Speedo Sensor Needed - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo Sensor Needed (/showthread.php?tid=67549) |
Re: Speedo Sensor Needed - Timbollew - 11-03-14 (10-03-14, 10:18 AM)Dead Eye link Wrote: I had to replace mine a few years ago and ended up finding someone breaking a 600 and getting them to send me the unit. Ended up costing £25 inc p&p - I'd recommend this route as buying new is insanely expensive as you have found outYeah I've been in touch with a few breakers but still not had any luck finding one. When you had to change yours DeadEye were your symptoms similar to mine? Anyone have any recommendations of breakers? Re: Speedo Sensor Needed - Dead Eye - 11-03-14 Nah, mine was just completely dead and wouldn't read anything - I just got the 3k tacho needle error code. The lugs were fine and the new unit fixed the fault Re: Speedo Sensor Needed - red98 - 11-03-14 The speedo sensor....I take as the bit that fits over the drive dog......if yes I have one for sale
Re: Speedo Sensor Needed - Timbollew - 11-03-14 Hey red, yeah the part that goes from the wheel to underneath the tank. Is what I'm looking for. You'd be a life saver. If it is that part you've got let me know and I'll pm you. Tom. Re: Speedo Sensor Needed - red98 - 11-03-14 there you go.....this belongs to christoT pm him for a price and a bit for me for postage unless you can collect in person Re: Speedo Sensor Needed - Timbollew - 12-03-14 That's the badger. I'll message him now. Where do u live red? I'm in South Wales. Re: Speedo Sensor Needed - red98 - 16-03-14 small rub on wire.through to metal but not broken.should still work. Re: Speedo Sensor Needed - Dead Eye - 16-03-14 This is what insulation or self-amalgamating tap were designed for ^^ Re: Speedo Sensor Needed - red98 - 16-03-14 Yes indeed mr dead......just dont want to hide any nasties when selling to a fellow foccer ......anyway.its a fab day why you not out on the mighty thou ?
Re: Speedo Sensor Needed - Dead Eye - 16-03-14 Just giving piece of mind ^^ I was just out on the thou, had just finished breakfast before I posted that message haha Re: Speedo Sensor Needed - Timbollew - 22-03-14 So I just got the part from Red and Christo (cheers both) and I'm gonna stick it on and see if this resolves my problem. Quick question for you guys though, what would you use to lubricate the drive dog and sensor? I was going to pack a little multi-purpose geese in there, what do you think? Re: Speedo Sensor Needed - noggythenog - 22-03-14 (22-03-14, 03:30 PM)Timbollew link Wrote: So I just got the part from Red and Christo (cheers both) and I'm gonna stick it on and see if this resolves my problem. Quick question for you guys though, what would you use to lubricate the drive dog and sensor? I was going to pack a little multi-purpose geese in there, what do you think? I hope Lithium grease is ok coz that's what i stuck on...i didnt pack it though...the dog needs to spin, i just went lightly over it with my finger & inside the rim & over the gasket type part on the face. I also smeared it around the wheel bearings & over the centre pin for the wheel. & i used copper slip on all the high heat areas on the caliper bolts & brake hose bolts. Re: Speedo Sensor Needed - Timbollew - 22-03-14 It's alive! Fitted the part and all working, just used multi purpose in the end. Wasn't as easy as it should've been though. Checked the sensor and was working fine, because of the little rub through on the "new" sensor wire I opted to cut the wire at the top heat shrink where it had rubbed and then resolder at the top. This was all a piece of cake. Greased everything and pushing the axle through and it just wouldn't go in, checked and the axle wouldn't fit through the sensor which is odd but hey ho. So I ended up using the dremel to sand the inside collar of the sensor just enough to get the axle through. Just took it for a test and all is good my plan was to change the oil and filter today too but that'll have to wait until tomorrow now.When I had a look at the old sensor the only thing I could see was down the bottom where the wire attached to the sensor the wire insulation had pulled up and away exposing the wires (not bare wires) and I guess moisture got in there and focced it up. It started with the speedo giving odd readings, reacting to other electrics like indicators and then just died. Just thought I'd recap incase anyone has a similar problem. Thanks again to all you guys on here helpin me source a part and advice along the way
Re: Speedo Sensor Needed - red98 - 23-03-14 glad you got it sorted ....strange about the axle ............
Re: Speedo Sensor Needed - Gazbo - 07-04-14 Hia lads. Screendumped the yam part for the numbers. Pagetts fitted my new front tyre about a fortnight ago. When he pulled the wheel out, bits of dog fell out all over the floor ! (Wasn't his fault - it has been squeeling like a pig for a while) Could only rescue a single tang, and he superglued it back on, and warned me these things are an arm and a leg to buy!(I assume he's talking about the whole unit - of which the rest of mine is fine)so my questions are - how much is it for just that bit? where to buy without getting my pants pulled down over the price, and is it easy enough to swap out for the old one?Circlip? push fit? wifes Y fronts elastic? what? I didn't want to touch mine whilst his superglue was holding - until halfway home tonight. Speedo flicked a couple of times, and dropped dead. I reckon the previously superglued (Single) tang finally gave up the ghost. MOT on the 21 st (sods law!) so need to act fast - cos he does check it on the rolling road thing...... Regards - Gazbo Re: Speedo Sensor Needed - noggythenog - 07-04-14 (07-04-14, 10:28 PM)Gazbo link Wrote: Hia lads. Hey gazbo, i see you are new so you prob havent quite got to grips with navigating the site yet, welcome......it is attack of the speedo sensors at the mo...like last year when everyone kept crashing their 600's :evil ..... Anyway someone else asked this morning & i gave them the earlier link. Just click on this link to another thread on the topic http://foc-u.co.uk/index.php/topic,12498.0.html Re: Speedo Sensor Needed - Timbollew - 08-04-14 The drive is £16ish from Main dealer. The sensor and drive is about £130. From what you've said it's only the drive you need and there a pice of pee to fit. Calipers off, pinch bolts loose, axle out, grease, fit drive and reverse.
Re: Speedo Sensor Needed - Gazbo - 09-04-14 Cheers Lads. Bought the dog.Just waiting for it landing now. Maybe here tonight. Q. So how is it held into the unit then? Circlip maybe? I only ask cos I'm really limited for time, and am using the bike for work, so it's going to be an sas job (Quick out-quick in) Can't afford to be off t' road at all. MOT due on 18th, so will want to do the swap before then (Yes he does check it on the rolling road when he tests me anchors- which are also up for some pre MOT bleeding - incidentally) I didn't get a good look at the knackered dog when they were doing me nu tyre, so was just unsure how to strip the old dog out of it's housing- thats all. (I'm an engineer, so am ok with competency etc. Got all the tackle,Just haven't attacked this particular job before, and don't wanna screw the pooch (Dog) if ya follows....) PS. I do know about getting it back into the wheel right ! That's a given. It wasnt me wot dun it wrong lasdt time, as I'd never had the wheel out. One bonus came out of all this though.....I thought the squeeking sound was me wheel bearings. It was obviously the loose dog's lugs rubbing round inside the unit. Padgetts Superglue job had given me about a weeks running though, but I wasn't counting on it. Rightly so - apparently. Thanks again for the help. Nice to know you're there lads. Gazbo Re: Speedo Sensor Needed - Timbollew - 09-04-14 Probably take you about 15 mins mate. It's simple, nothing holds it place, when you see the sensor it'll make sense, but on the near side of the front wheel the dog will slide into the sensor unit collar first with the lugs facing out (put a little grease on it) then line the lugs up with the wheel, a well placed foot to hold the front wheel in place while you slide the axle through and tighten up. Simples. Re: Speedo Sensor Needed - Gazbo - 09-04-14 :rolleyes O wow ! embarrassing that. Must be my engineering background - fully expecting all moving parts to be "Physically retained" ! (Although now I've eyeballed it - well yes - where was it going to go anyway ? :rollin Anyway - Got home this teatime. Biggest pizza box I've seen since I waz propper greedy, with the little Dog hiding in the corner. Looks totally different to the original, with it's nice Dalek - like slots around it.(T'other was just smooth - bore). You were right. Propper "lump of urine " to do. I bet I was 5 mins to pitstop it out & new one in. Took longer to get the Arse end strapped down ! Now nicely GP greased, tangs correctly located (After a bit of a faff about). Back up and running. I even tightened my downpipes to stop the "engine is trying to destroy itself " sound, caused by a wayward gasket in No. 3 port, flapping in the draught('Speshly on tick over). Amazing how the downpipes amplify this fluttering noise. My mechanic mate diagnosed " soon to give birth to con-rod "! So that's done too -nice and quiet again. And all before er-indoors shouted " Oy - fatso - Tea's ready. Paid a bit extra. F.Y.I. AJ Suttons (via fleabay) had it for 25 spondooliks, and DPD delivery. so I bit the bullet, rather than muck about. Sorted ! Thanks again all. I'll be back.
