Annoying noise from front wheel area..... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Annoying noise from front wheel area..... (/showthread.php?tid=62065) Pages:
Re: Annoying noise from front wheel area..... - spoonlamp - 03-03-13 This is all sounding very familiar - I've recently picked up an intermittent rattling as well. Not the normal fairing vibration (which isn't too bad on mine), this is like a cable is rattling against the tank or something. Noticeable when clutch is in and slowing or sometimes when cornering with a bit of lean on... Re: Annoying noise from front wheel area..... - bwizz - 03-03-13 Does you mode have the electronic speedo sender, ? They dry up and luggs break of! Re: Annoying noise from front wheel area..... - Fuzzy - 03-03-13 (03-03-13, 01:16 PM)spoonlamp link Wrote: This is all sounding very familiar - I've recently picked up an intermittent rattling as well. Not the normal fairing vibration (which isn't too bad on mine), this is like a cable is rattling against the tank or something. Noticeable when clutch is in and slowing or sometimes when cornering with a bit of lean on... Sounds very similar! As for the speedo sensor I will check that aswell when the wheel comes off. Re: Annoying noise from front wheel area..... - darrsi - 03-03-13 (03-03-13, 01:16 PM)spoonlamp link Wrote: This is all sounding very familiar - I've recently picked up an intermittent rattling as well. Not the normal fairing vibration (which isn't too bad on mine), this is like a cable is rattling against the tank or something. Noticeable when clutch is in and slowing or sometimes when cornering with a bit of lean on... Headlight bulb springs can unclip themselves, plus front indicators and fairing infill trays can all cause a rattle. |
