Rough Idle - with video - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rough Idle - with video (/showthread.php?tid=68601) Pages:
Re: Rough Idle - with video - fazersharp - 08-05-14 Sounds fine but looks like 1100- turn up to 1250/1300. I went to view a street triple and that ticks over at about 3x ours. Does anyone know of a bike that has such low idle as our std spec does Re: Rough Idle - with video - His Dudeness - 08-05-14 think most bikes idle around 1200RPM Re: Rough Idle - with video - GosportFazer - 08-05-14 Fazersharp - I admire your enthuasiasm, but the bike was idling in the vid, around 1250rpm. And as already pointed out, wasn't fully warmed up. After a 30 minute ride it idles at about 1350 - 1400. I have ordered a new air filter and oil filter and will give it a service once they arrive, if the plug caps dont cure it - I'll get the carbs off in my week off. Will keep this thread updated with any changes. Re: Rough Idle - with video - fazersharp - 08-05-14 Ill shut up then Im still saying it sounds fine--- or at least sounds the same as mine, Re: Rough Idle - with video - GosportFazer - 08-05-14 Haha, I appreciate everyones input, its just I have tried upping the idle speed before. I hope it is a solvable stutter. Re: Rough Idle - with video - darrsi - 08-05-14 (08-05-14, 01:26 PM)GosportFazer link Wrote: Haha, I appreciate everyones input, its just I have tried upping the idle speed before. I hope it is a solvable stutter. Did someone say "stutter"? :lol Re: Rough Idle - with video - johna6968 - 08-05-14 (07-05-14, 10:41 PM)His Dudeness link Wrote: [quote author=johna6968 link=topic=12996.msg146998#msg146998 date=1399478341] I've had my bowls off probably 4 or 5 times and they're still fine [/quote] I did say "can" and not "will"
Re: Rough Idle - with video - GosportFazer - 11-05-14 Quick Update: Plug caps arrived and fitted - made no difference Also received my infra red temp gun - fantastic little toy! and indeed £8 At idle from cold it seems after 5/10 minutes that the cylinders are about 160 degrees or so at header, apart from no4 which is around 200 degrees. I haven't had time to play with the mixture on 4 to see if it would bring it into line with the rest, but I also wonder at this stage whether a partially blocked idle jet would lean it out and cause the discrepancy. Gives me something to play with on my week off anyway. |
