Date: 19-04-26  Time: 14:11 pm
Author Topic: fuel pump  (Read 2610 times)
phil on a fazer
fuel pump
« on: 29 May 2013, 02:14:44 pm »
pleae help  :o
went out 2 start my fazer today after about a 3 week lay up (battery has been charged though).
Turned ingnition and the fuel pump clicked away as normal, hit starter, turned over but didnt catch - this is normal, my fazer doesnt like being started if it has been riden for a week. BUT..when i let go of the starter, the fuel pump clicked away a bit more???
ignition off......back on, fuel pump clicks for 5 secs but kind of sounds like theres a loose connection (the sound isnt "even" if that makes sense)
so i did igntion on...fuel pump clicked for 5 secs...ignition off....back on...clicks for 5 secs....AND SO ON, it just keep clicking away always for 5 secs.
This isnt right is it??? never done it before and i thought the fuel pump just primed the carbs? so why is it doing it for 5 seconds every time the igntion is switched on??
Falcon 269
Re: fuel pump
« Reply #1 on: 29 May 2013, 05:32:06 pm »
The fuel pump shuts off when the float bowl level is correct.  Perhaps the pump is not getting the pressure resistance expected and so continues to operate for a while longer.  Could be symptomatic of an issue with the float needle seat O-rings, Phil.
However, start by checking the obvious things like electrical connectors, fuel lines and fuel filter before you assume it's inside the carbs.
phil on a fazer
Re: fuel pump
« Reply #2 on: 29 May 2013, 05:55:29 pm »
ok. i do actually have a brand new fuel filter in my garage. So i will fit that, dont you have to remove the fuel pump to do so?? (if so, that will give me chance to spray up / clean the connectors)
thanks
