Abba or eazyrizer lifts - any users - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Abba or eazyrizer lifts - any users (/showthread.php?tid=70526) Pages:
Re: Abba or eazyrizer lifts - any users - VNA - 10-10-14 My garage floor is not particularly flat, so it bounces about a bit as I move it, but basically I can stick it anywhere I want. With the bike fully raised, I could do some work on it in the middle of the garage, then stuff it in a corner and do something else. The strap on the swing arm is to lift it horizontally. Drop it down, take the strap off and remove the bar, lift again and it goes into the stoppie position. There's a second way to use the strap to get it into the wheelie position, but you can only do that if you have a swing arm bobbin. I might get a bobbin mount welded onto my swingarm when I next remove it. Lew, you can shake the bike about on it, as you would expect, considering it's only held via the swing arm mount. I did climb up and sit on the bike with it fully raised, which feels pretty weird as yeah it bounces about with you on it. Abba told me it's fine to climb up, sit on it and do some work up there! There is a bit of a knack to getting the bike hooked up. I think I've got a reasonable feel for it now. So yeah for general servicing, if you are running a bike shop, a table would be quicker. But if you are pulling bits off the bike, then one of these might be handy. For me it simply takes up less space. Everything is pretty solid and well made. A couple of things I didn't like, are the release screw on the 3 tonne jack and the pumping handle, both seem a bit feeble, the jack itself is seriously solid, and maybe I'm just being fussy. Anyway the bike is still in use. But hey, maybe this winter I might start pulling bits off it and carrying a half decent tidy up. Hopefully I'll get good use out of this. Happy with it so far. And oh, I should have washed the bike before I took the photos - sorry! Re: Abba or eazyrizer lifts - any users - VNA - 10-10-14 Oh if you want to take the swing arm out, there is a swing arm removal kit which I also have. Basically pop the foot peg mounts off. Pick the one closest to the swing arm pivot, screw in the adaptor and lift. At some point I'll give that a go. Re: Abba or eazyrizer lifts - any users - lew600fazer - 10-10-14 Basically it is an ABBA stand with a Hydraulic jack, do take care you do not scratch your frame. Can you fit / rig it on either the side stand or centre stand? Re: Abba or eazyrizer lifts - any users - VNA - 10-10-14 Don't think I'd scratch the frame with it Lew. I did have a few wobbly moments hooking the bike up. If you don't take care with it you could drop the bike trying to hook it up, but I think I have the hang of it now. It won't hook up off the centre stand. So basically you slide it in roughly with the bike on the side stand. Retract the side stand and manoeuvre the stand in closer and hook up. You need to raise the stand a little on the pump to hook up, but once I've determined the exact height for my bike I'm gonna put a mark on the stand so I won't need to faff about getting that height spot on. Then you pop the brakes on (an easy mistake to forget), walk round the other side and slip the bar on and slide into the swing arm mount (will be a doddle once I have the mark), tighten it up and bingo. Put the other bar and strap on (if raising horizontally), pump away, slip the pin in and take the pressure off the jack. That's it. There's good demos on their web site showing you how it's done. Re: Abba or eazyrizer lifts - any users - lew600fazer - 11-10-14 Hi VNA, reason I mentioned about scratching the frame was this muppet here scratched the frame on my SX. I was never that confident using my ABBA stand but expect if I had used more often I would have gained more confidence. As you say ABBA do make good kit, it is like everything the more you use it the more confident one will become. Good luck with but take care do not want you dropping your pride and joy. Lew :faz Re: Abba or eazyrizer lifts - any users - VNA - 11-10-14 Cheers Lew. I've splashed the cash so I've gotta get on with it! But seriously I think it's the right option for me. A table lift would have taken up so much more space, been possibly even more of a pain to get the bike onto (cos I can't take a run at it as you usually would with a table lift) and you still have to lift the bike up from the table if you want to pull certain bits off. I can see why table list make sense, but this also makes sense. As long as the kit is robust reliable it should do me fine. Time, as they say, will tell. Re: Abba or eazyrizer lifts - any users - VNA - 12-10-14 Cheers Lew. Confident but not complacent - I hope! One more snap; ![]() Re: Abba or eazyrizer lifts - any users - locksmith - 17-10-14 Well you inspired me to get an Abba superbike stand. What a great piece of kit, used it last night to change my shock and the bike sits solid. I've invested in the addition for raising the front so next week the forks are coming off for an upgrade with no dodgy jacks/blocks of wood/ropes supporting the bike! Re: Abba or eazyrizer lifts - any users - fireblake - 17-10-14 (04-10-14, 01:15 PM)robin78842 link Wrote:I think a full bench is better with both wheels on the bench. You can jack it up as you would on the floor, both ends if you want. and it's more stable. I think I need to go to Robins place next time I work on my bike? Re: Abba or eazyrizer lifts - any users - VNA - 17-10-14 Quote:Well you inspired me to get an Abba superbike stand. Nice! I think preping the bike for the summer back in march made my mind up. I could hardly move after a day faffing aboot wi the bike. I just had to get something that allows me to stand or sit for most jobs. Re: Abba or eazyrizer lifts - any users - locksmith - 18-10-14 I cant believe how easy it is to use, theres so little contact with the bike yet once in place you can jump up and down on it ! The most common thing I see people saying about not buying one is that it uses the swing arm bolts so you cant use it to remove the swingarm. Well, they do a swing arm removal kit for it as well
Re: Abba or eazyrizer lifts - any users - chris.biker - 18-10-14 Just thinking over the whole concept and the last comment it occured to me that once you have this lift there is nothing to stop you making a ridged table workbench that the lift could roll up to and place the bike on for the few occasions a bench would be better. Re: Abba or eazyrizer lifts - any users - red98 - 26-10-14 (18-10-14, 05:36 PM)chris.biker link Wrote: Just thinking over the whole concept and the last comment it occured to me that once you have this lift there is nothing to stop you making a ridged table workbench that the lift could roll up to and place the bike on for the few occasions a bench would be better. thats what ive been thinking...I made a bench with castors when I restored my honda 400/4, using a long scaffold board to load.i have to empty the garage to make enough room though, too many projects :rolleyes....this lift would make it easy.....spotted a eazy rizer at the stafford show last week..similar thing but lifts from the wheels using a screw lift... Re: Abba or eazyrizer lifts - any users - chris.biker - 26-10-14 Red I wonder if you could replaced the screw with a car jack either the single leg type or a scissor jack? Re: Abba or eazyrizer lifts - any users - red98 - 26-10-14 Ah yes, some of the ramp type us a small car trolley jack, dont think the single leg or the scissor jacks would have enough lift..SLIMWILLY has made his own using a quick lift jack , the type off roaders use, he'll be along shortly with a picture........
