Fazer 600 oil ,,, stuck - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fazer 600 oil ,,, stuck (/showthread.php?tid=61967) Pages:
Fazer 600 oil ,,, stuck - jonnel101 - 15-02-13 Hi im changing the oil on my fazer 600 99 model and cant find any min or max marks on the sight glass . It just looks likes a normal sight glass size but it is all black with a tiny hole towards the top is this normal any ideas where to fill to thanks in advance Re: Fazer 600 oil ,,, stuck - Fazerider - 15-02-13 It can be tricky to spot the oil level, a good source of light helps. You might need to take the clutch cover off and clean the inside of the glass, old mucky oil does tend to stain it. Re: Fazer 600 oil ,,, stuck - red98 - 15-02-13 the max and min marks are on the engine casing around the edge of the glass not on the glass
Re: Fazer 600 oil ,,, stuck - Dead Eye - 15-02-13 I tend to just use the sight glass itself as the min / max mark :| Can't say I've ever noticed the min / max marks on the casing before... Fazer 600 oil ,,, stuck - BBROWN1664 - 15-02-13 If the oil isn't visible, it's too low. If the oil fills the glass there's too much. Re: Fazer 600 oil ,,, stuck - unfazed - 15-02-13 Should be like this Re: Fazer 600 oil ,,, stuck - darrsi - 15-02-13 Strip the engine down from the left side, and pull all metal type things out of the way until you've bored all the way through to the oil window. Then clean the inside with a cotton bud........
Re: Fazer 600 oil ,,, stuck - born to be mild - 15-02-13 Why Mr Darrssi, our best intelligence from the village would have it that you are,sir, guilty of a simple omission, the sight glass would most surely need to be cleaned most dlligently from the outside as well as from the inside to be properly efficatous. Re: Fazer 600 oil ,,, stuck - darrsi - 15-02-13 (15-02-13, 11:05 PM)born to be mild link Wrote: Why Mr Darrssi, our best intelligence from the village would have it that you are,sir, guilty of a simple omission, the sight glass would most surely need to be cleaned most dlligently from the outside as well as from the inside to be properly efficatous. Bugger, didn't think of that...... :rolleyes Re: Fazer 600 oil ,,, stuck - noggythenog - 15-02-13 Aha But with a mere treatment of activ8 friction reducer it does not matter where the oil level is Boom boom tish tsssss!!!
Re: Fazer 600 oil ,,, stuck - darrsi - 16-02-13 (15-02-13, 11:31 PM)noggythenog link Wrote: Aha "Let the magic begin...." Re: Fazer 600 oil ,,, stuck - richfzs - 16-02-13 You're all missing the fucking point, the farkle gland needs replacing Sent from my HTC Desire S using Tapatalk 2 Re: Fazer 600 oil ,,, stuck - ChristoT - 16-02-13 (16-02-13, 12:57 AM)richfzs link Wrote: You're all missing the fucking point, the farkle gland needs replacing Next thing we know, you'll tell us our cloolass pump needs replacing, and we need to check the gullib level! Re: Fazer 600 oil ,,, stuck - richfzs - 16-02-13 You go too far.... Sent from my HTC Desire S using Tapatalk 2 Re: Fazer 600 oil ,,, stuck - darrsi - 16-02-13 Regardless of all the banter,whatever you do, make sure the bubble in the window is level...... :thumbup Re: Fazer 600 oil ,,, stuck - unfazed - 16-02-13 (16-02-13, 03:51 AM)darrsi link Wrote: Regardless of all the banter,whatever you do, make sure the bubble in the window is level...... :thumbup :rollin :rollin :rollin :rollin Re: Fazer 600 oil ,,, stuck - born to be mild - 16-02-13 Mine hasnt got a bubble, should I be worried? and if so,where can I get one? Re: Fazer 600 oil ,,, stuck - JZS 600 - 17-02-13 I check mine on the centre stand with a torch as the foccing level glass is so awkward to see on your own without some one holding the bike up for you and I don't fancy a 600 landing on my head on the drive Re: Fazer 600 oil ,,, stuck - darrsi - 17-02-13 (17-02-13, 11:11 AM)JZS 600 link Wrote: I check mine on the centre stand with a torch as the foccing level glass is so awkward to see on your own without some one holding the bike up for you and I don't fancy a 600 landing on my head on the drive Are you saying you've attempted to check the oil window on your own without the bike being on the stand before? Re: Fazer 600 oil ,,, stuck - DryRob - 17-02-13 I use several mirrors to check mine whilst riding |
