Date: 25-04-26  Time: 23:17 pm
Author Topic: This might help worth a look  (Read 2397 times)
devilsyam
« on: 14 September 2013, 08:27:09 pm »
So needed to take the generator flywheel off and you really need a puller but broke mine ages ago
so first i undid the bolt and removed it
then grab the least expected item in the spares box an old bar end weight
with no modification screw into flywheel
No i have not gone barking mad hang in there lol
insert allen key and rotate clockwise till tight (make sure motor is in gear keep going till it comes off
now unscrew bar end weight and put away till next time ya need to remove one
another clever idea Bourne out of total frustration lol
1999andi
Re: This might help worth a look
« Reply #1 on: 20 May 2014, 12:02:54 am »
This is great idea and the bad end fitted perfectly. Unfortunately the inside chewed up and I just managed to get it out. I need to get a fly wheel puller. Had. Look on eBay but non the wiser. Any suggestions greatly appreciated
devilsyam
« Reply #2 on: 20 May 2014, 07:24:35 am »
Find another repeat above whilst gently tapping the flywheel with hammer if all else fail bash it off as I have a spare you can have lol
Ianboydsnr
« Reply #3 on: 20 May 2014, 04:21:41 pm »
you tighten it up, then hit the end of the bar end with a hammer, the shock breaks it off, you should not be tightening the bar end to tight that it strips anything, the bolt or bar end needs to bottom out, then put some pressure by tightening a bit more
gixersix
« Reply #4 on: 23 May 2014, 01:44:41 am »
Tap - tighten - tap - tighten is the time honoured method.
