R1 Front End Cost Estimates - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R1 Front End Cost Estimates (/showthread.php?tid=70698) Pages:
Re: R1 Front End Cost Estimates - devilsyam - 31-01-15 simple if you fit gen 2 upper and modified gen 2 lower then any fork leg from 98 to current inc gen 2 legs there are combo's that dont work r1 98 to 04 wont work with gen2 upper you have to use the r1 top yoke and mod for risers or buy after market wheel and disc cobos are the same unless you use 6 pots as you will need 310mm discs next question Re: R1 Front End Cost Estimates - bigbluebear - 31-01-15 Are the Gen2 forks the same length or will they too need spacers to bring them back to original gen1 length. Or is the R1 fork just a better fork than any gen2 fork, if so its easier just to stick to R1 fork. Reason is I was at my local Bikeshop who would do the work and it was a question from them as they have forks from a 06 Gen2 There is 07-08 R1 4C8 forks not far from me. Would I be limited in my options for these Re: R1 Front End Cost Estimates - devilsyam - 31-01-15 answer there all shorter and its a matter of preferance so love the forward ass up stance some dont hence i make the extensions to return to stock height gen 2s wont work because of bolt pattern so you could try with out if you dony like it fit extenders this is not difficult a job and paying a shop to do it would be expensive any of the fork options discussed will be better according to lee at traxxion the 07-08 for was the best yam made next question Re: R1 Front End Cost Estimates - devilsyam - 31-01-15 these b nice http://www.ebay.co.uk/itm/171631157627?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Re: R1 Front End Cost Estimates - bigbluebear - 31-01-15 With this R1 fork do I need the R1 wheel and radial brakes, or will it work with gen1 wheel and blue spot brakes and then able to upgrade to full R1 front end later. Do all R1 forks require R1 unmodified yolks on both these options. Will I need new front mudguard for both options Re: R1 Front End Cost Estimates - devilsyam - 31-01-15 With this R1 fork do I need the R1 wheel NO and radial brakes YES or will it work with gen1 wheel and blue spot brakes NO AND YES SEE NOTE and then able to upgrade to full R1 front end later. Do all R1 forks require R1 unmodified yolks on both these options.BOTTOM YOKE WILL NEED MODDING IN EVERY CASE TO FIT GEN 1 Will I need new front mudguard for both options YES NOTE gen 1 wheel is 5 bolt r1 is 6 so discs are a issue if wanting 320mm this means upgrading to r1 wheels to make this simple bbb i recon your best option is a set 03 r1 legs to gen 2 top and bottom yokes this retains ya wheel and current calipers whilst still giving you a good fork upgarde you can add extenders at a later date Re: R1 Front End Cost Estimates - bigbluebear - 31-01-15 Ok, food for thought....cheers Re: R1 Front End Cost Estimates - Stupid Luke - 01-04-15 Back to pondering this again. I nearly had a pair of 5PW forks from ebay last night, outbid at last minute! Does anyone know if the billet yokes on ebay (Billet bike bits) are a bolt straight on solution? What I mean is, can I just buy a pair of forks and one of these or will I still need to get things machined and / or a fork stem imported from the states. They are about 450 quid, which seems a lot for something you will hardly see but if they do the job they might be worth it. I am guessing that otherwise I can use a CNC machined top yoke for bar conversion on an R1 or gen 2 top yokes (100 -125 quid) bottom yoke from any R1?? (50 quid) plus fitting a new stem and fitting together (est 180 quid) so about 350 quid and all the hassle as I dont have any good engineering contacts. I know Luke has just done Nick Crisp's bike, that looks good. Any info on what options and costs that was? Re: R1 Front End Cost Estimates - NorthWestern - 01-04-15 I did mine on the cheap but that was largely due to having a few parts at my disposal. I modified the stem by machining 11mm (IIRC) more threads on and cutting 11mm off the top - this avoids the problem of the top yoke being held higher resulting in you needing to run the forks further up the yokes lowering ride height. Machined the inserts for some R6 top yokes as you would with R1 ones ( essentially they are the same as R1 ones but only cost £25 ) and used a YZF750 bottom yoke which requires no modifications. I seem to remember having to do some grinding to get the steering lock to line up, this may not be required with the more popular R1 top yoke installation - and of course the strenthening work on the top yoke for the fork bolts... Modifying the stem like that means you only loose 11mm or so in front rideheight so it doesnt drop as much as a normal install (but still more than devilsyams solution with the extenders - I believe it sits 11mm lower than stock with my setup). This was with 4XV forks using the standard wheel, brakes etc. For this you would need R1/R6 top yoke, YZF750 bottom yoke, machining work for the std stem, top yoke spacers making and that is about it. Ah no, I almost forgot, the YZF750 bottom yokes are for 2mm larger diam forks so I made some inserts from 1mm alloy that line the holes, you can't see them and work a treat. It's still a fair amount of work, you certainly appreciate the cost that some ready to fit setups cost once your done. I put some pics up of my "fitment" on here somewhere. |
