Date: 11-10-26  Time: 03:45 am
Author Topic: Rear Caliper.  (Read 37271 times)
kebab19
Re: Rear Caliper.
« Reply #25 on: 18 December 2011, 08:21:54 pm »
DaveC,
Read the 2nd posting on this thread - it links to the TRX850 rear caliper thread on the old FoC-U site & Andy's guide to what is needed for conversion.
The YZF750 rear caliper is apparently identical so should be the same process
You *will* notice a great improvement over the original setup
Let us know how you get on or if you need help - also some pics of your upgrade might encourage others to have a go too since the FZS600 rear brake is not universally admired!
davec
Re: Rear Caliper.
« Reply #26 on: 19 December 2011, 10:26:35 am »
Kebad19,
Thanks for that,I've got selective vision at times.I will go with the FZ1 caliper, if I can get 1,but the TRX850 conversion looks interesting.
kebab19
Re: Rear Caliper.
« Reply #27 on: 19 December 2011, 02:04:01 pm »
Yes, the FZS1000 looks best but is rare & usually expensive on ebay.
Both FZS1000 and TRX850 share the same brake piston seal kit so the pistons are the same diameter & therefore offer the same amounts of stopping power.
kebab19
Re: Rear Caliper.
« Reply #28 on: 21 December 2011, 12:52:48 pm »
FZS1000 caliper on ebay:
Item number: 120831901344
Scuffed & a bit pricey, tho....worth haggling hard IMO
TRX850 caliper, also a bit overpriced:
Item number: 160692405292
TRX850 caliper, cant make out if caliper mounting plate is included:
Item number: 140604640587
YZF750 caliper:
Item number: 350487682913
Item number: 260892570508
Item number: 190614804267 with mounting plate
davec
Re: Rear Caliper.
« Reply #29 on: 21 December 2011, 03:09:06 pm »
Yeah,that is a bit pricey,scuffed as well!I saw the YZF caliper on there the other day.I'm going to hang out for a reasonable priced FZ1 caliper,in no rush, not going to fit it until the spring.
Lumpy
Re: Rear Caliper.
« Reply #30 on: 21 December 2011, 03:12:09 pm »
My serviceable standard caliper will be up for sale soon when I get the new disc and Fazer thou caliper on it. The last one I saw went for £40 for goodness sake.
thom_1991
Re: Rear Caliper.
« Reply #31 on: 10 January 2012, 02:24:49 pm »
Will a 2008 Xjr silver spot rear caliper be an almost bolt on swap on a 98-03 Fzs 600 ala Fazer 1000 or a no no with completly wrong bolt spacings like an R1's? Ta
Lumpy
Re: Rear Caliper.
« Reply #32 on: 10 January 2012, 02:49:39 pm »
if you have one in mind, ask the breaker to measure the pitch, or pop onto an XJR forum and ask them the same. They will be quite accomodating.
thom_1991
Re: Rear Caliper.
« Reply #33 on: 10 January 2012, 03:06:47 pm »
Is the only difference between the various "spot" rear calipers the distance between the two caliper bolts then?
Lumpy
Re: Rear Caliper.
« Reply #34 on: 10 January 2012, 03:07:57 pm »
apparently not, there are lsightly different seals, valving, and drillings etc on some. The pitch differs from bike to bike.
