Date: 26-03-26  Time: 02:33 am
Author Topic: touring Spares  (Read 3238 times)
Notch000
touring Spares
« on: 17 May 2013, 01:08:47 pm »
Um packing for a euro trip, can anyone tell me the correct spec bulbs to get
Headlight H4 H7 ??,
dips
indicators
brake light for my shopping list,
Also should i also get some more spare fuses or will the spares in the box be enough ? ive never needed any yet
thanks
Re: touring Spares
« Reply #1 on: 17 May 2013, 01:18:17 pm »
Headlights are H1 & H4
Punkstig
Re: touring Spares
« Reply #2 on: 17 May 2013, 06:34:32 pm »
Get a set of these -
http://www.craftyplugger.com/
I carry them at all times along with a mini compressor from halfords, piece of piss to use and could save you hours at the road side waiting for recovery for something you can do yourself in 10 minutes!
Notch000
Re: touring Spares
« Reply #3 on: 17 May 2013, 06:39:25 pm »
got a set of plugs on the way, might get a small compressor or just take the bicycle pump, any good for big bikes ?
Punkstig
Re: touring Spares
« Reply #4 on: 17 May 2013, 07:14:18 pm »
Bike pump will be fine, it'll just take a while to pump up and you'll get fed up compared to plugging in a compressor, you can fit one under the seat with space to spare!
stevierst
Re: touring Spares
« Reply #5 on: 17 May 2013, 08:35:53 pm »
A roll of thick black fabric backed tape, cable ties, and a multitool. You can fix pretty Mich anything with that! And make sure you have a tool that fits EVERY nut, bolt, and Allen key on the bike.
FuZzBoM
Re: touring Spares
« Reply #6 on: 17 May 2013, 09:32:30 pm »
Spare set of levers is a good idea.
I got a set of these cheap ones http://shop.the2wheels.com/CNC-Adjustable-Clutch-Brake-Levers-Set-for-Yamaha-Lever-Set-Yamaha.htm
They are rather good for the money.
I keep the original ones under the seat just in case.  :D
stevierst
Re: touring Spares
« Reply #7 on: 17 May 2013, 10:15:56 pm »
+1 on the levers, great idea! ;)
Notch000
Re: touring Spares
« Reply #8 on: 18 May 2013, 12:14:49 am »
ya I have stocked on gorilla tape, zips ties and elec tape, multi tool and a small snips + 4-8mm allen keys(need to doubly check), Il probably just bring a small vice grips instead of levers, if i cant get some during the week, hopefully wont need but will get me to the nearest shop if needed.
I only looking into the original tool kit today, I never realised its so comprehensive, has 'almost' everything needed already
Anyone a spec on brake and indicator bulbs ??
Dave48
Re: touring Spares
« Reply #9 on: 18 May 2013, 06:03:36 am »
NotchOOO-re bulbs. Halfords do "sets" of bulbs for bikes-BUT I bought spare bulbs individually   & packed in small strong plastic box from "Poundland"-also  carry a  few spare fuses ( of right size &rating!) & small torch.. If you have an immobiliser make sure you have the correct fuse (my old Datatool used a 3A).-better than being stranded!
Notch000
Re: touring Spares
« Reply #10 on: 18 May 2013, 09:01:29 pm »
will do, no imobaliser, just as chain & disk lock for packing, just got to get the last couple of bulbs and fuses and im nearly packed i think !!
Slaninar
Re: touring Spares
« Reply #11 on: 19 May 2013, 11:36:35 am »
I like to carry:
A way to fix a flat tyre
(this I use on the Fazer:
http://www.louis.de/_10792ce8fd86b0c6edabc6d1161a729161/index.php?topic=artnr_gr&artnr_gr=10032076
and this (in case it is dark and pouring rain) - quicker, but messier:
http://www.louis.de/_10792ce8fd86b0c6edabc6d1161a729161/index.php?topic=artnr_gr&artnr_gr=10004874
And a small bicycle pump (to top up after using CO2 cartridges).
Way to change oil, spark plugs (and spare plugs), brake pads, coolant, chain tensioner etc. It all comes down to several wrenches, a ratchet with a needed parts (I don't carry full ratchet kit, just needed sizes), few allen wrenches etc.
Way to remove wheels (in case of major tyre failure) - also a few wrenches.
Set of spare bulbs and fuses. It all packs under the seat (alongside alarm and scottoiler). Yes, I also carry scottoiler oil if it's a really long trip - but this doesn't fit under the seat.
What I don't carry, but think it is wise to carry is a set of spare levers and a spare clutch cable.
Spare levers and a spare clutch cable are a smart thing to carry.
