More problems... non-starter and cutting out. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: More problems... non-starter and cutting out. (/showthread.php?tid=59158) |
Re: More problems... non-starter and cutting out. - CRH - 19-06-12 whilst you at it ?...chk for water in petrol? Re: More problems... non-starter and cutting out. - darrsi - 20-06-12 For the record 99.9% Isopropyl Alcohol binds with water in the fuel tank, and then it gets burnt off. I put 200ml in every full tank of fuel over winter otherwise it suffers from carb icing, not only does it get rid of any water it also lowers the freezing point. But that's a totally different story.......... Re: More problems... non-starter and cutting out. - Lawrence - 20-06-12 Just tried it, pump primed fine but no spark on cranking! What's the prime suspect for this? Do these bikes have one coil or 2/4? Anything else that can get tempramental and give results like this? Re: More problems... non-starter and cutting out. - CRH - 20-06-12 2 coils...and yes! it could be your ecu playing up?....rarely give bother though?...even if one coil had gone down?...i would have thought it would still start>...albiet only on 2 cylinders?......one for mr blade or red98 me thinks?? :rolleyes Re: More problems... non-starter and cutting out. - CRH - 20-06-12 your ecu is tucked away under seat behind your toolkit!!!....chk if the plugs to it are tight and that its bone dry?....not much else you can do but try another if its suspect?.......couple on ebay for £10.00........
Re: More problems... non-starter and cutting out. - red98 - 20-06-12 when you say no spark,is that on all plugs ?...as crh says 2 coils, mounted next to fuel pump,one coil supplies cly 1+4 the other 2+3.i`ll be surprised if both coils have failed at the same time...yes should run on 2 cylinders,did you replace the plugs ? check the ends of the ht leads these go hard after time,they can be trimmed and then re-fit the cap...not too much though as wont reach the plug,then its new coil time if no spark on any plugs i would look at side stand switch,kill switch and ignition switch next
Re: More problems... non-starter and cutting out. - CRH - 20-06-12 and??....if none of the above??......chaqnge the ecu?? :rolleyes Re: More problems... non-starter and cutting out. - ade the blade - 20-06-12 (20-06-12, 09:28 PM)CRH link Wrote: and??....if none of the above??......chaqnge the ecu?? :rolleyesif none of the above........4.5 ltrs of best unleaded and a nice shiny new ciggy lighter. never fails !! :lol :lol :lol :lol :lol :lol Re: More problems... non-starter and cutting out. - Lawrence - 21-06-12 Plugs were changed today, didn't really make any difference but the old ones were pretty scabby - two of them looked like they'd been sitting in a puddle for a while. The one with no spark was cyl 4, I didn't check the others but I'll take a spare plug with my tomorrow so that when it does it I can check them all. I'll check out the ECU, I agree it seems unlikely that both coils would die at the same time. Might be the weekend before I get to check it out, hopefully it won't screw me around too much tomorrow/Friday. Thanks for the advice so far, hopefully I can get this sorted out asap - I do 600 miles a week on it just going to work
Re: More problems... non-starter and cutting out. - red98 - 21-06-12 good idea taking plug with you....starting point has to be to see if you have/have not got a spark on all of the plugs / cylinders .......do you know how long the old plugs have been in the bike ?
Re: More problems... non-starter and cutting out. - Lawrence - 21-06-12 No idea, a couple of years at least judging from the condition of them. Re: More problems... non-starter and cutting out. - ade the blade - 21-06-12 have you got a spark on plugs #1 and 4? if so then left ( sat on bike ) coil should be fine. #2 and 3 are right hand. if no sparks at all good chance problem is in ecu / ignitor box of tricks as clive ( crh) has stated.........either that or it was a lucky guess knowing him :rollin :rollin :rollin :rollin only kidding clive :rolleyes :rolleyes :rolleyes Re: More problems... non-starter and cutting out. - CRH - 21-06-12 (21-06-12, 06:52 PM)ade the blade link Wrote: have you got a spark on plugs #1 and 4? if so then left ( sat on bike ) coil should be fine. #2 and 3 are right hand. if no sparks at all good chance problem is in ecu / ignitor box of tricks as clive ( crh) has stated.........either that or it was a lucky guess knowing him :rollin :rollin :rollin :rollin only kidding clive :rolleyes :rolleyes :rolleyes.....lucky guess!!!!! how dare you? :eek .....and i thought you was my pal????? :'( :'( :'( :'( :'( :'( .......cum along red? ..... :b ......ime not speaking to that blade bloke agen?....until he makes a retraction!!!!!
Re: More problems... non-starter and cutting out. - ade the blade - 21-06-12 (21-06-12, 08:06 PM)CRH link Wrote: [quote author=ade the blade link=topic=3509.msg28946#msg28946 date=1340301125].....lucky guess!!!!! how dare you? :eek .....and i thought you was my pal????? :'( :'( :'( :'( :'( :'( .......cum along red? ..... :b ......ime not speaking to that blade bloke agen?....until he makes a retraction!!!!! [/quote] think i read that too quick............sounded pretty sexual. yucky :rollin :rollin :rollin :rollin :rollin :rollin Re: More problems... non-starter and cutting out. - CRH - 21-06-12 no!!!! not sexual at all!!!!!.........but???? :rolleyes ......he did ask me if i would do his housework for him?...whilst he played around with his ..genny!????? :b ....of cause i declined!!!!!
Re: More problems... non-starter and cutting out. - red98 - 21-06-12 now now boys,calm down your both getting over excited...and you know what happened last time...... back to the problem ,if no spark on any cylinders i too would suggest changing ecu,simple job,2 plugs,2 screws,job done....as you know i do have a spare but not for sale...if your local your welcome to come round and try it
Re: More problems... non-starter and cutting out. - ade the blade - 21-06-12 (21-06-12, 09:56 PM)red98 link Wrote: now now boys,calm down your both getting over excited...and you know what happened last time......pot / kettle....................................filth !! :evil Re: More problems... non-starter and cutting out. - red98 - 21-06-12 new that was wrong as i was typing it :o ...trying to be all polite tonight and not lower myself to you levels...these guys are just here for a bit of help...this is foc-u.......FAZER OWNERS CLUB.....not the filth sites you spend most of your lonley nights on.....
Re: More problems... non-starter and cutting out. - ade the blade - 21-06-12 (21-06-12, 10:21 PM)red98 link Wrote: new that was wrong as i was typing it :o ...trying to be all polite tonight and not lower myself to you levels...these guys are just here for a bit of help...this is foc-u.......FAZER OWNERS CLUB.....not the filth sites you spend most of your lonley nights on.....read between the smut and the advice is there for our fellow owners.........as we go through the keyhole !!!!!!!!!!! :lol oh and i aint watched `greasing up those nipples` on BSA for beginners for quite a few weeks now :rollin :rollin :rollin :rollin :rollin :rollin anyway,it sounds like you`re gonna build a monastery and sell lavendar soap before long brother !! :lol :lol :lol :lol Re: More problems... non-starter and cutting out. - CRH - 21-06-12 oooooooooooooooooooooooooooooooooooooooooh !!!!!........ADE?.......reds gone straight????????...... :eek ...he doesnt want to be in our gang no more?? |
