Sound at front end under braking/deceleration - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Sound at front end under braking/deceleration (/showthread.php?tid=64974) Pages:
Re: Sound at front end under braking/deceleration - TonyW - 15-08-13 Check for seized or broken bobbins on the disc. If they're seized clean them with brake cleaner and spin them (gently) with a nut and bolt. Re: Sound at front end under braking/deceleration - unfazed - 15-08-13 Do you have clip on wheel weights? It can casue exactly what you describe if they are loose in their holder or the clip is not tight enough Re: Sound at front end under braking/deceleration - Paul - 16-08-13 To Tony W Do you mean the rivet type things that hold the two parts of the disc together? Re: Sound at front end under braking/deceleration - darrsi - 16-08-13 (16-08-13, 10:03 AM)Paul link Wrote: To Tony W Yeah, to be honest it's highly unlikely to be the cause of mickvp's problem, but it doesn't hurt to give them a clean up occasionally. Get the largest size bolt that fits through the holes (if your rivets have holes) then put a nut on the other end and gently do it up with a ring spanner. It will eventually bite enough to spin the rivet disc. They get dirt in them after a while, so whilst turning the nut you can either use just soapy water or brake cleaner on them and you'll see the crap come out. Don't use anything oily like WD40 'cos you don't want it on your pads, calipers, discs, etc. Re: Sound at front end under braking/deceleration - Paul - 16-08-13 You learn something every day Thanks Re: Sound at front end under braking/deceleration - mickvp - 16-08-13 (12-08-13, 10:30 AM)Paul link Wrote: I got the front wheel off the floor and spun it several times. Just been out and got my front wheel in the air and spun it a few times (before the rain started). my pads are touching the disk slightly and "catching" a touch, but there no clicking noise to be heard by hand. I have however noticed that the brakes seem to bind slightly less at one point on the disk, but its not bad. I think ill bring a DTI home from work and just make sure they are not too warped, but im confident thats not the issue for me. (13-08-13, 10:41 PM)neil2do link Wrote: hi interesting. Is there a way I can "slacken" the caliper off a bit so its not binding a bit like it is now. theres not much in it but I dont think it should be dragging like it is now? (although this is not the clicking noise i dont think, but still needs addressing I would have thought). (12-08-13, 10:57 AM)Paul link Wrote: I think I may have a possibly answer. Nope. not that for me. slight (and i do mean slight) disk warpage side to side, but they are very concentric, under 1mm anyway, so I dont have that issue you have noticed. (15-08-13, 07:23 PM)TonyW link Wrote: Check for seized or broken bobbins on the disc. If they're seized clean them with brake cleaner and spin them (gently) with a nut and bolt. I dont think any are broken, but I cant see any holes in mine either - are the foxeye ones a different design maybe (see pic below)? (15-08-13, 07:57 PM)unfazed link Wrote: Do you have clip on wheel weights? yes, I do have a single clip on wheel weight on the front wheel, but it does seem tight, I certainly cant get any movement on it by hand at least. I have noticed 2 other issues while out looking there as well, im unsure what has caused the first issue on the tyre, but dont think it is causing the clacking, and the second issue is some scoring on the disk face which i suppose could potentially be causing it (as the score goes though the holes on the disk which would give an interrupted sound if theres a pressure point at that location? or is there no merit to that logic? Issue 1 - an odd score all the way round my front tyre (no idea where this came from at all to be honest), thoughts? Im thinking its where the dual composite meets, but its only on the one side - the nearside: ![]() Issue 2 - scoring round the disk on both sides (and on both disks but the nearside one definately seems worse): ![]()
Re: Sound at front end under braking/deceleration - mickvp - 16-08-13 someone suggested earlier to try filing a small 45Deg angle onto the pads - this may be worth a try given the scoring issue (or am I best to just chuck a new set of pads in?) Re: Sound at front end under braking/deceleration - darrsi - 16-08-13 (16-08-13, 03:16 PM)mickvp link Wrote: someone suggested earlier to try filing a small 45Deg angle onto the pads - this may be worth a try given the scoring issue (or am I best to just chuck a new set of pads in?) That looks quite heavily scored, i'm wondering if you've picked up a small stone at some point and braked on it. Just taking the edges off at 45 degrees helps the pads wear in a bit more gradually. Only a sand them down a bit, not all the way down. What pads are you using now, out of interest? Re: Sound at front end under braking/deceleration - mickvp - 17-08-13 im not sure what pads that are in actually. they have been in since I bought the bike. Re: Sound at front end under braking/deceleration - BluprintZ - 20-08-13 The scoring on the disc looks like the old pads have worn down to the metal at some point, before new ones were fitted (the previous owner?). The cut marks on the tyre look a bit odd at well, as though something is catching on it. When i removed the chain off mine last week, i noticed that one of the bolts holing the rear hugger on, was way too long and was about 3mm short of touching the rear sprocket bolts. Might be worth checking if something similar is happening to your front tyre? G ; ) Re: Sound at front end under braking/deceleration - mickvp - 20-08-13 Well I've ordered new pads now (thought it wise to just put a new set on so I know they are pukka), so ill get a good poke around while I do those when they arrive. Its strange because it doesn't always do it either, only sometimes. I think the mark on the Tyre may be age related, but that's just supposition. Either way ill be ordering new three this week too so can get a good look while the wheel is off
Re: Sound at front end under braking/deceleration - mickvp - 23-08-13 So, new pads arrived last night (ferrodo platinum - very good feeling pads). My god the pads that were in were glazed to hell. Still had a little life on them too (about 4mm), but for peace of mind I fitted the new ones. Took the bike a 10-15 mile ride to bed them in, and I've not heard the noise once since, so its either hiding from me or its pad related. Re: Sound at front end under braking/deceleration - mickvp - 11-09-13 still not cured this problem. pads are new and fine, new tyre is on, ive had the wheel off and the speedo drive is both greased and intact (and ive bought a spare as well just incase). the scoring on the wheels shown above though, is it possible they could be from the fender extender screws? those seem to be sticking out a bit further than i would like. (there is also some slight scuffing on the inside of the front mudguard,maybe the wheel is somehow touching it causing the noise?I dont really see how though?) Any thoughts? running out of ideas, and parts to change/lookat. worse still is the fact it doesnt happen at every junction, only occasionally (but consistently at the same junctions) Re: Sound at front end under braking/deceleration - andybesy - 11-09-13 Bearings? I had a clink sound on changing speed or direction, sporadic as you've described, although not rhythmic with road speed. Was diagnosed as wheel bearings and fixed with their replacement Andy Re: Sound at front end under braking/deceleration - mickvp - 11-09-13 Hmmm. Might be worth looking at aye. The noise is not the sort of noise I would expect from bearings though, and only happens at low speeds really (or wound noise drowns it out at high speed?) I've had it wound up to about 90mph and there's no wheel bearing whine though? Re: Sound at front end under braking/deceleration - darrsi - 11-09-13 If it is the bearings then it will only get worse as the weather gets wetter. Re: Sound at front end under braking/deceleration - Paul - 11-09-13 To Mick I've tested mine again. And It's intermittent, admittedly. But as far as I can tell it's down to uneven disc wear and the pads rocking on the central pivot, but only at low speed. But no loss of braking power..... at least as far as I can tell. Re: Sound at front end under braking/deceleration - mickvp - 11-09-13 ive changed my pads as well though, and no change in the noise whatsoever? you would think changing the pads would have at least altered the noise until they wore back into the disks? |
