Oil & Oil Filter change. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oil & Oil Filter change. (/showthread.php?tid=61589) Pages:
Re: Oil & Oil Filter change. - xlewisbdx - 30-01-13 (30-01-13, 05:40 PM)darrsi link Wrote: I personally use a ring spanner, it's a bit easier to use with the bike on the side stand (drains the oil easier on the side stand). Cheers boss, will do. I've just bough a set of spanners and it has a 17mm ring one on so I am good to go there ![]() Just to get this right, it is around 2.7 litres when I fill it back up. I will be draining the oil and changing the filter. Re: Oil & Oil Filter change. - darrsi - 30-01-13 From empty, as you are changing the filter as well, you're safe to put in 2.5 litres straight off. Then, start the engine for 20-30 seconds so it coats the engine, switch off, and then watch the window, the oil will slowly rise up. If it's not enough add a bit at a time, then start engine again, switch off, then watch the window again. Repeat this process until the oil level is in between the metal markers at the side of the window. Make sure the bike's on a level flat surface on the centre stand though otherwise you'll get a false reading. If you're thinking of changing the oil around the 4000 mile mark, you only need to replace the filter every 2 changes, it's not necessary every time. Re: Oil & Oil Filter change. - xlewisbdx - 30-01-13 (30-01-13, 05:52 PM)darrsi link Wrote: From empty, as you are changing the filter as well, you're safe to put in 2.5 litres straight off. I love you....
Re: Oil & Oil Filter change. - Lazarus - 30-01-13 according to manual : Oil quantity:Total amount:3.5 L Periodic oil change:2.5 L With oil filter replacement:2.7 L Re: Oil & Oil Filter change. - darrsi - 30-01-13 (30-01-13, 05:54 PM)xlewisbdx link Wrote: [quote author=darrsi link=topic=5961.msg54678#msg54678 date=1359564761] I love you.... [/quote] Now, now, control yourself, you have a bike to look after....... :biker Re: Oil & Oil Filter change. - darrsi - 30-01-13 (30-01-13, 05:55 PM)Lazarus link Wrote: according to manual : Crikey, don't chuck 3.5 litres into the equation, i'm trying to make this easy!! 3.5 litres is in the factory, totally dry. Re: Oil & Oil Filter change. - xlewisbdx - 30-01-13 (30-01-13, 05:57 PM)darrsi link Wrote: [quote author=xlewisbdx link=topic=5961.msg54680#msg54680 date=1359564862] I love you.... [/quote] Now, now, control yourself, you have a bike to look after....... :biker [/quote] Oh yeah, he gets all the attention first ![]() Re: Oil & Oil Filter change. - zielik - 04-05-17 I will be changing oil in mine. Do you know the measures for drain washer? Or link to websites would help. Fzs600 2002. Thanks. Re: Oil & Oil Filter change. - darrsi - 04-05-17 (04-05-17, 08:02 PM)zielik link Wrote: I will be changing oil in mine. Do you know the measures for drain washer? Or link to websites would help. Fzs600 2002. Thanks. Would just use the old one to be honest, the sump bolt is long with plenty of thread, it's not under any stress, and won't come loose or leak. Don't go mad tightening the bolt up either otherwise you'll round it off. Re: Oil & Oil Filter change. - bandit - 04-05-17 Agree with darrsi, but if you want to replace with a new one you need a aluminium sump washer M14x20x1.5. http://www.ebay.co.uk/itm/M14-X-20-X-1-5-MM-THICK-ALUMINIUM-SUMP-NUT-WASHERS-/270661455664 Re: Oil & Oil Filter change. - zielik - 04-05-17 HI Darrsi and Bandit Thank you very much for help. If I will manage to buy it in Edinburgh before the weekend (as it's too late for online order) then I will use new washer if now then I go with the old one. I will use friend's torque wrench for tightening up so should be all good :-) Thanks again Zielik Re: Oil & Oil Filter change. - bandit - 04-05-17 You will find that you will have to undo & do it up with a ring spanner as you can't get a torque wrench or socket on it due to the frame. Just nip it up don't be tempted to over tighten as you will strip the threads. Re: Oil & Oil Filter change. - darrsi - 05-05-17 (04-05-17, 11:12 PM)bandit link Wrote: You will find that you will have to undo & do it up with a ring spanner as you can't get a torque wrench or socket on it due to the frame. Just nip it up don't be tempted to over tighten as you will strip the threads. That was my earlier point about not going mad tightening it up, you can't get a socket on the nut so unless you've got some fancy contraption then nipping up as bandit says is more than enough. If it was to leak, which it won't, then simply nip it up a little bit more. Just make sure the ring spanner is on properly otherwise it will quite easily round off or damage the soft hex head of the bolt......been there, done that before. :o Re: Oil & Oil Filter change. - Jules-C - 05-05-17 For some reason that escapes me the sump plugs seem to be made with pre-rounded corners to make them more prone to spanners slipping than normal bolt heads Re: Oil & Oil Filter change. - kgjersda - 05-05-17 Regarding alternative methods on the oil filter, fust buy an oil filter socket, it makes it so much easier to change the filter. On another note, for you guys with un-original downpipes (motad/delvic), do they make the oil filter change harder? Also for the sump plug, these are worth their weight in gold: ![]() Re: Oil & Oil Filter change. - vinnyb - 05-05-17 (05-05-17, 09:17 PM)kgjersda link Wrote: Also for the sump plug, these are worth their weight in gold:Strictly speaking only one of them is, the rest won't fit :lol Re: Oil & Oil Filter change. - darrsi - 05-05-17 (05-05-17, 09:17 PM)kgjersda link Wrote: Regarding alternative methods on the oil filter, fust buy an oil filter socket, it makes it so much easier to change the filter. :agree Yeah, good shout, i have a set of these as well, really handy. Re: Oil & Oil Filter change. - Dave48 - 06-05-17 I bought a set of these from Halfords in January and they have become my spanners of choice particularly in restricted areas. Money well spent! |
