New carbs!!!!!!!!!but..... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: New carbs!!!!!!!!!but..... (/showthread.php?tid=61675) Pages:
Re: New carbs!!!!!!!!!but..... - packie - 01-02-13 You might have competition there, Padraig. There is a lad on here who had his carbs out about 10 times to date!! His problem is runnig longer than Coranation Street!! :'( Be careful where that bike leads you, bud. It might become a bottomless pit for money and you could get sucked in. I bought (what I thought) was a decent bike but paid a terrible price in bad decision making. The first bad decision was with all my 20 year experience in bikes and having owned/bought quite a few....on this deal I acted like a "first timer" getting into bikes when I bought it. In my enthusiasm to close the deal in a far and distant land, I checked nothing meticoulously. I bought it private in another County which was a first for me. I rarely buy private due to comeback issues, and buying it in another County sort of hedged me to buy it on the spot because going away to mull on it was not an option with the travel distances involved. Even then, if I had did a thorough check all over the bike or paid for a second opinion to come with me, I would have spotted a catalogue of things wrong that would have costed a lot of money to fix. That would have at least given me the option of walking away. Instead, I got suckered into bit by a bottomless pit of money spending and bad decion making as follows. When I got the bike home, I discovered that the brake discs were under the limit and needed replacing. That including the pads, costed a kings ramson and that is were my problems began. Now I was totally committed to the bike and could not walk away unless I took a heavy loss. When doing that job I found that they butchered the bleed nipple on the rear caliper and it was a small bit iffy anyway so I decided to get a secondhand Fazer thou one instead. Then I discovered that the rear master cylinder was butchered and had to get a second hand one, and in the process, I cracked the Master cylinder's mounting riders footplate that had to be replaced too. I was well up to my armpits invested in the bike now. Then I had camchain problems which the previous owners load pipe masked over. I decided to buy a quite pipe for it and that's when I heard all the camchain rattles. I knew that the camchain was knackered. No problem there. But on inspecting it further, some dipsh!t had the same problem earlier but decided to weld a lump of metal onto the tip of the tensioner to take up the slack further instead of replacing the camchain. The result for me was a chamchain and a new tensioner had to be fitted. It was getting to be a joke at this stage. I then had an electrical problem that would cut the bike dead unexpectantly at take off. Actually when I first noticed it, I noticed it because I bloody fell off the bike as it threw me off balance. Luckily (my first bit of luck!) there was no damage to the bodywork but I did snap the front brake lever in two which had to be replaced. I eventually sorted it to being a loose wire on a connecting block down by the relays. That I sorted myself at no expense, but it was effecting my moral big time at this stage. I nearly sold it to the breakers for 500 quid!! Next up was a fork leg that was badly corroded that I didn't spot. Had to get a second hand one. Now I have tight spots in two places on my chain and sprockets, I just bought a new set as we speak. I said to myself, I might as well go the full hog, so I bought a K&N filter for it as i'm going to balance the carbs pretty soon. The bike has been running well now for the last 1,000 miles and i'm really enjoying it. Hopefully all my problems (major ones) are behind me. It's a fantasic bike when running well and really suits me. I have a fine bike now, no doubt. But the money that the bike costed and what I put into it would have gotten me a 4-5 year old newer version. And if I ever sell it on, it will always be for a big loss now. I suppose it has thought me a few valuable and major lessons too going forward, so that's a plus too. So be careful were that bike takes you because you could be entering a place of no return like me if someone takes about 4-5 hours to fix it at €50 a hour. Rant over.!...ha ha! :2guns Re: New carbs!!!!!!!!!but..... - reillypadraig - 01-02-13 your dead right there i bought for 750 and it now stands me about 1100 and its still not running, i should have just waited for a decent running bike but (i knew it all at the time) silly me i had to buy clutch level & cable gear selector new rear brake pads(but then the caliper was shit, thanks again for that, it runs nearly too wel, rear wheel locks with anything over fairish force, think only one piston working well) had to replace clutch but old engine had better clutch in it had to but engine mounting bolts oil & oil filter 50 for new choke plunger but then old carbs wer fucked so waste of money new rear indicators rear fender has half missing under the seat needs replacing had to temp fix the speedo but need new one have over 200hours spent on fucked up electrics and bad connections(i bought the bike last august!!the bank holiday weekend) new fuel filter i coulod rant on for hours at this but im not ready to give the bike into urman until im 100% sure all it needs its mix screw twiddling Re: New carbs!!!!!!!!!but..... - packie - 01-02-13 ..only €200 away from what you spent. It's on the website for the last month or two, so I'd say it would have gone for a €1,100 if you waved it in front of the guy. http://www.donedeal.ie/for-sale/motorbikes/4310233 Re: New carbs!!!!!!!!!but..... - reillypadraig - 02-02-13 i know, seen that and all, even seen a cbr for 800 quid, a week after i bought the fazer and not a thing wrong with it, seen the bike before and all, guy was emigrating and just wanted cash there and then. wel its back to removing the carbs again and proding trough the holes to see if there is and dirt left in my jets Re: New carbs!!!!!!!!!but..... - packie - 02-02-13 Have fun :fish Re: New carbs!!!!!!!!!but..... - red98 - 02-02-13 on the plus side....when your bikes up and running your going to know exactly what you`ve got and also have a great knowledge of how your bike works .....keep at it matey iam sure your very close and after a few good rides you will forget all about the hassle
Re: New carbs!!!!!!!!!but..... - reillypadraig - 02-02-13 oh i will, lots and lots, its getting ridiculous now Re: New carbs!!!!!!!!!but..... - red98 - 04-02-13 any progress over the weekend
Re: New carbs!!!!!!!!!but..... - reillypadraig - 04-02-13 (04-02-13, 09:05 PM)red98 link Wrote: any progress over the weekend yes actually, i used the ultrasonic cleaner i got in aldi and heard to use vinegar, worked well, came out very clean, i put in the jets from the old carbs aswel and used the cleanest ones of all of them as 2 of the pilot jets from new carbs i got were blocked. got them in and as standard setting bike was sluggish( as in 2 turns from seated on the idle screws,) so i droped the needles one clip and made it worse as bike from standard settin g was spitting fuel from exhaust so i raised them one clip from factory and bike ran better with better trottle response, so i then went on to adjust the idle screws untill the bike revved up . i mean i adjusted the screws out(richer) until it ran better and the idle went up, was kinda tough to hear it though on the 1st and 4th cylinder, but got it fairly close, but i just cant get to the 3rd one, i can move it abit but i either burn my hands of the block and then i cant see what im at or adjust with a pointy nose pliers and it take about 5-10mins for one revolution so cant adjust fast enough to hear a change in the idle (which im told to listen out for) bike still has dead spots but at times has full power and really have to hang on lol :b iv used an allen key with a small socket and a small phillips head into the socket to turn it but its too big even at that as it hits the starter motor and is at too much of an angle to turn it, i have to go into a tool shop this week to find a way, there is a offset rachet set im told will do the job but i have my doubts, i also seen a carbtune 90 degree screwdriver but its a fortune. very close now!! on the plus was a dry day so got a bit of gunk degreaser to the bike and shes abit shiny-er now :eek [size=78%]any ideas on adjusting that screw, im sure this problem has come up over and over again [/size] |
