Gen 1 Pre-load settings - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gen 1 Pre-load settings (/showthread.php?tid=60082) Pages:
Re: Gen 1 Pre-load settings - 1967fazer - 26-09-12 If your getting flashed by cars and lighting up road signs, then adjusting your beam down slightly shouldn't fail the mot test. Find a wall that you can mark up where your beam is currently, then adjust the beam down a little. Then find a friendly mot tester, who if necessary, will let you adjust the headlights there and then. That'll do it. On the shock side of things....r6 shock mod is very good, but then I've already said this. At least you've got choices:-) Re: Gen 1 Pre-load settings - FuZzBoM - 26-09-12 I was discussing this topic with a bloke i met the other week. He has a Gen 1 and done many little tweaks to it over the years. He suggested dropping the forks 10mm through the yokes. He thinks it would also sharpen the steering a little. I like free mods so i may give it a go some time
