Gen 2 intermittent starting. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gen 2 intermittent starting. (/showthread.php?tid=70190) |
Re: Gen 2 intermittent starting. - slimwilly - 07-09-14 You could while you are in there look to see if the secondry flies have been trimmed. [smg id=2117 type=preview align=center caption="airbox 1"] [smg id=2118 type=preview align=center caption="airbox 2"] Re: Gen 2 intermittent starting. - noggythenog - 07-09-14 Cheers Bill Yep ill defo be cutting out the snorkel. Blocking the AIS im not too fussed about as i dont really mind the popping noise......unless it is detrimental to the bike that is?. & the flies look full size......again i could cut them down or tie them open but im not sure if the bike would then need a power commander which i cant really afford. First things first.....find someone with a dremel multi tool. Re: Gen 2 intermittent starting. - slimwilly - 07-09-14 Oh, i thought it had a power commander, never mind keep it shiny side up. We ought to get doing some drag sting testing soon, you and i,,
Re: Gen 2 intermittent starting. - noggythenog - 07-09-14 (07-09-14, 11:01 AM)slimwilly link Wrote: Oh, i thought it had a power commander, never mind keep it shiny side up. My mass keeps my wheels on the ground. Bloody quick bikes Re: Gen 2 intermittent starting. - stevierst - 07-09-14 Yeah, you need a PC or juicebox if you start playing with the secondary flies. Makes a substantial difference with the right map though. Re: Gen 2 intermittent starting. - slimwilly - 07-09-14 If you enjoy acceleration and ease of passing then there is the best mod,,,cheapest except the air box one that is do the 16 tooth front srocket,,about £16 on ebay,,it puts it the same as the Gen 1s then,16 tooth.The rear wheel slides back a touch to take the chain slack. If you are not doing long motorway rides etc then it is a nice nice mod, hard to explain the difference but it alters the whole characteristics of all the gears. The speedo will read slightly faster than you are doing, but not much,1.e 5% over plus they are already 5% over so 10%is more real. On the list of mods for this model the great Ivan puts the 16 tooth on the must do list. and he knows best :lol Re: Gen 2 intermittent starting. - stevierst - 07-09-14 The 16t increases fuel consumption slightly though, and 105-110 miles before the light on a spirited ride. The Ivans reflash is supposed to be the daddy of the mods, bringing the humble FZ up to R1 power throughout the rev range Re: Gen 2 intermittent starting. - noggythenog - 12-09-14 Got the new battery on today and i said to my missus.....i bet it doesnt start.....right enough.....it didnt. Same old problem but i've at least swapped out the most obvious and im happy to k ow that i have a fresh battery as of now. It is really random.......it started on the 3rd try....turned off then restarted straight away...& i third time......then didnt start on the 4th.......waited a while.....back out....started first time. An important thing to note is this - it isn't how many times i press the starter button......when it does it i could press the starter 100 times and it wont start.........it is how many times i switch off and back on the ignition.....then it can start at the first press of the button straight away. So it looks like i've got a long road ahead of diagnostics .I did have a bit of trouble with the ignition a while back whereby the key wouldn't turn sometimes which i cured with some graphite spray. Also i am completely alarmed by those loose and snipped wires on the front end......it's as if someone has taken a snipper to everything.....but why......it screams bodge job.......take a look......why on earth would you do something like that & how the foc is the bike still running. Back to work now for a while but on my next days off ill go out for a spin at least and test out the new K&N and AIS mods.....once it is running it is fine and an absolute rocket. Then i can seriously see me putting it into a garage to diagnose as i dont do wiring....especially not spaghetti junction wiring. Re: Gen 2 intermittent starting. - woodwizzard - 12-09-14 Have you followed those wires back to anything? They look like add-ons and seperate to the main wiring system, so should be able to follow them back. Might be worth trying another ignition barrel by the sounds of it. Re: Gen 2 intermittent starting. - noggythenog - 12-09-14 (12-09-14, 06:44 PM)woodwizzard link Wrote: Have you followed those wires back to anything? They look like add-ons and seperate to the main wiring system, so should be able to follow them back. Might be worth trying another ignition barrel by the sounds of it. Not in great depth buddy...i know a couple are for the heated grips and ill be getting a garage to properly uninstall them at some point as they are just another thing to go wrong that i dont need...plus ive heard some bad stories about heated grips acting up. The coax wire appears to go back to the battery and also into this thing which appears to be an inline fuse. & i can hear an electrical click when im turning the bike over which appears to be coming from the small black box in the top right passed the battery......not sure what's in there and whether it is supposed to click anyway???? Re: Gen 2 intermittent starting. - slimwilly - 12-09-14 Oh dear, it sure is a twat when these things play up. i guess if it was dodgy wiring then the fault would be all the time, even when riding,,but if you have no problem when riding then its not them. So its the ignition,starting sequence,,thats where the problem is,,so concentrate there :\ Re: Gen 2 intermittent starting. - noggythenog - 12-09-14 (12-09-14, 08:31 PM)slimwilly link Wrote: Oh dear, it sure is a twat when these things play up. First thing im doing next days off is going for a bloody good spin though.......whats the worst that could happen with dodgy starting :\ .... :lol Then it looks like ill be going through to ys fault code thingy which will hopefully throw something up to look at. Re: Gen 2 intermittent starting. - unfazed - 12-09-14 Noggy, have not been on here with almost a month, did not realise you were having nuisance issue. Since it turns over it really rules out the clutch,side stand and kill switches. Sounds like a mild corrosion issue, I would lift the tank and check the crank sensor connections. You do not need to be an electrical genius to disconnect a plug and spray it with contact cleaner or WD40 and put it back together again. Follow this procedure, take connector apart check it, spray it put it back together, take it apart again and put it back together again, then and only then move on to the next connector. This fixes 75% of electrical faults I have come across on bikes. Time consuming, slow and tedious, but often well worth the trouble. The service manual is good as it shows where all the items are. Re: Gen 2 intermittent starting. - noggythenog - 12-09-14 (12-09-14, 09:31 PM)unfazed link Wrote: Noggy, have not been on here with almost a month, did not realise you were having nuisance issue. Good to have you back Unfazed 8) .....& i've seen you diagnose a fair few electrical demons on here so i'll go with that........ill try the diagnostics on the dash first and see what they come up with (if anything) & then ill attack the connectors......i was in a rush to get everything back together yesterday and wanted to try the new battery so i just sprayed ACF50 on everything but when i get more time i'll systematically open up each connector......it has been said previously so i really need to take the time to do it......plus if any others are close to becoming troublesome i might just nip them in the bud before they start. I am confident. Cheers! Re: Gen 2 intermittent starting. - slimwilly - 12-09-14 Oh mr Noggy, i will buy a rope and come and tow you around, :lol it would be criminal if i did not meet up with you this year :o Re: Gen 2 intermittent starting. - noggythenog - 12-09-14 (12-09-14, 10:05 PM)slimwilly link Wrote: Oh mr Noggy, i will buy a rope and come and tow you around, :lol Ill be out again......but once i start i cant stop so that's 150 miles of fun before i put on my face of shame outside a biker caf with the bling bike struggling to start & passers by spitting on me like the piece of dirt that i am. :b Re: Gen 2 intermittent starting. - pilgo - 13-09-14 (12-09-14, 10:09 PM)noggythenog link Wrote: [quote author=slimwilly link=topic=14590.msg166177#msg166177 date=1410555958] Ill be out again......but once i start i cant stop so that's 150 miles of fun before i put on my face of shame outside a biker caf with the bling bike struggling to start & passers by spitting on me like the piece of dirt that i am. :b [/quote] you told me NEVER to mention this happening outside the cafe at Llandovery, glad you have found the strength to confess it now !! :lol hope you get it sorted soon mr noggy :thumbup Re: Gen 2 intermittent starting. - noggythenog - 13-09-14 (13-09-14, 05:52 PM)pilgo link Wrote: [quote author=noggythenog link=topic=14590.msg166182#msg166182 date=1410556181] Ill be out again......but once i start i cant stop so that's 150 miles of fun before i put on my face of shame outside a biker caf with the bling bike struggling to start & passers by spitting on me like the piece of dirt that i am. :b [/quote] you told me NEVER to mention this happening outside the cafe at Llandovery, glad you have found the strength to confess it now !! :lol hope you get it sorted soon mr noggy :thumbup [/quote] Ha ha.....i'm worthless mate! It's like one of those vehicles in an american film that wont start at the most dangerous time & you think nah that'd never happen....my bike's got whatever they have......i just need to remember to stop over railway lines etc. :lol Re: Gen 2 intermittent starting. - noggythenog - 14-09-14 I'm gonna try the self diagnostic tool on the speedo tonight but I've got thinking about what stuff has gone on recently and I did have all that hassle when I broke down due to the loose bolt on my rear set for the gear linkage....I since then ratcheted up a spare bolt and I'm now thinking that during my last run I had a brief issue at one of the times I stopped where the linkage was jumping about a bit and I was having a bit of trouble trying to select Neutral etc. Now just a thought for picking your brains but.....ok I've already discounted the side stand switch and it not being in Neutral or the kill switch etc during start up because then it wouldn't turn over whatsoever...and it always turns over.... but could it be teetering on the edge of gears and causing this issue.....or would it be a straight forward it either is in Neutral or it isn't type scenario....and just not turn over? I'm not with the bike right now but would holding in the Clutch while starting it up negate that....I cant remember now whether the bike will start if say I'm in first gear with the Clutch held in....I think it will....it's just another theory I've got to try diagnose that I could always put it in 1st gear and then hold in the Clutch....if I got half a dozen good starts then that would indicate the problem to me.... but is it a sound theory or an absolute piece of nonsense? Re: Gen 2 intermittent starting. - noggythenog - 14-09-14 (06-09-14, 07:47 PM)tony_d123 link Wrote: [size=1em]Not sure if it's any use in your case as you don't seem to get any error codes, but just wondered whether you can run a diagnostic check to see any historic error codes? copied from the US Fazer forum:-[/size] Thanks for this Tony, top man. I've just done the test and i get D01 16.................so according to that list above then i have the Throttle position sensor (Stuck) code...is that right?..does it sound like a likely culprit based on my symptoms?......but i'm lost as to the whole throttle thing.....as i hold in the buttons and the fault code D01 16 is displayed and then i slowly twist the throttle then it goes from this 16 all the way up to 96 and then back down to 16 as i throttle off......but i really don't know the relevance of this part? Is this code pretty reliable or is it common to get this code with mods or for other faults to wrongly present this code? If it is the TPS then i know where it is as i noticed it under the tank the other day but from there on i'm stumped again......i also know that above the TPS is a little revolving nut that clicks around (i accidentally knocked it a notch and then back again) anyone know what it is? So many questions......such a small brain
