Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston (/showthread.php?tid=63654) Pages:
Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - elbrownos - 01-06-13 Keep your Dad away from your bike! What a disaster.. The dust seals are important because they also retract the piston slightly when you release the brake. Without them your brakes will rub and overheat. I recently used pattern seals & pistons from Bitzforbikes and I reckon they are fine. Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Andy Smith FZS - 10-06-13 Update Fitted a thou caliper, posted up a pic of the finished fit and one of a banjo sitting above the bit you need to file. I did it while the caliper mount was on the bike. I tucked a cloth between the mount and the discs so I didn't scratch the disc. Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Andy Smith FZS - 10-06-13 I need to move the brake line abit but you the idea. Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Chris - 10-06-13 Where did you find a thou caliper??? :eek Chris Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Andy Smith FZS - 10-06-13 Bought it off Claude aka Fuzzy on here
Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Chris - 10-06-13 Damn, I've had my eyes peeled for one of them for ages... haha! I'll find one sometime, although I just spent a fair few quid rebuilding my standard one so it should last fine for a while. Chris Re: Rear Caliper - Helped Needed - Pictures of Issue - Stuck Piston - Dave48 - 10-06-13 Andy-just make sure the caliper or mounting plate doesn't foul brake line under movement of swing arm etc. BUT YOU KNEW THAT ANYWAY :eek Glad you sorted problem. Go easy on the pedal! :lol |
