sinto link Wrote:[quote author=dilboy link=topic=17112.msg197456#msg197456 date=1432930468]Firstly, we've got to unwire you from the moon :lol But seriously, You'll need to find thefuse box near battery, Have a circuit tester (or 2 bits of wire with 12v bulb) Connect one end to NEGATIVE on battery Switch on ignition Touch terminals (one at a time) with other wire or terminal of circuit tester You will see light come on or movement on circuit tester Switch off ignition If light goes out, that's where you want to connect your POSITIVE wire from your USB charger and leave the NEGATIVE on the battery or find an earth nearby. If you don't get a light coming on or movement on the tester, repeat the above steps till you do Simples, job done ![]() [/quote] Re: USB/Charger Port - anutz - 29-05-15 still curious as to what fuse you used? and how you know what the wires are rated to carry?
Re: USB/Charger Port - dilboy - 30-05-15 I bought the fuse and connectors at Maplins,explained the situation and he suggested the 15a fuse. Regarding the wire not sure there
Re: USB/Charger Port - sinto607276 - 30-05-15 (30-05-15, 12:20 PM)dilboy link Wrote:I bought the fuse and connectors at Maplins,explained the situation and he suggested the 15a fuse.There's your problem, Maplin's have no clue about bike electrics :groan Re: USB/Charger Port - dilboy - 30-05-15 And neither do I :wall Re: USB/Charger Port - dilboy - 30-05-15 Plus I've just fond the earth wire has a break inside it so, got to replace it :'( I've had a look at the ignition idea, looked in the fuse box, but it scared me so I ran off, could it be explained again in really easy steps. Dilboy, the not so good electrician :evil Re: USB/Charger Port - sinto607276 - 30-05-15 (30-05-15, 02:40 PM)dilboy link Wrote:could it be explained again in really easy steps. Here it is in really easy steps for you You'll need to find thefuse box near battery, Have a circuit tester (or 2 bits of wire with 12v bulb) Connect one end to NEGATIVE on battery Switch on ignition Touch terminals (one at a time) with other wire or terminal of circuit tester You will see light come on or movement on circuit tester Switch off ignition If light goes out, that's where you want to connect your POSITIVE wire from.your USB charger and leave the NEGATIVE on the battery or find an earth nearby. If you don't get a light coming on or movement on the tester, repeat the above steps till you do. Simples, job done Re: USB/Charger Port - unfazed - 30-05-15 Show the foccer a picture :lol :lol A picture tells a thousands words :rollin :rollin :rollin One thing "a 15amp fuse" What the Foc are they charging, the battery in the truck John McGuinness uses for going to races? :lol :lol Re: USB/Charger Port - sinto607276 - 30-05-15 (30-05-15, 10:19 PM)unfazed link Wrote:Show the foccer a picture :lol :lolWho's to show who a picture? And of what exactly? (this thread could go in a totally different direction now)
Re: USB/Charger Port - unfazed - 30-05-15 (30-05-15, 10:32 PM)sinto link Wrote:[quote author=unfazed link=topic=17112.msg197600#msg197600 date=1433020750]Who's to show who a picture? And of what exactly? (this thread could go in a totally different direction now) [/quote] Here's hoping it does :lol Re: USB/Charger Port - sinto607276 - 30-05-15 :agree :useless |
