Pillion foot pegs help please - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Pillion foot pegs help please (/showthread.php?tid=60062) Pages:
Re: Pillion foot pegs help please - limax2 - 28-01-15 (27-01-15, 11:11 AM)Fazeroverdivvy link Wrote: What do you use as spacers between the new bracket and the original hanger? This reply is to Fazeroverdivvy Welcome to the site. Be aware this is for the 600 and I'm not sure how the 1000 Fazer differs, probably very little. I have not done this mod but will try to answer your questions and YamFazMan can correct me when he returns. I don't think he has used any spacers as he says the original cap screws have a thinner head than standard and are to be used for attaching the bracket to the frame bracket. Certainly do NOT tighten the hanger screws if it is hitting the head of the bracket screw. If it does you could use washers to pack it out. Two different holes in the small bracket is because the captive nut in the exhaust bracket is 10mm x 1.25 pitch (fine series) rather than the more readily available 1.5mm pitch (course series). Since he needed a shorter bolt he has used a standard 8mm bolt to pass through the 10mm nut and put a 8mm nut on the end of the 10mm nut. Hence a 10mm clearance hole where the bracket attaches to the hanger and 8mm clearance at the exhaust end. Two different size holes in the large bracket are because the two for the hanger are tapped 8mm thread and the other two are clearance holes for bolting to the captive nuts on the frame bracket. If you used nuts behind the new bracket you would need to pack it out and use longer screws to the frame with compensating spacer etc for the exhaust bracket. Hope that all makes sense. :\ Re: Pillion foot pegs help please - YamFazMan - 29-01-15 Hi Thanks limax2 I couldn't put it better myself ![]() ATB YFM Re: Pillion foot pegs help please - HovBiker - 11-02-15 Got a 98 bike and wife finds pillion uncomfortable.she's 5ft 9 with 31 inside leg. So the 2000 on hangers give 50mm more leg stretch and straight swop? Anyone got pair for sale?? Re: Pillion foot pegs help please - kebab19 - 11-02-15 Exhaust angle is also affected, but 'join' can be readjusted into position. Worst case scenario is that the link-pipe gasket will start leaking & need replaced. I swapped mine for the later hangers / pegs. There is a decent improvement with the later hangers, but I'm not sure if it's 50mm of difference? They move the pegs both downward & forward a bit. For maximum difference you could also fit the later seat which has more pillion foam. If you adopted YamFazMan's idea on top of the later hangers I'm sure a 6 foot+ pillion would have no issues. Re: Pillion foot pegs help please - RMT1983 - 11-02-15 Im breaking my 2002 fzs600 and have the rear hangers and plastic grab handle for sale................ Message me if any good! Re: Pillion foot pegs help please - ChristoT - 12-02-15 I found the Thou pretty comfy on the occasions I've been pillion. Found it ok, just got stiff legs after about an hour. I'm a 6'3" man with a 36" leg!! Re: Pillion foot pegs help please - Paulfzs - 12-02-15 i put the newer hangers on mine they do work a lot, i also recovered the seat and added about 30mm of padding to rider + pillion seat which helped a lot. exhaust wasnt a problem it still bolts on fine Re: Pillion foot pegs help please - Punkstig - 13-02-15 (12-02-15, 06:41 PM)ChristoT link Wrote: I found the Thou pretty comfy on the occasions I've been pillion. Found it ok, just got stiff legs after about an hour.How long's the other leg? Re: Pillion foot pegs help please - Paulfzs - 13-02-15 (12-02-15, 06:41 PM)ChristoT link Wrote: I found the Thou pretty comfy on the occasions I've been pillion. Found it ok, just got stiff legs after about an hour. how is this possible! im 6ft and its horrible on the back of a fazer! Re: Pillion foot pegs help please - ChristoT - 15-02-15 (13-02-15, 10:29 PM)Paulfzs link Wrote: [quote author=ChristoT link=topic=4414.msg183260#msg183260 date=1423762909] how is this possible! im 6ft and its horrible on the back of a fazer! [/quote] Talking Thous here Paul. Never been on the back of the 6. (13-02-15, 10:17 PM)Punkstig link Wrote: [quote author=ChristoT link=topic=4414.msg183260#msg183260 date=1423762909]How long's the other leg? [/quote] "I'm Jake de peg (diddle diddle diddle dum) with mah extra leg (diddle diddle dum)!" :lol :lol |
