Date: 09-05-26  Time: 08:09 am
Author Topic: fazer 600 2001 misfire  (Read 13588 times)
bucksfiz
Re: fazer 600 2001 misfire
« Reply #25 on: 28 May 2013, 09:31:31 pm »
will rip carbs off again when i get a chance and give em another good clean   then report back  cheers so far boys for all your help very much appreciated
Ebme Geek
« Reply #26 on: 29 May 2013, 04:14:08 pm »
If you prime up the carbs, ign on wait for fuel pump to stop clicking just before you remove them and then keep them verticle, remove the bowl of dodgy no4 and a good one and compare the fuel levels between them.  If you loose any fuel out of them getting them out just top them up again out of the frame.
This is better than just a "float level" check, as that don't prove the needle valve is not bloked or other no fuel flow problem / blockage, stuck float as mentioned possible
« Reply #27 on: 29 May 2013, 05:42:43 pm »
A quicker and less messy method of checking the fuel levels in the carbs is to use a length of pvc tubing on the drain spigot as described in the manual. By draining the bowl first (may need to turn off the fuel tap under the tank briefly) you can compare the filling rates for a good carb and carbs 3 and 4. That way you can find out if the problem is in the fuel supply side without even taking the carbs off.
« Reply #28 on: 29 May 2013, 08:13:23 pm »
 :agree  yep...thats the way i do it.......i would check that first but its more likley to be the float valve  ;) [size=78%] [/size]
bucksfiz
« Reply #29 on: 29 May 2013, 09:27:07 pm »
at last shes sorted    it,s in the thames   only joking before u go looking         firstly sincere thanks to all for your inputs, helped imencly many many thanks     took the carbs off and gave the another good strip down and blew the fook out of em and that cured it shes as good as new   cheers boys many thanks.
« Reply #30 on: 30 May 2013, 06:56:52 am »
nice one matey.....did you see what was causing the blockage or was it just a general clean and blast with the airline ?.......glad its sorted  :)
bucksfiz
« Reply #31 on: 30 May 2013, 08:58:25 pm »
hi m8 when i striped carbs first time they were still like new and found no s-it  in them did not use a compresor first time  as i dont like blowing 100+ psi,s around esspecally when they still looked like new as usually with my luck something important usually gets blown accross the other side of the workshop and losted    many thanks for your help  cheers kind regards gaz
« Reply #32 on: 31 May 2013, 07:37:59 am »
ha ha....yeh, know what you mean about losing things with an air line,done that a few times,you mention the thames a few times are you at the london end ? if yes your more than welcome to join in with our "london foccers monthly ride-outs " :)
bucksfiz
« Reply #33 on: 01 June 2013, 11:53:24 pm »
yes near the 02 whens the next ride out and where
Dead Eye
« Reply #34 on: 02 June 2013, 06:14:22 am »
The next ride out, is today :D Leaving from the Ace Cafe at around 8.30am
Exupnut
« Reply #35 on: 02 June 2013, 06:34:40 am »
Wow! Ur up. Seeya 7:45
