Chain cleaner: is it a big con? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Chain cleaner: is it a big con? (/showthread.php?tid=72412) Pages:
Re: Chain cleaner: is it a big con? - BBROWN1664 - 05-05-15 I just use a scottoiler and never clean the chain unless it is really full of crud. Paraffin is the cleaner of choice then. Re: Chain cleaner: is it a big con? - Dead Eye - 05-05-15 (04-05-15, 06:33 PM)noggythenog link Wrote: What's wrong with wd40 then guys...thats what i used...have i focced up? WD40 can cause rubber and seals to swell which ends up allowing dirt and grease past the seal. I've seen this myself, as well as with Brake Cleaner though thankfully the part was a proper seal so no huge issue for me at the time (this was on the car) Re: Chain cleaner: is it a big con? - Hamos - 05-05-15 Parafin and the same brush that Bigralphy uses, then lube of choice Re: Chain cleaner: is it a big con? - stevierst - 05-05-15 You can never have enough lube ![]() ![]()
Re: Chain cleaner: is it a big con? - johnakay - 05-05-15 oh its not my fingers!! mine are still intact. copied and post off the internet what other fools did. thanks anyway.john Re: Chain cleaner: is it a big con? - riedrider - 06-05-15 I use this and have still all fingersĀ http://www.kettenmax.com/product_info.php/info/p2_KettenMax-Premium-chain-maintenance-kit-for-motorbike.html A simple idea but it works very good. To clean the chain I use diesel which is nearly the same as paraffin. Both will do no harm to the o-rings. With petrol I would not be sure. Re: Chain cleaner: is it a big con? - fazersharp - 07-05-15 The issue I find with stuff like that is you then spend the same amount of time again cleaning the cleaner Re: Chain cleaner: is it a big con? - stevierst - 07-05-15 We could start a new thread "what's the best chain cleaner cleaner?" Re: Chain cleaner: is it a big con? - brooker81 - 07-05-15 Carlsberg. Re: Chain cleaner: is it a big con? - stevierst - 07-05-15 Probably ![]()
