Knocking Through Foot Pegs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Knocking Through Foot Pegs (/showthread.php?tid=64025) Pages:
Re: Knocking Through Foot Pegs - Biggy461 - 22-06-13 Yeh thats correct if you pull the clutch lever in when its knocking it stops, and also if you roll off the throttle. Seems only to be between 3 to 3.5k revs? Once you get above it it goes or its unnoticeable? Re: Knocking Through Foot Pegs - darrsi - 22-06-13 Chain problems will still happen as long as the rear wheel is moving. That's altered things a little? Re: Knocking Through Foot Pegs - darrsi - 22-06-13 Have a look around the engine mounting bolts, i read on another forum about someone having a snapped bolt causing knocking on the right foot peg. Re: Knocking Through Foot Pegs - Biggy461 - 26-06-13 I cleaned and lubed the chain and this seems to have reduced the knocking quite a bit. |
