FZS 600 Is this one worth buying? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: FZS 600 Is this one worth buying? (/showthread.php?tid=62535) Pages:
FZS 600 Is this one worth buying? - trotsky - 24-03-13 Hi, could anyone tell me from their experience if the bike from this advert is worth considering and buying? Could you also share your opinion what to check if I go to see the Fazers? Are there any specific things to check and how to check the for the unexperienced bike rider? http://www.ebay.co.uk/itm/Yamaha-FZS-600-2003-1-OWNER-/150987402872?pt=UK_Motorcycles&hash=item23278cee78 Thanks for any help in advance and I will appreciate it even more for the quick answers as its a bit urgent Best Trotsky Re: FZS 600 Is this one worth buying? - unfazed - 24-03-13 Any one owner from new bike is always worth considering. This looks good and has some useful extras. The condidion from the photographs appears to reflect the low mileage, no flaking paint on the engine (looks original) and very little rust. Check the wear on the tyres and any rattles from the engine on startup, but. since you are buying from a garage it gives you a bit of a safety margin. Looks like the original rear shock, ask if it is and also and if the front sprocket nut has been changed to the modified one. Good Luck Re: FZS 600 Is this one worth buying? - trotsky - 24-03-13 Hi Unfazed, Thanks for your help. Will keep it in mind. If you think abouyt anything else that I should keep in mind please let me know. What my reaction should be to changed Rear shock and to the modified sprocket nut? Sorry if it sound stupid but I am new to bikes :o best Re: FZS 600 Is this one worth buying? - mtread - 24-03-13 Looks very good, and at a reasonable price for a clean foxeye. I've got one same colour same year, also one owner from new, but mine's done 36K without any problems. New downpipes and scottoiler are good signs. Looks like it's been well looked after. Agree with what's been said about the rear shock. Mine was like a pogo stick at 24K, so if it's the original it won't last much longer. Agree with what's said about rattles, but they aften rattle a bit before the camchain tensioner clicks over, then it goes. Looks a good one. Re: FZS 600 Is this one worth buying? - trotsky - 24-03-13 Hi mtread, Thanks. So if the rear shock is original it will need replacing sooner rather then later?! Am I correct? If so how expensive it is? Thanks for all the help. Best T. Re: FZS 600 Is this one worth buying? - unfazed - 25-03-13 A new rear shock could set you back around £300 from Hagon but may be cheaper ones available, good barganing point if it is original and 20000 miles is about the life of them. The front sprocket nut can loosen and fall off, Yamaha brought out a new thicker nut to solve the issue. Easily checked with a torch looking in along the line of the chain, it should be flush with the end of the Shaft whereas with the original one the shaft sticks out, outside the nut. I have exactly the same model with over 70000 miles on it and it has done everything from track days to two up touring in Ireland, England, Wales, France and Spain Re: FZS 600 Is this one worth buying? - mtread - 25-03-13 Yep, I agree with unfazed, 20K is about it for the original shock and a good bargaining point. I got a Hagon and no complaints. Re: FZS 600 Is this one worth buying? - bwizz - 25-03-13 my 600 started to pogo at around 26000 ,but my inlaws is ok at 25000. the thou's are more prone to rear shock's, Also check the fairing infills fit properly , sign of previous damage. also check the rear disk for mico cracks around the cooling holes, can be a real pain to change the disk, good bikes though ! Re: FZS 600 Is this one worth buying? - trotsky - 25-03-13 Hi All, could the below be trusted? I've done check on VOSA and the below came back. Thanks to all for the handy advices and i will try to make a good use of them. Would you mind if I ask few (or quite few) questions about Fazer in the future? Best Trotsky There are no later tests for this Vehicle. Most Recent Vehicle Details and Test Summary applicable to this Registration Certificate document reference number. Registration mark: XXXXXXXXXXXXXXXXXXXX Make/Model: YAMAHA / FZS600 Colour: RED VIN/Chassis No: XXXXXXXXXXXXXXXXXXXX Approximate date of first use: 01/04/2003 Type of fuel: Petrol Date of test: 23/07/2012 Certificate issued (Pass) Odometer reading: 19,150 Miles Test number: 446495202277 Test expiry date: 22/07/2013 Full Test History, starting with first recorded vehicle and test results Registration mark: XXXXXXXXXXXXXXXXXXXX Make/Model: YAMAHA / FZS600 Colour: RED VIN/Chassis No: XXXXXXXXXXXXXXXXXXXX Approximate date of first use: 01/04/2003 Type of fuel: Petrol Date of test: 04/04/2006 Certificate issued (Pass) Odometer reading: 13,044 Miles Test number: 473244496074 Test station name: MOTORCYCLE TYRE SHOP Test station number: 1ALC65 Test station telephone number: 01443 400122 Test class: II Test expiry date: 03/04/2007 No Advisory Notice issued Date of test: 30/03/2007 Certificate issued (Pass) Odometer reading: 15,948 Miles Test number: 602299887030 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 03/04/2008 No Advisory Notice issued Date of test: 06/05/2008 Certificate issued (Pass) Odometer reading: 16,951 Miles Test number: 140477428104 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 05/05/2009 No Advisory Notice issued Date of test: 24/04/2009 Certificate issued (Pass) Odometer reading: 17,184 Miles Test number: 902314319190 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 05/05/2010 No Advisory Notice issued Date of test: 29/06/2010 Certificate issued (Pass) Odometer reading: 17,717 Miles Test number: 644210380149 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 28/06/2011 No Advisory Notice issued Date of test: 28/06/2011 Certificate issued (Pass) Odometer reading: 18,981 Miles Test number: 568619171114 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 28/06/2012 No Advisory Notice issued Date of test: 23/07/2012 Certificate issue refused (Fail) Odometer reading: 19,150 Miles Test number: 517415502244 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Reason(s) for refusal to issue Certificate Rear Stop lamp does not illuminate immediately a brake applies (1.3.1a) No Advisory Notice issued Date of test: 23/07/2012 Certificate issued (Pass) Odometer reading: 19,150 Miles Test number: 446495202277 Test station name: REALWORD MOTORCYCLES LTD Test station number: 1ALY45 Test station telephone number: 01685870070 Test class: II Test expiry date: 22/07/2013 No Advisory Notice issued This completes the test history for the above vehicle as recorded on VOSA's MOT Computerisation Database Re: FZS 600 Is this one worth buying? - unfazed - 25-03-13 Ask away and good liuk with it, but post in the FZS600 section as this is the FZ600 section(under seat pipe). You will get more replies Re: FZS 600 Is this one worth buying? - trotsky - 25-03-13 Thanks Unfazed, Could that be moved into FZS600 section? Apologies for this Best T. Re: FZS 600 Is this one worth buying? - unfazed - 26-03-13 Just sent Farjo (administrator) a message on same Re: FZS 600 Is this one worth buying? - Arfa - 26-03-13 Looks decent. Obviously you're paying a spot more as it's a dealer. I recently picked up a same year fzs600 with only 13K on it, with blue screen, hugger, belly pan, spotless, with original pipes etc. £1800. Didn't have top box, but chap threw in panniers, tank bag and spare can. Re: FZS 600 Is this one worth buying? - Exupnut - 27-03-13 Did u get the bike trotsky as the ebay listing has ended ? Sent from my iPhone using Tapatalk 2 Re: FZS 600 Is this one worth buying? - trotsky - 27-03-13 (27-03-13, 08:34 AM)Exupnut link Wrote: Did u get the bike trotsky as the ebay listing has ended ? Hi Exupnut, I bought it today and it will arrive tomorrow (26-03-13, 06:27 PM)Arfa link Wrote: Looks decent. Obviously you're paying a spot more as it's a dealer. Arfa, I was looking for one of them and couln'd find any of that year for less. I got it for £2000. I think I saw a couple of them but up the north. And down the south they were more expensive then my final price FZS 600 Is this one worth buying? - Exupnut - 27-03-13 It does look in good condition. Good job. Looks like u dont need much doin... Just a great blank canvas for you to get moddin. Start with choppin that huge can down. Its foccin massive lol Sent from my iPhone using Tapatalk 2 Re: FZS 600 Is this one worth buying? - trotsky - 28-03-13 Hi Exupnut, Thanks and maybe I will see you one day on the road as well as all others. I just need to get on it and start riding :rollin Best T. Re: FZS 600 Is this one worth buying? - Dead Eye - 28-03-13 Look forward to seeing you at some meets soon Trotsky :-) Re: FZS 600 Is this one worth buying? - trotsky - 28-03-13 Dead Eye, for sure I just hope I will find few foccers in Hampshire to make a good start and then expand the riding area Thanks T. Re: FZS 600 Is this one worth buying? - inditime - 28-03-13 Looks like a good bike. I picked mine up from a dealer, 3 months warranty and only 14k on it for a MY2000. The MOT history is similar to mine, mine was used for the first few years and then had about 150 miles a year put on it. Mine is immaculate as well, but i think ill check that small sprocket nut issue. I wont tell you how much i paid for it for fear of upsetting trotsky :'( |
