Date: 25-05-26  Time: 17:54 pm
Author Topic: Starter Relay Woes  (Read 3560 times)
boozardy
Starter Relay Woes
« on: 10 June 2013, 09:56:01 pm »
Hi All, any help would be appreciated! My starter relay is making a rapid buzzing/clicking when I press the starter button, I thought at first it was the battery dead! So I bought an optimate 4 on impulse! Then I took the multi meter home from work and discovered I had over 12v on the battery! Bugger.......... does this mean the relay is buggered or a symptom of something else? Forgot to mention? The rev counter needle goes off on one after I release the starter, it was fine two weeks ago when I last rode it then yesterday, this! ps the battery is 2years old. Advice anyone??? Cheers, Tony
Hedgetrimmer
Re: Starter Relay Woes
« Reply #1 on: 10 June 2013, 10:20:37 pm »
I'm guessing your rev counter is giving a fault code - does it flick up to a particular revs, stay for a couple of seconds, drop back to zero and repeat? That's a fault code indication. Have already put up a post for someone in the know to help with all the different codes, but I'm sure someone with more tech. knowledge than me will be able to help you.
The Male Whale
« Reply #2 on: 10 June 2013, 11:43:14 pm »
Have you got more than 12v when cranking the starter?
If not, (and I suspect you haven't) then get a new battery as yours is focced.
Whale
Falcon 269
« Reply #3 on: 11 June 2013, 05:01:40 am »
Battery voltage needs to be a lot more than a bare 12v. :)
Ignition off, you should get 12.7v across the terminals on a good battery.  Under 12.3v or so and the battery is as good as dead.
Your symptoms in the first case are classic dead battery.  Eliminate that first and then come back to us if the problem persists.
fazer-rat
« Reply #4 on: 11 June 2013, 05:24:10 am »
try cleaning your earth connection to the bike, the fault you have is low voltage at the starter circuit which can be caused by a bad earth connection.  my thunderace did this and i cleaned the connection at the engine,, sorted.
PaulSmith
« Reply #5 on: 11 June 2013, 12:56:01 pm »
You've bought the optimate, now use it. It will charge a charge a healthy battery, recover a tired battery, or tell you it is fucked.
boozardy
« Reply #6 on: 11 June 2013, 08:58:40 pm »
Hmmmmmmm! Cleaned  all terminals and charged up, put meter on battery whilst cranking and got 5v.................... I guess i'll go for the new battery! I just want to play!!!!!! Will report back!............... just out of curiosity any particular battery I should go for? Ps thanks for all the advice guys... Tony
tomlinscote
« Reply #7 on: 11 June 2013, 09:29:25 pm »
motobatt seem popular.....
tommo
Hedgetrimmer
« Reply #8 on: 11 June 2013, 09:52:13 pm »
If money's no object, I'd say Yuasa, but I've found Turbo's to be quite good too (distributor used to be Feridax).
boozardy
« Reply #9 on: 15 June 2013, 11:21:00 am »
Sorted!!!! A new battery and now it's back to it's barking self!!!!!!!!! Thanks for all the advice guys, now i'm off to play :lol ........... Tony
