Is this clutch basket a basket case - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Is this clutch basket a basket case (/showthread.php?tid=64451) Pages:
Re: Is this clutch basket a basket case - gra0411 - 15-07-13 Just seen the picture ( didn't show as I was posting reply ) and you were right it does look the same really confused now as dont want to remove clutch unless I have to Re: Is this clutch basket a basket case - CRH - 15-07-13 ...like ebme says if you could show a vid of it you would get some more input into whats going on?...but as regards the marks"...ive had a look at mine through the filler and cant see any on mine ?...also when running looks ok and true!!...there must be a clutch genius on here surely??...come on ..red 98 wheret art thou!!....even old" ade the blade"...must be lurking :b ....somewhere!!!!! Re: Is this clutch basket a basket case - Ebme Geek - 15-07-13 If there was no real vibes with the chain off and going up through the gears, I think you have your answer. The gearbox basically has straight cut gears it's going to whine, and as the output shaft gets faster up the gears the speed the teeth wipe each other goes up. Maybe because of the vibration you have got a bit sensative, I know it can play on the mind, I am going with sort that chain at the moment PS - make sure that sproket is tight, and see if it's got the modified nut Re: Is this clutch basket a basket case - gra0411 - 15-07-13 Looked on flea bay most pics as I'm on a phone don't show any conclusive answer either way , sprocket nut tight and tab still on , don't know if you saw old post re nut but had chain and sprocks fitted lots of years but not many miles ago and nut come off on way back from shop and I got new nut /tab from dealer but it not me being sensitive it a progressive worsening problem , ie noise louder and vibration getting worse and makes fingers go numb after 30 mins riding , foot peg loosens about every 50 miles even with thread lock ( chain side) and I've done 15k miles on this bike over 8 years its not something I noticed in the past , I wondered if output shaft focced after nut come off also when got bike years ago chain was well tight ( don't know how long for) Re: Is this clutch basket a basket case - gra0411 - 15-07-13 Sorry should have said wasn't sat on bike with chain off and that was when whine started and vibes was minimal , now whine and vibes worse , will have to do that again to double check |
