Date: 07-05-26  Time: 03:14 am
Author Topic: Low revs stuttering  (Read 11636 times)
Re: Low revs stuttering
« Reply #25 on: 17 June 2013, 10:29:47 am »
All very interesting - got a similar problem on my thou. Was much worse with open Viper can which was on the bike when I bought it. Changed to standard can, better but not right still. Have just put new Scorpion can on, as good as standard, but still not right. Problem seems to be at worst at about 3k rpm off throttle. Everywhere else, no problem. Can't work on my own bike due to shoulder problem which makes things very awkward, so sooner or later gonna have to take it in somewhere and lay out for someone else to take a look  :(
Pilot circuit problem?
hi nick......baffle,in or out ?
Hedgetrimmer
« Reply #26 on: 17 June 2013, 10:40:02 am »
Baffle in. I've no idea what's in the airbox either.
« Reply #27 on: 17 June 2013, 11:36:46 am »
i would be interested to see what its like if you ever take the baffle out  ;)
Hedgetrimmer
« Reply #28 on: 17 June 2013, 11:48:30 am »
Red, tbh I don't think the problem is to do with the can, even though it was worse with a straight thru pipe. I've consulted with Mike (Falcon 269) about this, he suggests looking at plugs/plug caps/HT leads first, which I will have checked/changed when I (finally) get round to taking it in. But I've had bikes with those sorts of problems before, and it just doesn't feel like that, you know? Plus, with plugs/coils breaking down, I would've thought the problem would be worse higher up the rev range?
Hedgetrimmer
« Reply #29 on: 17 June 2013, 11:52:15 am »
PS.
I've also run a fuel system treatment through the tank, no change.
« Reply #30 on: 17 June 2013, 12:08:57 pm »
mmmmmm...sounds like you two have simular problems  :\ ....ANARCH..looks like your carbs are ok then  ;)  iam thinking electrics but not my strongest point  :o  when i first started trying to cure my stutter i bought secondhand ecu,tps and coils and swapped them in turn to see if that was the problem,japanese electrics are very reliable and after 15 yrs and 40,000 miles mine were fine.....looks like mine is a wiring fault (worn through and broken) but not proved yet  :rolleyes
i`ll be interested to see what ADE THE BLADE thinks...................
CRH
« Reply #31 on: 17 June 2013, 02:08:07 pm »
...no use asking morris paul!!..he,s tooooo loved up with....BAAAAAAAAAAAAAAAAAAAAAAAbra :rolleyes
« Reply #32 on: 17 June 2013, 03:30:58 pm »
ha ha....MORRIS THE BLADE.....dos`nt roll of the tongue as well as ade,earning a few extra quids and he does get to keep the outfits  :lol :lol :lol ........come on ade put baaaaaaaaabra down and give us your opinion.......
Anarch
« Reply #33 on: 17 June 2013, 05:31:34 pm »
I think I'll make a video of the engine running tomorrow - maybe this will give you some ideas - cause I'm clueless at this point :)
Initially I was only able to detect it up to 3k RPM but now I can hear when accelerating up to 6k. Could it have anything to do with exhaust ?
Hedgetrimmer
« Reply #34 on: 17 June 2013, 05:55:08 pm »
Anarch, was your bike laid up for any length of time before you got the symptoms? It's just that Soapy, who's just joined FOC-U, is having similar problem after his bike was laid up for the winter - I bought mine recently from a dealer and suspect it may have sat for a while since last use.
« Reply #35 on: 17 June 2013, 08:29:11 pm »
video would be good  :) ....my thou is effected by the end can,lumpy tickover and up to 3/4000,great there on,i think its the way the cans are just not my cup of tea.....
Hedgetrimmer
« Reply #36 on: 17 June 2013, 08:30:55 pm »
Except that mine's doing it with standard can too... :\
« Reply #37 on: 17 June 2013, 08:52:07 pm »
thats blown it  :rolleyes
Soapy
« Reply #38 on: 18 June 2013, 10:47:32 am »
Hi Nick. Looks we are part of a small club with similar issues. Hopefully between us we can get sorted. Cheers John S
otis
« Reply #39 on: 18 June 2013, 07:10:48 pm »
Had a similar problem a few months ago. #1 zorts was not getting as hot as the others. Checked the plug and had not bad spark. Turned out that it was a dodgey plug that would break down as I gave it the beans but ok if I nursed it. I know you have changed the plugs but you get bad ones. Have you tested the headers to see if any are not as hot as the rest ?
