Jumping out of second gear - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Jumping out of second gear (/showthread.php?tid=71382) Pages:
Re: Jumping out of second gear - Deefer666 - 07-03-15 Its tricky, but not impossible. Take your time, follow the guide I wrote and it'll all go back in. I'm on 07887 854614 if you need advice/moral support/piss taking. Good luck! Re: Jumping out of second gear - Triggergee - 07-03-15 I tackled it late last night in the end, was much easier than I thought. Just wiggled it all back in place patiently. All in all not a hard job really but there is no way I would have attempted it without help from deefer and fazerider so thank you both very much! Now I'm just waiting for my oil level senser and a new bloody sump! I cracked the thing putting the sump plug back in, totally pissed off now I got to say! Another £8 for senser and £25 for the sump plus I have to wait till Tuesday for delivery....... Re: Jumping out of second gear - Deefer666 - 08-03-15 :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup :thumbup Re: Jumping out of second gear - Triggergee - 11-03-15 Well after completing Deefer666's last step in his guide (strutting around like a peacock once the jobs done) I seem to have a working bike again! Rather pleased about it too. Gears are selecting really smoothly and the first to second shift is smoother than ever, hopefully it won't start playing up again too soon if at all. Good stuff cheers guys Re: Jumping out of second gear - Fazerider - 11-03-15 Congratulations! :thumbup Re: Jumping out of second gear - DaveyT - 24-01-16 Hi, I followed Deefers instructions and it really helped me, the only thing is, I have re-assembled the bike and it still jumps out! Any ideas would be greatly received Re: Jumping out of second gear - Bretty - 24-01-16 The dogs will be worn where the gears engage side by side. The dogs are nice and square but each time it jumps out it'll wear a chamfer on the edges, it gets worse and worse until they no longer stay engaged under any torque... As it jumps out it'll likely be bending your new fork. :-S You need a new gear box! I'll take a photo of my knackered gears, if it makes it clearer... Re: Jumping out of second gear - DaveyT - 24-01-16 Thanks for the reply, I have a full assembly but the thought of taking out the full engine to change the internals of the box made my balls shrink so just changed the forks while the engine was in situ hoping that that would sort it, photos would be good so I can Identify better.... cheers Re: Jumping out of second gear - Bretty - 24-01-16 This photo shows the worn bits. The three dogs on the top of the left gear should have sharp edges. You can see the rim underneath that the fork runs in. The fork pushes that lefthand gear across on the shaft so the dogs engage into the holes/slots in the righthand gear. This should also have sharp, not rounded edges in the holes. The combined wear means under any torque they are forced apart and it jumps out into the next hole. I thought my bike was misfiring! It cost me £80 for a donor engine, plus a head gasket, a tube of that liquid gasket stuff and three days to get the engine out/in and switch the gearbox in mine. It would be certainly easier if you can do it in your kitchen! Re: Jumping out of second gear - Bretty - 24-01-16 I was quite smug about finding the problem on my bike, then changing everything over. Things like that don't normally work out for me. Re: Jumping out of second gear - DaveyT - 24-01-16 Thanks for the info and pics, I think I'm going to have a sulk about it for a few days then make a start on removing the engine. |
