quiet when cold, rattles like mad when warm ?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: quiet when cold, rattles like mad when warm ?? (/showthread.php?tid=62999) |
Re: quiet when cold, rattles like mad when warm ?? - markaboot - 08-05-13 (08-05-13, 09:45 AM)markaboot link Wrote: [quote author=His Dudeness link=topic=7375.msg74138#msg74138 date=1367849276] will do, thanks. i do have starting issues sometimes, where battery seems to die for no reason. i can crack bike up fine, ride 10 mins home, park up on the back alley open the gate. get back on and i have nothing, just dead. guess i'll just have to keep pulling things apart till i find the problem. [/quote] after the old screw driver trick, the noise seems to be top / central. mainly concentrated around the tensioner. i seem to be back to cam chain again. now after that compression check being at 90psi, is it possible that some how the timing is out? or a slack chain would lead to timing being out? is it at all possible for a tooth to skip and there be slack in the wrong place? think its time i took the rocker cover off. Re: quiet when cold, rattles like mad when warm ?? - Gnasher - 08-05-13 (08-05-13, 06:22 PM)markaboot link Wrote: [quote author=Gnasher link=topic=7375.msg74625#msg74625 date=1368026045] Have you checked the carb balance as out of balance carbs can give you a very similar noise?[/quote] carbs were balanced last year, can they really be that out in that space of time?[/quote] They sure can balancing carbs is not just a simple matter of twiddling the sync screws to get the needles all the same it really isn't. Re: quiet when cold, rattles like mad when warm ?? - unfazed - 09-05-13 Timing would want to be off by a good few teeth before it would bring compression down to 90psi and the valves would be hitting pistons by then. When I replaced my chain, the old one was one 1 1/2 length longer than the replacement. I check the valve clearance for a friend last year and discoverd whoever replace the chain on his bike before he bought it had the timing on the exhaust cam out by one tooh and the bike appeared to be running fine. I lifted the cams and reset the timing to the correct position and put it all back together he took it for a spin and said he found absolutel no difference in the performance. All the issues you have described point to the water pump, but you appear to have ruled that out. Never heard of cam chain or tensioner on a fazer rattling when hot and quite when cold, it has always been the oppisite. For out of balance to cause that kind of sound it would not even run. Other possibilites are worn clutch drum, starter clutch as some else has mentioned cam shaft end float or a cracked shim or valve lifter, list is endless. It is really now a process of elimination. Re: quiet when cold, rattles like mad when warm ?? - markaboot - 09-05-13 (09-05-13, 01:45 PM)unfazed link Wrote: Timing would want to be off by a good few teeth before it would bring compression down to 90psi and the valves would be hitting pistons by then.i will check the compression again when my 10mm adapter arrives, it was a quick check and if i'd done it at home i'd have taken my time with it. might be checking the valve clearances this weekend so can check timing too, will also check the cam lobes etc at same time. ![]() ![]() here is said water pump, nothing obvious to me when i had it out. bearings ran smooth, if a little tight. seals looked in good nick. i have now cleaned the pump as it was impossible to tell if anything was leaking from the drain hole due to it being caked in chain lube and muck. i drained the water off and again had a slight rusty orange tinge and slight smell to it but this could be residue from previous coolant. fresh in again with rad flush this time, will be putting anti freeze in at the weekend sometime. i will certainly be keeping an eye on this and checking again in the future, haven't ruled it out yet. Re: quiet when cold, rattles like mad when warm ?? - unfazed - 09-05-13 A bit of pitting on the shaft, but would not appear to be enough to cause the rattle you have. However the clearance on the impleller to casing is very small and the least bit of wear could cause a rattle as the impeller hits the casing especially under load, but there does not appear to be any scratch marks on the impeller. Have you ridden the bike with fresh coolant, you may find the rattle is gone since the lower viscosity of the new coolant may not put the pump under as much pressure. When you put it back together and if the rattle is still there use to screw driver trick to listen to the pump. The bigest problem with the screwdriver trick is how to filter out the normal sounds from the abnormal sounds. Re: quiet when cold, rattles like mad when warm ?? - markaboot - 09-05-13 (09-05-13, 08:52 PM)unfazed link Wrote: A bit of pitting on the shaft, but would not appear to be enough to cause the rattle you have. However the clearance on the impleller to casing is very small and the least bit of wear could cause a rattle as the impeller hits the casing especially under load, but there does not appear to be any scratch marks on the impeller. the biggest problem is reaching the throttle whilst bending down with a screw driver on the water pump :rollin yea i ride every day at the moment, car is in a worse state of repair! it did seem quieter today, but then it was raining and much colder than the last couple of days. its only a ten min ride to work so usually only just gets warmed up fully by the time i've arrived. Re: quiet when cold, rattles like mad when warm ?? - unfazed - 09-05-13 Get a very long screwdriver with a bend in the middle :lol Re: quiet when cold, rattles like mad when warm ?? - markaboot - 13-05-13 checked the water pump this weekend for noise and its quiet, certainly isn't the source of the knocking its very hard to pin point but i'd say the noise was from the top front quarter if looking from the side, if that makes sense. so the portion above the exhaust manifold, the cam valves or chain guide maybe. didnt get chance to check the valve clearances unfortunately, so that will be a job for next weekend unless we get a dry sunny evening :rollin Re: quiet when cold, rattles like mad when warm ?? - darrsi - 13-05-13 Don't know if it's been asked before but what oil are you using, out of curiosity? Re: quiet when cold, rattles like mad when warm ?? - dBfazer600 - 13-05-13 I know this is opposite to your problem but if carbs and valves are that out or spark issues the two vids below may help if you think they sound is similar. FZS 600 cam chain tick before FZS 600 cam chain tick after I have a need to know what the problem is and it's simply curiosity and frustration (but not as bad as you will be) Daz Re: quiet when cold, rattles like mad when warm ?? - markaboot - 02-06-13 (13-05-13, 10:30 AM)darrsi link Wrote: Don't know if it's been asked before but what oil are you using, out of curiosity? sorry been busy, oil is castrol power 1 4T 10w-40 just wondering if i should go with a slightly thicker oil? Re: quiet when cold, rattles like mad when warm ?? - darrsi - 02-06-13 No, not at all, 10w/40 is correct. Re: quiet when cold, rattles like mad when warm ?? - markaboot - 02-06-13 well after my mechanic mate talking me into changing the cam chain (for the price of a new chain its not worth risking etc) its not the chain lol so now me are back to the tensioner, after having it out the 5th time we noticed some play when the spring is in. when you try to push the tensioner back out the ratchet is locking fine under pressure but there seems so be a good 5 mm movement between clicks. so what im trying to explain is under compresion the tensioner locks but when released the spring will push it back out about 5 mm without moving on to the next click. think that makes sense. so is it possible that the tensioner is bouncing on the spring? took a picture today of the contact surface between the tensioner and the guide, down the tensioner hole. i have nothing to compare but it looks like there could be some indication of wear. ![]() any ideas? Re: quiet when cold, rattles like mad when warm ?? - markaboot - 27-03-14 well after a long time I finally had the chance to get round to having a go at getting the bike back on the road. Unfortunately that wont be happening for while! however on the plus side (not really a plus) I have discovered the source of my rattle. Some how i have chewed through my big end shells and scored the crank :'( Re: quiet when cold, rattles like mad when warm ?? - His Dudeness - 27-03-14 20k and the engine ate itself? :eek Never hear of that on a Fazer. Got any pics of her? Re: quiet when cold, rattles like mad when warm ?? - markaboot - 27-03-14 taking it to work with me tomorrow so will take some pics then. knew it was bad after taking the oil strainer off and it was full of copper shards! guess i must have had an issue with the oil feed Re: quiet when cold, rattles like mad when warm ?? - Timbollew - 28-03-14 (05-05-13, 02:29 PM)markaboot link Wrote: so earlier today i decided i would manually advance the tensioner by one click. got the carbs off again, this time without undoing everything as haynes suggests and just lifting them up out the way.I need to get in and check my tensioner so I'm interested in your easier technique to get the carbs off. Please enlighten me... I was listening to my engine with screwdriver and it all went wrong ![]() Re: quiet when cold, rattles like mad when warm ?? - reddave101 - 29-03-14 Had exactly the same problem which was doing my head in. I ended up stripping the engine completely to no conclusion..BUT it is now cured.. Very simple after all that.. Changed oil, filter to high grade 10/40 and made a oil filler breather. The only reason I came to this check was from time to time I noticed the bike had more torque than before and the clutch would become stiff and heavy. So after no end of research and came to my own conclusions I ended up thinking there may possibly be too much air building up in the crankcase and causing loads of torque to release the air pressure because after a short blast the torque would slacken off and would get a rattle.. Now just to point out my fazer 600 98 model has a few performance upgrades which may not of helped with mine but after I've made a oil breather to replace the filler cap, blocked off the air inlet to the air box and rerouted the crankcase breather pipe, all rattling has gone and even the fuel economy is better, and throttle response is 100% better. Hope that gives you some more insight into a cure for you.. Re: quiet when cold, rattles like mad when warm ?? - markaboot - 31-03-14 (29-03-14, 08:35 PM)reddave101 link Wrote: Had exactly the same problem which was doing my head in. I ended up stripping the engine completely to no conclusion..BUT it is now cured.. Very simple after all that.. Changed oil, filter to high grade 10/40 and made a oil filler breather. The only reason I came to this check was from time to time I noticed the bike had more torque than before and the clutch would become stiff and heavy. So after no end of research and came to my own conclusions I ended up thinking there may possibly be too much air building up in the crankcase and causing loads of torque to release the air pressure because after a short blast the torque would slacken off and would get a rattle.. interesting! would be worth doing a little how to on this or at the least a few pics please Re: quiet when cold, rattles like mad when warm ?? - markaboot - 31-03-14 as promised a few pics. ![]() what i found when i took the oil strainer off :'( not a good sign! ![]() the damage on number 4 ![]() number 4's bearing ![]() the damage to number 3 ![]() whats left of number 3's bearing, the missing bit fell out after removing the con rod not before. also note the discolouration of the steel, thats been hot! ![]() a comparison of the colour difference, number two also has play and is a little tight to turn. main bearings don't look great either. on the plus side my 'new old stock' crank arrived today now i need to source bearings. can anyone recommend a good place to buy bearing shells from? |
