K&N Air Filter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: K&N Air Filter (/showthread.php?tid=70060) Pages:
Re: K&N Air Filter - rodrigojds - 26-09-14 I bought a K&N air filter last week and I've noticed a few things. The very first thing I noticed was that the idle RPM's are lower now than before. Previously I would start it up and the RPM's would go to around 1.25 K and now I start it up and it goes to less than 1K. But after a while it goes to 1.25 K so I'm guessing it's not an issue. Another (very) positive thing is that the RPM's easily go to + 12K and before it would rarely pass 8K. Also the sound the bike makes when I accelerate is louder! ![]() Even though it was expensive I'm happy that I bought it. Re: K&N Air Filter - darrsi - 26-09-14 (26-09-14, 11:49 AM)rodrigojds link Wrote: I bought a K&N air filter last week and I've noticed a few things. It'll be the last one you buy for the bike so it wasn't really expensive! And it's worth it just for the general better feeling of the bike anyway. Re: K&N Air Filter - clayt74 - 26-09-14 With standard air filter mine ticks over between 1.6-1.8k which I thought was the norm? Rev wise easily over 12k all the time!! Still wanna fit a k&n tho Re: K&N Air Filter - BBROWN1664 - 26-09-14 The FZS runs slightly rich from the factory. No need to change the carb jets when adding either a K&N or a different end can. Just reset the TPS and balance the carbs properly to fully enjoy the (slight) increase in performance. The most apparent difference I found was in the mid-range where it just smoothed everything out nicely. Re: K&N Air Filter - clayt74 - 26-09-14 I've got a set of carb gauges but haven't used them yet, is setting the tps just using the rpm meter to show it's in range? Re: K&N Air Filter - positron - 26-09-14 I have sandybikespares stainless steel pipes with standard exhaust, and I had some issues with bike not revving past 7k or so (there's a thread here about it), and ended up replacing what appeared to be an ancient air filter with a K&N. No other changes. Bike now has more power than I ever wanted. It pulls away like a train and by around 10k the power is still coming on strong that discs in my dodgy lower back starts to protest from the sheer force of the meat-sack that I am getting pushed harder and harder against the seat. Re: K&N Air Filter - darrsi - 26-09-14 (26-09-14, 03:56 PM)clayt74 link Wrote: With standard air filter mine ticks over between 1.6-1.8k which I thought was the norm? Rev wise easily over 12k all the time!! Still wanna fit a k&n tho Doesn't really need to be that high, around 1250rpm is average. TPS should be set on the 5000rpm mark, plenty of info on here mate. Re: K&N Air Filter - MC680x0 - 26-09-14 (26-09-14, 04:24 PM)clayt74 link Wrote: I've got a set of carb gauges but haven't used them yet, is setting the tps just using the rpm meter to show it's in range?you set the tps so it reads centre (think its 3k but I could be wrong - there is a shop manual in the downloads section on this forum, tells you in there about setting TPS); the rpm needle moves up/below 3k [whatever] to tell you whether to rotate the TPS clockwise or anticlockwise. Re: K&N Air Filter - bandit - 26-09-14 Yes clayt74 5000rpm on meter is correct.
Re: K&N Air Filter - darrsi - 26-09-14 (26-09-14, 06:20 PM)tweetytek link Wrote: [quote author=clayt74 link=topic=14460.msg168135#msg168135 date=1411745069]you set the tps so it reads centre (think its 3k but I could be wrong - there is a shop manual in the downloads section on this forum, tells you in there about setting TPS); the rpm needle moves up/below 3k [whatever] to tell you whether to rotate the TPS clockwise or anticlockwise. [/quote] Seriously, why would you bother writing that if you don't actually know what you're talking about? :rolleyes Re: K&N Air Filter - darrsi - 26-09-14 Instructions on TPS check on here: http://foc-u.co.uk/index.php/topic,9111.msg91005.html#msg91005 |
