Date: 29-04-26  Time: 19:00 pm
Author Topic: manual camchain tensioner fitment guide  (Read 55258 times)
snapper
Re: manual camchain tensioner fitment guide
« Reply #25 on: 17 July 2013, 08:14:02 pm »
sorry devilsyam to late for me , I have one on order
 Im all for group buys so would have been up for it as well !
devilsyam
« Reply #26 on: 17 July 2013, 08:16:57 pm »
yeah put it down to sat delay he only just got back to me lol
fireblake
« Reply #27 on: 17 July 2013, 10:24:33 pm »
I'll be up for one. Bikes coming up to 30, 000 miles now.
PieEater
« Reply #28 on: 18 July 2013, 05:49:08 pm »
I would also be interested.
Edit/- Seeing as everyone else is buying their own I have done the same.
snapper
« Reply #29 on: 19 July 2013, 12:08:38 pm »
got to say bloody good service mine arrived today !
 not sure when I'll get chance to fit it but at least its here ready
Hedgetrimmer
« Reply #30 on: 19 July 2013, 12:13:00 pm »
+1  :)
R1FSR
« Reply #31 on: 19 July 2013, 08:55:42 pm »
Ordered mine earlier
Ian-man
« Reply #32 on: 19 July 2013, 11:11:01 pm »
Mine arrived today, excellent service and nice quality. Need to fit it before my Scotland trip in September.
b1k3rdude
« Reply #33 on: 20 July 2013, 09:21:41 pm »
b1k3rdude do you want me to get you one
Tis ok, I msg'd him and he removed the restriction and will be fitting mine tomoz.
Regarding adjustment, how often do we now need to check? every 3 months..?
devilsyam
« Reply #34 on: 20 July 2013, 09:35:12 pm »
mines been in a year on the yellow bike and checked it last week marked it with a marker and reset difference was the width of the marker about 0.5 mm bog all really
Hedgetrimmer
« Reply #35 on: 20 July 2013, 09:45:48 pm »
What mileage covered in that year?
devilsyam
« Reply #36 on: 20 July 2013, 09:48:41 pm »
about 5k yellow bikw dosent do much millage just fitted one to the black bike this does 500 miles a month year round so should be a better test
Hedgetrimmer
« Reply #37 on: 20 July 2013, 09:51:58 pm »
Did you check it cos it started to get a little noisy, or just curious?
devilsyam
« Reply #38 on: 20 July 2013, 09:59:39 pm »
because every one kept asking made me paranoid
Hedgetrimmer
« Reply #39 on: 20 July 2013, 10:01:19 pm »
:lol
brooker81
« Reply #40 on: 23 July 2013, 09:07:37 pm »
Two more on eBay now ! Well 1 more in a second
bigfootpete
« Reply #41 on: 24 July 2013, 09:07:14 pm »
How long is the OEM designed to last?
Hedgetrimmer
« Reply #42 on: 24 July 2013, 09:14:05 pm »
It's a case of you can't wait around to find out. Check further back in this thread, there's an example of one failing at a mere 25k miles, resulting in bent valves. Apparently on the OEM ones, the springs fail.
VNA - BMW Wank
« Reply #43 on: 25 July 2013, 11:04:40 am »
Quote
Dunno.   But until I'd seen this thread I hadn't been aware that there was a tensioner issue.
I thought many bikes had done over 100,000 miles - I assume on the OE tensioner, some over 200,000 miles?
Presumably this is the same tensioner fitted to the R1, R6 etc for years.
I do like the idea of a manual tensioner - so simple.  But why did Yamaha fit an auto tensioner?  Are there reasons why the tension needs to vary in day to day running?
Also how do we know exactly how much tension to apply to the manual unit?
Curious.  Might replace mine, but I'm in no rush.  Not sure it's the right move.
PieEater
« Reply #44 on: 25 July 2013, 02:26:19 pm »
My guess is that failure will be age related rather than mileage related. The spring in the tensioner will be applying the same pressure regardless of whether the bike is being used or not. I just had the spring go on one of my passenger footpegs, and then read this thread and thought if I'd just had one spring go on the bike ..........
As you know chains stretch from new, an auto tensioner will remove the necessity for a service item which may get overlooked on the first few services leading to warranty claims. Once a chain has done a few thousand miles it will stop stretching as much so adjustment becomes less of an issue, you're looking at thousands of miles not day to day.
I've just fitted mine, and this part wasn't that straightforward, I think I got it right but might ask a mechanic to double check. when you're tightening the tensioner you can feel when it starts applying pressure to the guide, with the engine running you then start to hear the rattles start to smooth out as you apply more pressure. You need to find the point where all the rattles have gone without applying any excess pressure on the guide, I found this part a little difficult especially with the fan running so I tried a few times and found where I thought the best setting was. Apparently if you overtighten you hear a whirring sound which I never got to hear so I assume all is good as the engine sounds as good as it did prior to replacing the tensioner.
devilsyam
« Reply #45 on: 25 July 2013, 08:18:35 pm »
pie i think ya looking to hard - as you tighten from the rattle you hear the rattle slowly quieten your listning for a sweet spot go to far and you can here a weering noise as too much pressure is being applied
its like in the vid rattle to 1/2-3/4 turn fan dont help granted nor did my clutch rattle lol
VNA - BMW Wank
« Reply #46 on: 25 July 2013, 11:07:39 pm »
OK follow the logic.  Though there are lots and lots of such parts on a bike.
How many failures have we had on the forum?
And how many miles have been clocked up with manual tensioners?
Anyway reminds me she's heading towards 29,000 miles now, been busy with other things, but I better get her in for a valve clearance check in the next few weeks.
steve pring
« Reply #47 on: 26 July 2013, 10:20:14 am »
Whether to have one fitted or not?
I would always ask myself the question ..... has Mike had one fitted to his fazer?
snapper
« Reply #48 on: 26 July 2013, 10:31:10 am »
I think this is more about prevention
£35 and half an hour of you time against the risk (all be it limited risk) of a big bang
as the expression goes "you pays your money you take the risk "
My bike has down nearly 21k now and to be honest I probably don't need it , but to me prevention is better than cure or repair
each to there own !
VNA - BMW Wank
« Reply #49 on: 26 July 2013, 11:36:11 am »
Mike has been quiet for a while, maybe he's off on an Ivanising world tour!
Quote
Yeah, while I follow the logic, I'm not 100% convinced.  Also this is a part off e-bay.  Not sure who made it.  Are the materials and the head 100% correct?
I do see a company called APE making em - http://yamahazone.biz/tensioners.html
And they say;
Quote
APE manual cam chain tensioners are designed to replace the automatic and hydraulic tensioners on high performance engines. The automatic adjusters can back out when the throttle is closed suddenly at high rpm. This allows the cams to go momentarely out of time, and can result in bent valves and/or serious engine damage. Hydraulic tensioners have a tendency to put too much tension on the chain guide under high rpm/high oil pressure conditions, resulting in premature wear.   Both problems can be eliminated with the installation of the APE manual tensioner. No mater what the engine does, the cam chain tension will remain constant. An APE manual cam chain tensioner is a must for any kind of performance riding.
 APE manual tensioners are CNC machined from billet alloy to exact tolerances for perfect fit.
