Exup valve....sheared bolt...rattles - the saga continues! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Exup valve....sheared bolt...rattles - the saga continues! (/showthread.php?tid=63402) Pages:
Re: Exup valve....sheared bolt...rattles - the saga continues! - marcusfordus - 16-07-13 All this drilling going off, are you just using HSS drill bits ???? If you are, you need to change them to the correct type. (I worked with a proper engineer, who knew everything about everything in metals, top bloke rode a Goldwing !). I did what he said and was able to drill all sorts of stuff the normal bits wouldn't touch. The bits were pricey though. Re: Exup valve....sheared bolt...rattles - the saga continues! - FazerRuss - 17-07-13 Yes, regular HSS drill bit worked just fine on this one. |
