Advice please - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Advice please (/showthread.php?tid=59855) Pages:
Re: Advice please - richfzs - 15-08-12 What noggy describes, is pretty much how mine likes to play, and has done from new. If the engine is cold (as in ambient temp), then choke to start it, and then close the choke pretty much straight away. If its warm, then it'll start with no choke, nae bother. Re: Advice please - Stuajohnson79 - 15-08-12 Thanks for all the advise guys! Definitely some food for thought there. I'll have to see if I can get some time to pull the bike apart soon! While I've got the carbs off and apart, is it worth me replacing the rubbers! I think if you add all the cracks together it will be longer and deeper than the grand canyon! A quick update on the starting issue, I took the bike to work yesterday. It started on the third attempt with full choke (it's garaged over night by the way), could put the choke fully in by the end of the road (about 200 yards)! When I started it at lunch time (bike was in full sun all day), with no choke the revs dropped off then died when I tried to rev it or give it some choke. Restart with choke, fine! Re: Advice please - richfzs - 15-08-12 What you've described there doesn't sound too hideous Stu, apart from the 3 goes initially. Are the plugs in good condidiotn? As somebody said earlier, a good service sounds as though its in order, since you've just got it, and will probably improve things no end. (and do it before you get into taking the carbs off, its a much easier option and should be done anyway )cover the cracks in your carb rubbers with water, and start the bike - if there's a problem, you'll see the water bubbling. The rubber is very thick, and the cracks have to be immesne before they go through. Re: Advice please - Stuajohnson79 - 15-08-12 Thanks rich, I'll get it serviced as soon as I can. Is it a hideous job or is it quite easy? I'm an aircraft technician so I can wield a spanner well. It's knowing what's what on a bike! Oil, filter (air and oil), gaps? Would a dose of redex go amiss? Re: Advice please - darrsi - 15-08-12 Interesting how the descriptions of starting bikes are different, because i never need to, or even think about using the choke for starting other than maybe extremely cold climates, but even then it's not all the time! Hit the button, one light rev then it ticks over fine! @Fazerider, you keep talking about 'fresh' fuel as if it goes off over night like milk or something, and it clearly doesn't? Why is that, i'm intrigued? :rolleyes Re: Advice please - richfzs - 15-08-12 iTS NOT TOO HIDEOUS (OOPS) a task, old washing bowl is good for catching the oil, cos it comes out so fast most of the "designed for oil change trays" just overflow (in my humble experience), and the drain plug is in a stupid place behind the frame. I wouldn't bother with plug gaps, in your case - as you don't know how old they are, they're cheap enough just to replace so you know their history. Oil & air filters too. (fiddly to get at the air filter, if I recall, but hardly a Haynes 2 spanner job ). I'd probably do the fuel filter too while the tank is off (again, so you know whats what).Valve clearances are supppoed to be checked at (I think) 24,000 miles, sure somebody will correct me if I'm wrong, but virtually everybody who had done them, has found that they are bang on where they're suppoed to be, so I wouldn't bother with that! Carb balancing, will be well worth doing, if you've gauges, or can beg/borrow/steal/buy some, there's an excellent guide on here somewhere on how to do that. I'll post a link when I get home, dont have it here. Re: Advice please - richfzs - 15-08-12 redex - not really got any experience of this stuff, so cant comment. Only time I've tried it was on the cage, and didnt make difference I could tell. Re: Advice please - richfzs - 15-08-12 (15-08-12, 07:25 PM)darrsi link Wrote: @Fazerider, you keep talking about 'fresh' fuel as if it goes off over night like milk or something, and it clearly doesn't? Why is that, i'm intrigued? :rolleyes Some people are convinced fuel goes off, and that you must replace it if storing a bike, over winter say. Personally, I've never done anything of the sort, and went back to the bike after 6 months, tank half full, and it started and ran with no issue. As it does every spring. So, from my experience, its not anything worth spending more than a millisecond worrying about. Others experience may vary
Re: Advice please - richfzs - 15-08-12 Found pointer2null's great guide to carb balancing on an FZS. This is on the old Yukky site, way before we moved here. Re: Advice please - Stuajohnson79 - 15-08-12 Wanna swap bikes darssi? ![]() I do think the fuel in my bike has "gone off" as the old tax was May last year! I think the octane rating may have dropped somewhat Re: Advice please - Stuajohnson79 - 15-08-12 Thanks for the link rich. One of the guys at work has already said I can borrow his carb tuner Re: Advice please - darrsi - 16-08-12 I only ever use super unleaded, but also use the bike daily, so fuel simply won't go off........and i don't 'store' my bike over winter, i wear boots with chunkier soles :lol My bike is my transport, i've never driven a car in my life, and public transport is taboo to me......but never had issues with bad fuel....... @Stuajohnson79, obviously 15 months standing about is a different story, you probably had a tank full of soup!! :lol Re: Advice please - Stuajohnson79 - 16-08-12 Here's another one for you to mull over! Is there anyway to recalibrate the fuel sender? After 110 miles the gauge still reads full, then the light comes on at half a tank at 140 miles, then time for a refill at 160 miles! Is that good mileage? I don't ride like a prat as I don't know how to
Re: Advice please - Fazerider - 16-08-12 (16-08-12, 08:41 PM)Stuajohnson79 link Wrote:Here's another one for you to mull over! Is there anyway to recalibrate the fuel sender? After 110 miles the gauge still reads full, then the light comes on at half a tank at 140 miles, then time for a refill at 160 miles! Is that good mileage? I don't ride like a prat as I don't know how toAs an electronics engineer I did consider making a circuit to compensate for the non-linearity of the fuel sender, but took the easier option of getting used to it instead. :lol Assuming you get mid-fifties to the gallon you should be able to get 200 to 220 miles from a tankful, the reserve light typically comes on very early though... I was sweating bullets the first time I exceeded 40 miles with it lit, but do so quite often now. A fill-up then is normally 18 or 19 litres which cuts down on time wasted at petrol stations.
