Date: 01-05-26  Time: 08:08 am
Author Topic: FZS600gRR unreleased model  (Read 19332 times)
Ruby Racing
Re: FZS600gRR unreleased model
« Reply #50 on: 22 September 2013, 02:38:50 pm »
Surely the point of shaving the spacers instead of the swing arm is they are a shit load cheaper to replace if any mistakes are made,  not only that but an unmolested swingarm will have a higher resale value than a shaved one!
I agree. However I may have misunderstood Wraith600 as I read it that he shaved down the spacers that are PART of the frame, not the loose spacers. So that's a big job and expensive too.
Whilst I would rather not cut down the swing arm, it is a necessity as it is 10mm too wide to fit between the frame. So either the swing arm or frame is altered, I can't see how you could achieve it with just different spacers. However I'm happy to be proved wrong and that's why I'm asking the questions, so I can use the easiest solution. My plan is to replace the existing roller bearings with new ones with a smaller inside diameter so I can use the Fazer spindle without resorting to spacers.
Altering the swing arm is not that big a deal as it only cost me £25 and once the build is done the bike will have been heavily modified anyway and it wouldn't be possible to put it back to standard without a lot of work. Plus I have an additional sacrificial one to test on first.
Punkstig
« Reply #51 on: 22 September 2013, 04:27:43 pm »
In which case, yes, shave the swingarm  :lol
Yamazer-92
« Reply #52 on: 24 September 2013, 06:33:02 pm »
This is a bit of a noob question but does the thundercat front mudguard / fender bolt straight on to the standard Fazer forks?
Punkstig
« Reply #53 on: 24 September 2013, 07:55:05 pm »
Nope
