Hesitation, surging and crap mpg. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Hesitation, surging and crap mpg. (/showthread.php?tid=65624) |
Re: Hesitation, surging and crap mpg. - Lawrence - 24-09-13 That's why I bought them, they were recommended on here. Haynes says the resistance of the caps should be 10Kohm, those are 5. Swapping them back (and that's the only change that was made) had a huge impact on how it ran. Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 That's very interesting!!! I wonder if that might be a reason why my bike's slightly unhappy around the 3000rpm mark at lower speeds? I've always blamed the short end can! :look Gonna have to see if i've still got the originals to try, 'cos i'm certainly not gonna pay £52 each for new ones? :eek Re: Hesitation, surging and crap mpg. - Lawrence - 24-09-13 Sod £200 for a set, that's not far off what my bikes worth :rollin I'm sure NGK will have something suitable, just a case of finding the right one. Re: Hesitation, surging and crap mpg. - Fazerider - 24-09-13 As Darssi says, lots of us are using the NGK plug caps. There is nothing wrong with having a 5k ohm resistor instead of 10k, the thing's only there to stop radio frequency interference and the value is not critical. If those caps really are causing the problem it'll be due to breakdown of the insulation i.e a faulty one... or tracking due to dirt/moisture... or not having a good connection to the plug or ht cable. The value of the suppression resistor being 5k rather than 10 is not the problem. Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 I never knew it was all so complex, i just thought caps were caps? Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 I would've thought that there'd be loads of people complaining of issues if it was the NGK caps? Re: Hesitation, surging and crap mpg. - Lawrence - 24-09-13 I'll give them another go then, but that's definitely the only thing that was changed. All the HT leads were secure in the caps and the I didn't trim them when I put the standard caps back on. This needs more investigation, I'll check it out more at the weekend
Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 So, in theory from what you're saying, according to this NGK chart we "should" need SD10F caps, but they don't actually exist so i can't see it being too much of an issue, although it's interesting what the Haynes manual says. Saying that, electrics and me don't get on too well. :thumbdown http://www.ngksparkplugs.com/docs/resistor_covers.pdf Re: Hesitation, surging and crap mpg. - Lawrence - 24-09-13 From a quick read, using 5k caps instead of the standard 10k will mean that the coil discharges quicker, giving you a stronger spark that doesn't last as long. It might be that the shorter spark, coupled with whatever else is wrong with it, is making it run like a bag of shite. If I can sort out the other thing (carbs possibly) then the 5k caps might work a treat... http://www.ultralightnews.ca/articles/resistorcapsandplugs.htm http://forums.sohc4.net/index.php?topic=67096.0 Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 All i got was "Use these as replacements for superior performance on your bike." That'll do for me :lol Re: Hesitation, surging and crap mpg. - dBfazer600 - 24-09-13 (24-09-13, 07:19 PM)darrsi link Wrote: [quote author=Lawrence link=topic=10010.msg103678#msg103678 date=1380045783] Loads of us have got them, including me? [/quote] This includes me and I have been having problems with a stuttering :faz I may just get out the old uns and see what happens. Daz Re: Hesitation, surging and crap mpg. - darrsi - 24-09-13 (24-09-13, 08:08 PM)dBfazer600 link Wrote: [quote author=darrsi link=topic=10010.msg103687#msg103687 date=1380046776] Loads of us have got them, including me? [/quote] This includes me and I have been having problems with a stuttering :faz I may just get out the old uns and see what happens. Daz [/quote] Won't hurt to try i s'pose, it's not exactly a major is it?
Re: Hesitation, surging and crap mpg. - Frosties - 25-09-13 (24-09-13, 07:39 PM)Fazerider link Wrote: As Darssi says, lots of us are using the NGK plug caps. There is nothing wrong with having a 5k ohm resistor instead of 10k, the thing's only there to stop radio frequency interference and the value is not critical. If those caps really are causing the problem it'll be due to breakdown of the insulation i.e a faulty one... or tracking due to dirt/moisture... or not having a good connection to the plug or ht cable. The value of the suppression resistor being 5k rather than 10 is not the problem. Well said fella! Re: Hesitation, surging and crap mpg. - Ebme Geek - 25-09-13 +1 Re: Hesitation, surging and crap mpg. - Lawrence - 25-09-13 It was running far better this morning than yesterday. Still has the hesitation that it always had, but the really shit running has gone. When I service it at the weekend I'll stick the NGK caps back on and try it again. Re: Hesitation, surging and crap mpg. - Lawrence - 05-10-13 Just done a service (oil + filter, air filter, fuel filter, plugs, front sprocket, coolant) and it's running exactly the same as before but now it sounds weird :rolleyes Sounds a bit like an Impreza, although it goes just the same as before which is odd. I'll leave it for a bit as it might've been me spilling something in the electrics...I cleaned the carbs out too, is there anything I should've done after to prime them? I just flicked the ignition off/on a few times to run the pump. Re: Hesitation, surging and crap mpg. - Fazerider - 06-10-13 (05-10-13, 05:40 PM)Lawrence link Wrote: Just done a service (oil + filter, air filter, fuel filter, plugs, front sprocket, coolant) and it's running exactly the same as before but now it sounds weird :rolleyesRunning the pump is all it needs, though as you noticed it does cut off if it doesn't detect the pressure rising after clicking for a few seconds. Are cylinders 3 and 4 still running cooler? Re: Hesitation, surging and crap mpg. - Lawrence - 06-10-13 Yeah I had to do it a few times until it got to the usual point of slowing right down as the pressure builds up, like it does if you leave it off overnight. Not sure, I only went for a quick run down the road and back. Next time I take it out I'll check. Re: Hesitation, surging and crap mpg. - Lawrence - 11-10-13 Turns out that in first/second gear when I gave it some welly it was ok. In higher gears it ran like a sack of shite. Was on the way home and planning on taking the carbs out again to check them out (it wasn't getting (enough) fuel to #4, sparking but header was ~50C when the others were ~150C) and 10 minutes before I got home it suddenly cleared and went back to normal. So to summarise, it still hesitates like before but at least I haven't made it worse
Re: Hesitation, surging and crap mpg. - darrsi - 12-10-13 Just had a read of this and the fella explains very well how carbs work, it's worth a look. http://au.answers.yahoo.com/question/index?qid=20071102043029AAd5QCo |
