Loss of tyre pressure - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Loss of tyre pressure (/showthread.php?tid=75455) Pages:
Loss of tyre pressure - redfox1 - 17-04-16 Hi everyone,Just a quick question-how common is it for the wheels to become corroded ?.I'm asking as both my front and rear tyres are losing roughly about 1psi a day.I have had them refitted by a tyre tech,but they still leak about the same amount,and he did mention possible corrosion-has anybody else had this problem,and short of new wheels,is there anything else I can do? Re: Loss of tyre pressure - Val - 17-04-16 .. Re: Loss of tyre pressure - Val - 17-04-16 (17-04-16, 07:05 PM)redfox1 link Wrote: Hi everyone,Just a quick question-how common is it for the wheels to become corroded ?.I'm asking as both my front and rear tyres are losing roughly about 1psi a day.I have had them refitted by a tyre tech,but they still leak about the same amount,and he did mention possible corrosion-has anybody else had this problem,and short of new wheels,is there anything else I can do? Your Fazer is very new to have that. And I never heard that hapenning on even older Fazers. Theoretically is possible. What worries me your tyre "tech" uses the word "possible"? That means he has done not good job finding the leak. Does he ever immersed the whole tyre in a water tank to find the leak at all? If not you need better tyre tech. There may be zillion other thinks too. Like valves. Because of clamp weights. Cracks on wheels. Different tyre punctures. If the corrosion in the beads is the problem, most tyre outlets will take off the tyre, clean off the worst of the corrosion and refit the tyre using a sealant that is specially made for the job. Obviously your tyre "tech" has not find the leak and has not done the cleaning and sealant bit does he? Re: Loss of tyre pressure - slappy - 17-04-16 Check the tyre valve, make sure the inner part is screwed in correctly. Smear a bit of spit over the valve , after removing the cap obviously, see if there are any bubbles.Is the tyre seated correctly on the rim? As for corrosion, possible but I think it would be unlikely. Re: Loss of tyre pressure - redfox1 - 17-04-16 Thanks,guys.I think the tech did use some sealant cos I can see the remains of it on the wheels.Done the spit test myself,and could see nothing-I guess I might go back to see if they could have another go,or maybe take it to another garage,but original garage is really local,so it will be harder,but the bike is otherwise great,so I suppose it's no real chore to put myself out!
Re: Loss of tyre pressure - slappy - 17-04-16 Are you sure its sealant and not just remains of whatever stuff they used to help tyre slip onto rim? Where I get my bike tyres fitted he uses a soaplike lube to ease them on better and it leaves a white residue. Re: Loss of tyre pressure - redfox1 - 17-04-16 (17-04-16, 09:20 PM)slappy link Wrote: Are you sure its sealant and not just remains of whatever stuff they used to help tyre slip onto rim?Yea,that's right,the residue is white-does anybody know what colour the sealant is?-Problem is,this tyre fitter comes highly recommended round here and is normally quite trustworthy-but something's not quite right! Re: Loss of tyre pressure - Bretty - 17-04-16 Ever considered filling the tyre with an off the shelf sealant (like slime) yourself? I'm just putting that out there, I've never used the stuff, but I'm considering putting a can under the seat for some European touring I have planned. I have a slow leak on my rear. I found today it was 21psi so inflated it back to 42, I'll check it next weekend and make a plan. I also found the rear tyre has a 90degree valve and the front is straight so I couldn't use the compressor at my local garage and will but an emergency adaptor for it. Re: Loss of tyre pressure - bandit - 17-04-16 Redfox, clean the white residue off & make up thick washing up liquid/water mix & apply with a paintbrush between tyre/rim,look for bubbles,also check tyre valves for cracks or leaks from the base where it goes through the wheel. Re: Loss of tyre pressure - redfox1 - 18-04-16 (17-04-16, 10:32 PM)bandit link Wrote: Redfox, clean the white residue off & make up thick washing up liquid/water mix & apply with a paintbrush between tyre/rim,look for bubbles,also check tyre valves for cracks or leaks from the base where it goes through the wheel.Good idea-it's the fact that both tyres are both leaking at once which makes me doubt corrosion-they're year-old BT 23's which I've always had a problem with retaining pressure-will check the rims with the washing-up water to see if I can see anything Re: Loss of tyre pressure - darrsi - 18-04-16 (17-04-16, 10:06 PM)Bretty link Wrote: Ever considered filling the tyre with an off the shelf sealant (like slime) yourself? The slime stuff works very well, i had a slow leak in my rear tyre, which still had life left in it so i gave it a go. Few months down the line i heard a pop one morning and saw a large screw had gone in at a funny angle. Tyre didn't deflate at all so i rode to bike tyre place a few miles away and got mugged off for a new T30 as it was the best one they had in stock. They won't repair a tyre with this stuff in, because it's just too messy, and they'd have trouble using glue so it's way too much effort, but it'll certainly get you out of trouble if touring. Can be a bugger to put in the valve though, it's lumpy so you need something to poke it down with and preferably an air line to use as well. Re: Loss of tyre pressure - Val - 18-04-16 (17-04-16, 09:40 PM)redfox1 link Wrote: Yea,that's right,the residue is white-does anybody know what colour the sealant is?-Problem is,this tyre fitter comes highly recommended round here and is normally quite trustworthy-but something's not quite right! The sealant is yellow. Also it is important to clean well the corrosion on the beads before apply the sealant if that is the reason for the leak. Re: Loss of tyre pressure - BBROWN1664 - 18-04-16 did he replace the valve stems? They are a known failure point. Re: Loss of tyre pressure - unfazed - 18-04-16 Very possible the valve has not been changed for a long time. They do perish and leak, badly perished one can break down suddenly. Fazer rims are pretty good lasting and unlikely to be the source of the leak. Don't go putting any crap without finding the problem first. Re: Loss of tyre pressure - flakey - 18-04-16 have your tyre fitter remove the tyre, replace the valve, clean up any corrosion on the wheel and then refit the tyre using the bead seal black sealant (like liquid rubber), rebalance your wheel, your problems should be solved, shouldnt cost much at all maybe £10 piss easy job for a tyre fitter. even the likes of ATS or national tyres or bathwick might do it Re: Loss of tyre pressure - redfox1 - 18-04-16 (18-04-16, 06:59 PM)flakey link Wrote: have your tyre fitter remove the tyre, replace the valve, clean up any corrosion on the wheel and then refit the tyre using the bead seal black sealant (like liquid rubber), rebalance your wheel, your problems should be solved, shouldnt cost much at all maybe £10 piss easy job for a tyre fitter. even the likes of ATS or national tyres or bathwick might do itYep-deffo going back to the tech to see if he can fix-this time I'm going to ask where any possible corrosion is,and see if it can be addressed.Since yesterday the back tyre lost about 2 psi,front wasn't so bad,but both still losing pressure,so I've no alternative-Thanks for all the useful advice,folks :thumbup Re: Loss of tyre pressure - redfox1 - 19-04-16 Just a quick update.Spoke to the tyre tech,who told me bring the bike back in.However,he said the wheels were corroded,and also that,if all else fails,he'd consider putting tubes in!-Now that's novel.Has anybody else heard of tubes under tubeless tyres?! Re: Loss of tyre pressure - NorthWestern - 19-04-16 They must be proper corroded... I have seen some in a real state and they are fine at keeping pressure. Mine are not the best and are fine, the beads usually manage a decent seal. Mine have both leaked at the valve Base. A quick squirt with oil and spinning them got me to the next set of tyres when I replaced the valves. Sent from my SM-G935F using Tapatalk Re: Loss of tyre pressure - unfazed - 19-04-16 (19-04-16, 05:58 PM)redfox1 link Wrote: Just a quick update.Spoke to the tyre tech,who told me bring the bike back in.However,he said the wheels were corroded,and also that,if all else fails,he'd consider putting tubes in!-Now that's novel.Has anybody else heard of tubes under tubeless tyres?! Not all tubeless tyres are suitable for putting tubes in. :eek I have never seen a fazer rim so badly corroded it would leak unless the tyre was fitted without tyre soap. The tyre soap not only aids putting on the tyre also acts as a bit of a sealant. I still think it is the valve needs changing and if it was changed he may have fitted it dry or could also be a bit of dirt stuck on the rubber of the valve core. Re: Loss of tyre pressure - robby boy - 20-04-16 Personally I would not recommend putting tubes in, if you get a nail in the tyre it will deflate at a much higher rate with a tube and if that happened on a spirited ride going into a corner who knows where you might land, I would check the valve stem where it comes through the wheel, if no leak there try round the rim and round the tyre, use warm water with a dash of fairy, (warm water sticks to the rubber and does not run off like cold) if it is round the rim clean all corrosion off and use the liquid rubber like others have already said. |
