slight oil leak - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: slight oil leak (/showthread.php?tid=72152) Pages:
Re: slight oil leak - darrsi - 13-04-15 Like the white room in Charlie & The Chocolate Factory. :lol I had to work on a film camera in that room in the last version of the film 11 years ago, but I only had to wear shoe covers to stop the floor getting dirty.
Re: slight oil leak - His Dudeness - 13-04-15 Just going out to do a bit of maintenance on the bike :lol
Re: slight oil leak - Deefer666 - 14-04-15 The FZS does not need the sprocket cover gasket the only reason it was ever fitted was to stop the corrosion issue between two mating ali surfaces. The oil leak will either be from the o ring that seals the push rod ...easy fix or the main output shaft seal behind the front sprocket... Not such an easy or cheap fix. Re: slight oil leak - Paulfzs - 30-04-15 So oil change done, correct amount of oil put in, other than a bit of clutch slip the oil leak is still there... its still not dripping badly but it is leaving oil on the floor.. It appears to be coming from one of the bolt holes for the sprocket cover or one of the dowel pins. there is a noticeable coating of oil on the sump where its dripped down... Why would it be leaking from the down pin or bolt hole? Re: slight oil leak - Punkstig - 01-05-15 Only because the fluid has found that to be the easiest route using gravity! Re: slight oil leak - Paulfzs - 01-05-15 how has it found its way through a bolt hole though lol |
