Date: 20-08-26  Time: 00:32 am
Author Topic: Mineral, Semi Synthetic or Full Synthetic for our machine?  (Read 18959 times)
Slaninar
Re: Mineral, Semi Synthetic or Full Synthetic for our machine?
« Reply #25 on: 14 August 2013, 10:08:49 am »
I used to get some fully synthetic stuff called Amsoil MCF from Opei, supposed to be the best.  The old girl went through a litre roughly every 1000 miles.  Bike had done approx 10K so switched back to Yamalube semi, doesn't use anything now.
Semi synth and mineral oils leave a bit of gunk residue, so it creates a sort of a seal. That's probably why the bike doesn't consume any more oil. It does not mean the engine is better protected, or fixed. On the contrary.
Heard many people putting heavy (20w50) mineral oil in order to fix the engine oil consumption. Sounds like painting a rotten metal fuel tank without previously removing the rust.
Though most oils are decent and as long as they are changed in time and the bike is warmed up before riding hard, there should be no problems. Most problems occur from lack of oil, not from mineral, cheaper oil.
VNA - BMW Wank
« Reply #26 on: 14 August 2013, 07:13:53 pm »
Quote
Your problem was probably that the bike had only done 6000 miles and was not yet fully scrubbed in.  You did the right thing in switching back to a semi synthetic and fortunately for you no harm was done.
Apparently bikes run from new on top notch fully synth often don't bed in and burn oil.  Turns some bikes into permanent oil burners, other folks claim they have chucked some cheap and nasty mineral oil in, given the bike plenty of abuse for a couple of thousand miles, switched back to semi and all was well again.
The late Kevin Ash on running in - http://www.ashonbikes.com/content/running
From the infamous oil thread  :lol
Quote
Peter Brett in that article from Castrol oils;
QuotePeter Brett says that they’ve discovered synthetic oils actually interfere with running in, for reasons which go beyond their low friction properties - there also seems to be a chemical process happening which hinders it. “Although you can treat an engine as fully run in after 500 miles, surface stabilisation continues for at least the first 5,000 miles of an engine’s life,” he says. “Synthetic oils actively prevent this from happening, and not simply by holding friction surfaces apart, although we still don’t know exactly why and how this happens. But there’s no doubt they inhibit the process itself. So the consequence of using a synthetic too early is your engine will never run in properly. I would even suggest waiting until 10,000 miles (16,000km) before using it in most engines subjected to normal use. Until then, you’re best to use an inexpensive but branded mineral oil.”
Hedgetrimmer
« Reply #27 on: 14 August 2013, 07:20:24 pm »
 :lol
pitternator
« Reply #28 on: 15 August 2013, 07:22:27 am »
talk to dek about how to bed an engine in .....
manufacturers detail a break in procedure which everyone can follow, but there are several theories about how best to do it.
My GS for example has almost no break in procedure, advice was just to avoid prolonged full throttle use ...ie thrash it , but not too much !  :lol
my local bmw service manager believes the harder you ride it in the first 600 miles, the better. Fully synthetic goes in at 600 miles.Hence why for first 600 ( mineral oil) it dont want to be mollycoddled) ...
Slaninar
« Reply #29 on: 15 August 2013, 07:46:45 am »
What do you think of this, controversial, method?
http://www.mototuneusa.com/break_in_secrets.htm
Hedgetrimmer
« Reply #30 on: 15 August 2013, 06:46:21 pm »
I did thrash one bike I had right from new - an FZ750 back in about 1987/88. Red lined it in every gear in one memorable ding-dong with a 1st generation GSXR750, all whilst still supposedly running it in (less than 600 miles on the clock). That bike revved freely with no problems for all the rest of the time I owned it. So that's a bike with technology 25 years older than we have now. I can't say I remember what oil I had in it, but again, oil that is now 25 year old technology.
cable tie
« Reply #31 on: 17 August 2013, 11:12:31 pm »
 Jon your bm ain't run in till 30k ! Now mine @ only 1000 miles on the clock, 137 mph on the autobahn and to this day it still ain't used a drop of oil.
I'm with Dek on the theory don't pussy foot around.
JZS 600
« Reply #32 on: 18 August 2013, 12:12:36 pm »
I was talking to a Beemer owner the other day and his mechanic was telling him that to run his GS in he needed to give it a thrashing.
The problem with them is the folk buying them are mostly fairly sensible and they don't normally ride that way anyway...
