Oh no.....not another bolt.... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oh no.....not another bolt.... (/showthread.php?tid=72697) Pages:
Oh no.....not another bolt.... - anutz - 29-05-15 OK so i have really messed up again :'( :'( :'( :'( :'( :'( :'( Snapped a front mud guard bolt and i really am annoyed - was using a torque wrench to get it to 7NM but it just span round and round then snapped....WTF can i do about this! yes i can ride without a fender but want to fix it....OMG
Re: Oh no.....not another bolt.... - Paulfzs - 29-05-15 get drilling! Re: Oh no.....not another bolt.... - anutz - 29-05-15 i am thinking left had drill bits might be best here after what i learned when the exhaust studs snapped..... Re: Oh no.....not another bolt.... - Andy Clap - 29-05-15 (29-05-15, 06:44 PM)Paulfzs link Wrote:get drilling!As the man said. That's one bolt I would never have thought of using a torque wrench on. Maybe something to be said for "Feels about right". Re: Oh no.....not another bolt.... - anutz - 29-05-15 it was a cyclo-torque wrench specifically for low torque - and the service manual does state 7NM....so i figured i would do it right :\ Re: Oh no.....not another bolt.... - Paulfzs - 29-05-15 7nm new, as above "feels tight enough" is what id use for this. Re: Oh no.....not another bolt.... - anutz - 29-05-15 Relief.....manged to grab the tinest piece of it and it came out with ease with a pair of neddle nose pliers!!!! WOHOOOO! I might just get this back together - eventually! Re: Oh no.....not another bolt.... - unfazed - 29-05-15 Are you sure the torque wrench was set to 7Nm and not set to 7lbf. Re: Oh no.....not another bolt.... - darrsi - 29-05-15 Were you using copper grease? Re: Oh no.....not another bolt.... - anutz - 29-05-15 so yes wrench was in NM ( other scale is inch-pounds..) and i was using copper grease... I really am perplexed as to why it happened, but we all know its usally operator error....so i cannot figure out what i did wrong!
Re: Oh no.....not another bolt.... - Paulfzs - 29-05-15 lucky then! maybe it was a worn bolt Re: Oh no.....not another bolt.... - anutz - 29-05-15 damn lucky - the tinest bit of thread left - i would like to know what happened - it felt like the bolt was twisting when i realised what happened.....exactly the same as the exhaust stud feeling thats what i thought oh no.....and stopped.....but it was too late - literally pinged off.... Re: Oh no.....not another bolt.... - Paulfzs - 29-05-15 it may have been done it too tight before and you just helped it finish itself off. Re: Oh no.....not another bolt.... - anutz - 29-05-15 yes i like that idea - it was like that when i got there - that will do nicely for this one :b Re: Oh no.....not another bolt.... - Andy FZS - 29-05-15 7NM would be for a dry bolt if you put grease on then 7NM on the torque wrench would be greater due to the lower friction due to the grease if that makes sense. Re: Oh no.....not another bolt.... - Jules-C - 29-05-15 Need to reduce the dry torque setting by 20% or more for greased bolt but can vary a lot depending on grease and materials. Sometimes a low torque setting is given then an angular measurement given to avoid the problem so you tighten to 3nm say and then tighten another 30 degrees Re: Oh no.....not another bolt.... - anutz - 29-05-15 Jules-C/Andy FZS - understood about the need to consider the effect of grease.....never considered it! How would you reliably figure it out - is there a chart that shows how certain greases affect the fixings? Re: Oh no.....not another bolt.... - anutz - 29-05-15 So can i ask - on bolts such as the suspension clamps, if they are greased - is that advisable or not, i am going to be doing a once over soon before the MOT, not sure wether i should copper grease all threads or not? Re: Oh no.....not another bolt.... - Andy FZS - 29-05-15 Sorry I can't really advise on % of torque if greased. I often put grease etc on bolts and seldom use a torque wrench. I tend to just nip things up until they're tight dependant on size. Not really helpful I'm afraid. Re: Oh no.....not another bolt.... - anutz - 29-05-15 nah its ok m8 don't expect it, i have copper greased the threads on the yoke bolts and tightened them to recommended torque, will re-consider |
