Date:
07-05-26
Time:
12:03 pm
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
VHT Flameproof Paint
« previous
next »
Print
Pages: [
Author
Topic: VHT Flameproof Paint (Read 3607 times)
hightower
WSB Pack Hound
on:
12 September 2013, 01:16:31 pm »
My engine block looks so tatty with the paint flaking. I was given a tin of something like this:
http://www.ebay.co.uk/itm/VHT-BLACK-FLAMEPROOF-EXHAUST-COATING-PAINT-SP102-/350869502666
from a lad at work - the picture on it is of the exhaust pipes, but would this sort of stuff go on to the engine block just as well?
If so would it just be a case of:
1) Clean parts to be sprayed
2) Mask parts not to be sprayed
3) Spray?
Logged
GP Hero
Re: VHT Flameproof Paint
Reply #1 on:
12 September 2013, 01:21:48 pm »
http://foc-u.co.uk/index.php/topic,8354.msg82143.html#msg82143
Logged
hightower
WSB Pack Hound
Reply #2 on:
12 September 2013, 01:33:55 pm »
Thanks, so paint should be alright?
Logged
GP Hero
Reply #3 on:
12 September 2013, 01:48:29 pm »
I used Plastikote spray, which isn't classified as high temp. spray and it's holding up fine.
Just make sure you thoroughly degrease anything you spray otherwise it'll cause you problems.
Logged
hightower
WSB Pack Hound
Reply #4 on:
12 September 2013, 01:50:21 pm »
Yeah, there a particular brand or just good old soap and water?
Logged
Dead Eye
Naughty Corner
GP Hero
Reply #5 on:
12 September 2013, 02:34:16 pm »
Proper degreaser would be better first - something like Ultra Gunk which you can get from Halfrauds or fleabay
Logged
GP Hero
Reply #6 on:
12 September 2013, 03:13:51 pm »
I used Gunk from a spray can but brushed it into all the nooks and crannies, then i jetwashed it off, which blew half the paint away but that wasn't really a bad thing, then smoothed down what was left with wet 'n' dry.
Logged
Naughty Corner
GP Hero
Reply #7 on:
12 September 2013, 03:36:17 pm »
ive used that VHT paint on my downpipes for years,very good paint,bit overkill on the engine.....as darrsi suggests , use plasticote,lots and lots of de-greasing is the key......pun intended
Logged
Naughty Corner
GP Hero
Reply #8 on:
12 September 2013, 04:49:41 pm »
Down pipes for me is Granvile cylinder black satin and once painted on you need to start up and heat up, you will see smoke and it smells a bit but it kind of bakes on. Im thinking of touching up my flat tops of fins with it. Comes in a tin and I cant see any brush strokes on the exhausts. It sticks to anything as I got some on the shiney bits and its a bugger to get off. Dont think I would do big flat areas with it tho
Logged
Punkstig
GP Hero
Reply #9 on:
12 September 2013, 07:34:11 pm »
I've used Hammerite on the engine with no problems!
Logged
jason1
Weekend Warrior
Reply #10 on:
14 September 2013, 02:55:36 pm »
I used barbecue paint on my engine , gave it a real good rub down , degrease , masked up and sprayed . Works a treat , also sprayed down pipes at same time . Used all weathers and still looking good .
Logged
Hedgetrimmer
GP Hero
Reply #11 on:
14 September 2013, 03:47:53 pm »
Quote from: Punkstig on 12 September 2013, 07:34:11 pm
Don't listen to him, this is the only guy I know who REALLY needs flameproof paint!
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
