Crank case welding. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Crank case welding. (/showthread.php?tid=72413) Pages:
Re: Crank case welding. - davidkent - 06-05-15 That makes sense can't see theyre a hard swap Re: Crank case welding. - Deefer666 - 06-05-15 courier is fine, it'll go to my business address so usually no problems with carriers Re: Crank case welding. - Deefer666 - 06-05-15 You can use the late model alternator on an early engine its simply a case of changing the connection, the early alternator will also work on the late engine.... I know the alternator was upgraded but the old one works the on the new bike just fine in my experience, I'm guessing that you would only encounter a problem if you tried to run several accessories from it, like heated grips, heated clothing, sat nav etc all at once. Re: Crank case welding. - davidkent - 06-05-15 That seems reasonable to be fair. most I use is sat nab and phone charger anyway Assuming this engine is pretty up straight I won't need to do the cam chain or anything? Just swap my front sprockets over and get fitted? If you manage to find the mileage that'd be great then we cN inbox re purchase. I think it's the safe bet plus ill have a shed load of spares. Is the engine complete? Re: Crank case welding. - Deefer666 - 06-05-15 The engine is complete apart from the front sprocket cover and its still in the frame atm. You wont have to do anything other than put new oil & filter in it and fit your front sprocket... It is a bit dirty so you may wanna take some time and give it a bit of a de-gunk before fitting it. I am working away from home from tomorrow until Sunday but can organise it on Monday Re: Crank case welding. - davidkent - 06-05-15 No problem. If I went the rebuild option was the 300 with parts? And what sort of time scale would that work on? Re: Crank case welding. - Deefer666 - 06-05-15 Its a days work (if supplied a bare engine) I could poss fit it in toward the tail end of next week |
