70mph in top gear??? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 70mph in top gear??? (/showthread.php?tid=71940) Pages:
Re: 70mph in top gear??? - Paulfzs - 25-03-15 (25-03-15, 01:34 PM)rhinoeli link Wrote: [quote author=Paulfzs link=topic=16362.msg188455#msg188455 date=1427286766] Done that. My speedo cheats around 3-4% up. [/quote] most speedos read slightly wrong, id trust my phone gps over the speedo any day Re: 70mph in top gear??? - rhinoeli - 25-03-15 Of course GPS is way more precise. What irritates my mind is the thing that many say their bike runs over 6000 rpm at 70 mph. Referring to the calculations above, 70 mph should be at around 5600 rpm. This is almost 10% difference. Tacho and speedometer should be more precise. In fact his speedo has to show less than the reality, which is not typical. Or the tacho has to show more than reality, which... yeah, we should test it with a proper rpm measuring device. Might worth some experimenting on this topic in the future... Re: 70mph in top gear??? - midden - 25-03-15 (25-03-15, 01:50 PM)rhinoeli link Wrote: Of course GPS is way more precise.I bet you're mates have fun winding you up ![]() (25-03-15, 12:46 PM)rhinoeli link Wrote: [quote author=midden link=topic=16362.msg188445#msg188445 date=1427277303]A few pounds perhaps.Basically you are talking about the cluth slipping which may count at hard accelerations or much higher speeds and rpms. Don't think it is the case here. [/quote] Basically I wasn't
Re: 70mph in top gear??? - rhinoeli - 25-03-15 (25-03-15, 02:08 PM)midden link Wrote: I bet you're mates have fun winding you upSorry, don't really know what does that mean. English is not my best... (25-03-15, 10:55 AM)midden link Wrote: A few pounds perhaps.RPM, transmission, gear ratios and wheel speed are proportinal to each other. The only thing between them is the clutch. Don't know what else were you talking about.? Re: 70mph in top gear??? - midden - 25-03-15 (25-03-15, 10:55 AM)midden link Wrote: A few pounds perhaps.RPM, transmission, gear ratios and wheel speed are proportinal to each other. The only thing between them is the clutch. Don't know what else were you talking about.? [/quote] engine won't need to work as hard going down hill as it would going up hill for the bike to reach 70mph Re: 70mph in top gear??? - fazersharp - 25-03-15 Its odd that the speedo is not an MOT test item Re: 70mph in top gear??? - rhinoeli - 25-03-15 (25-03-15, 02:50 PM)midden link Wrote: engine won't need to work as hard going down hill as it would going up hill for the bike to reach 70mph RPM is the same uphill and downhill if the clutch is engaged. It has nothing to do with the "work". Re: 70mph in top gear??? - midden - 25-03-15 Ok I'm with ya now. But I'm still over 6k at 70mph standard bike
Re: 70mph in top gear??? - AndyL - 25-03-15 Mine reads about 5,800 or 5,900 at 70mph Re: 70mph in top gear??? - greenman - 25-03-15 Ok that got some very mathematical responses, when I say 61/2k rpm, I use this as a rough guide. I have a Speedo that occasionally goes weird, apparently I was doing 125mph around a roundabout I usually take at least than 30 a couple of weeks ago so when it was behaving itself I checked and displayed 70mph is just under 6500rpm = won't get nicked. Re: 70mph in top gear??? - midden - 25-03-15 Commuting to work I feel compelled to jump off and stand corrected. 70mph between 5800 and 6 rpm, 6500 is my normal riding area :o sorry Rhinoela Re: 70mph in top gear??? - the cueball - 25-03-15 thanks everyone, very interesting answers... :rollin Re: 70mph in top gear??? - Jules-C - 25-03-15 (25-03-15, 06:37 PM)greenman link Wrote: I have a Speedo that occasionally goes weird, apparently I was doing 125mph around a roundabout I usually take at least than 30 a couple of weeks ago Check the route of the speedo sensor wire in particular by the brake disc. Weird speedo readings are often caused by the edge of the disc wearing through the insulation and contacting the copper wire and sending confusing pulses to the speedo Re: 70mph in top gear??? - Beeblebrox2nd - 26-03-15 Popping down the road for a jolly jaunt shows that at an indicated 70mph, my tachograph is reading 5900rpm, in standard gearing in top gear. Re: 70mph in top gear??? - clayt74 - 26-03-15 Yep I get 5800 at 70mph standard bike! There is also quite a variance depending on tyre condition n profile. A few extra mm in tread has a large impact on the circumference of the front wheel hence a difference in speed reading..... Also how much tread on rear tyre will also affect the drive ratios. Hehe I await the flaming
Re: 70mph in top gear??? - greenman - 26-03-15 (25-03-15, 11:00 PM)Jules-C link Wrote: [quote author=greenman link=topic=16362.msg188504#msg188504 date=1427305066] Check the route of the speedo sensor wire in particular by the brake disc. Weird speedo readings are often caused by the edge of the disc wearing through the insulation and contacting the copper wire and sending confusing pulses to the speedo [/quote] There is a nick in the the insulation by the disk, I just need to get around to getting it sorted but until then....... Re: 70mph in top gear??? - Jules-C - 27-03-15 ......wrap a bit of insulating tape round it to stop water getting in and leave for about 7 years. It was good insulating tape its not even been replaced! Re: 70mph in top gear??? - YamFazFan - 05-04-15 (24-03-15, 09:12 PM)YamFazFan link Wrote: My 600 is as standard as they come & top gear at 70mph is a fraction over 6000rpm. Maybe 6100'ish. Correction :o :o :o: Just been out on the bike for the first time in ages & made a special point of double checking this figure. At 70mph on the speedo the tacho is reading, as close as I can tell, 5650 RPM. Re: 70mph in top gear??? - freeware - 10-04-15 Standard gearing from my POV: Re: 70mph in top gear??? - fazersharp - 10-04-15 I make mine to be 5850 rpm standard bike, dosent look quite like 5900 |
